highvoltage_32 Fordmods Newbie
Age:36 Posts: 3 Joined: 03 Jan 2005 Location: brisbane QLD, Australia
Posted: Sat Apr 02, 2005 9:31 pm Post subject: nc fairlane overheats |
gday
my nc v8 fairlane overheats going up hills.i have had the radiator cleaned by rad wshop,and replaced thermostat,but still no good.sitting at lights and long periods of idle o.k.long trips and freway driving o.k.only up inclines and only takes about 10 minutes to overheat.any help would be appreciated.
thanks  |
NC 5ltr Fordmods - Getting Side Ways
Age:28 Posts: 1053 Joined: 12 Nov 2004 Location: Newcastle NSW, Australia
Posted: Sat Apr 02, 2005 9:38 pm Post subject: |
i had a similar problem with mine , when the car is under load it overheats! have you had the radiator flushed and cleaned,did they clean out the s**t in those side thingeys on the radiator? u l;osing water? apart from that the only other thing i can think of is that maybe a hose is blocked.
hope that helps
cheers |
Posted: Sat Apr 02, 2005 9:43 pm Post subject: |
| It depends on how they cleaned out the tank, sometimes they do a verry poor job so I usually just replace the tank instead. Also could be the fan viscous hub (they aren't thermos are they) or water pump although I think it will come down to either radiator or fan. |
Posted: Sat Apr 02, 2005 10:05 pm Post subject: |
| yeah they cleaned the cores out. no extenal leaks but sometimes does leak from overflow without overheating.the vacumm operated heater switch/valve? does drip when engine is cold but takes up when engine is warm.haven't checked water pump yet,but if water pump was f**ked would be evident on the long trips?yes/no? |
Posted: Sat Apr 02, 2005 10:17 pm Post subject: |
the fan is viscous/clutch,but i was to believe the fan clutch was primarily to keep the engine cool at idle and in traffic.?but if this could contribute to the problem could u please explain so i could understand a little more into the workings of the fan clutch.
thanks |
Posted: Sat Apr 02, 2005 10:28 pm Post subject: |
| As the viscous hub gets old, the fan tends to slip more so its not actually moving as much air as it could so obviously the engine gets hotter. It is primarily designed for keeping the engine cool at idle and light throttle but if it is slipping at all then the cooling system won't be able to cope under heavy loads etc. I think there is a greater possibility that the radiator is still slightly blocked but its worth checking everything anyway. |
Posted: Sat Apr 02, 2005 11:05 pm Post subject: |
| I bet this is it... |
Posted: Sun Apr 03, 2005 10:32 am Post subject: |
Replace the viscous fan with a thermo fan.
You could also run a davies craig electric water pump. They are extremely good at cooling an engine, although their controller is overly complicated and in my experience, doesn't work.
Edit: Or it could be that your pump is worn out. |
dalesf150 Fordmods Stock as a Rock
Age:29 Posts: 183 Joined: 05 Apr 2005 Location: berwick VIC, Australia
Posted: Thu Apr 07, 2005 4:44 pm Post subject: think mine's the water pump |
I was cooking my nc a bit to so I replaced the rariator with 3core and put a new thermostat in 180 insted of 192 so I can bump ignition for premium fuel when I get the cooling sussed.
Found the car was still geting hot in traffic and unusually while going up hills even at 110kmh. at that speed the fan's probebly wouldn't be keeping up with airflow anyway which leaves water pump.
have orderd a high flow water pump from the states should be here in the next couple of weeks. I'm also ditching the clutchfan but thats just so I can fit the au xr8 snorkel as it fit's almost perfectly appart from the fan shroud being in the way. |
