NUTZEF Fordmods Stock as a Rock
Age:24 Posts: 164 Joined: 09 Nov 2004 Location: melbourne VIC, Australia
Posted: Tue Jun 03, 2008 9:31 pm Post subject: need advice |
was out at calder last friday night and manage to run a 14.2 at 100mph on 7 psi with my standerd computer and injectors in place with rising rate fuel reg. (wolf and 550s not fitted yet) had a good 2.o second sixty foot but 14.2 is dissapointing. i know i need to get it tuned but been lazy, it has a stock motor with 170 psi in each cylinder so comp is not an issue. turbo is an off the self garrett t66 turbo with ar70 comp not to sure on turbine but think it is 1.02. car runs a manual with 3.45 gears so pull in first and second in sweet but put it in third and is lagy untill about half way throu.
car still has a 1673 cam so thinking going back down to a 1604 wade cam might help plus with the tune and bigger injectors.
i wont to keep this car manual cause its more fun just dont wont the lag.
any help on making it less laggy wouldbe nice thanks guys |
Age:24 Posts: 1846 Joined: 25 May 2006 Location: Perth WA, Australia
Posted: Tue Jun 03, 2008 10:12 pm Post subject: |
I'd be looking to get the tune done asap.
Dunno, with those sixty foot times it looks to be going hard off the line, maybe its the top end, either a bit rich or lean and it will cost the top end.
Maybe a dyno run and check Air Fuel Ratio's, if they check out to be fine, then I'd be looking at your driving.  |
Age:20 Posts: 897 Joined: 26 Nov 2004 Location: Waroona WA, Australia
Posted: Tue Jun 03, 2008 10:26 pm Post subject: |
leave the cam its not the problem, but u could advance it alittle.
it just needs a tune it would be to rich, with incorrect ignition advance. |
Posted: Wed Jun 04, 2008 9:33 am Post subject: |
| You will get far less lag with auto and heaps better 60Ft times.. The turbo spools on converter BEFORE the go light comes on.. The turbo won't spool on rpm alone.. I suggest get it tuned properly and set up a two step rev limiter so it builds boost while staging... In effect it becomes a pre stage anti lag program... Hope you don't have a T5 tranny... |
Age:21 Posts: 808 Joined: 17 Aug 2005 Location: S.E. Melbourne VIC, Australia
View User Gallery (21)
Posted: Wed Jun 04, 2008 9:42 am Post subject: |
Get an auto with a 3000rpm stall!! shouldn't have much lag issues then, and you should get faster times as well  |
Posted: Wed Jun 04, 2008 1:05 pm Post subject: |
wont to keep it manuel
yes it t5(i know cant affort tko yet)
it starts to lagging under full load at the start of third ????????
and no its not my driving |
ebs_4l Fordmods - Getting Side Ways
Age:24 Posts: 848 Joined: 23 Sep 2005 Location: kadina SA, Australia
Posted: Thu Jun 05, 2008 1:50 am Post subject: |
Graham - your one funny guy, you just used these words all in the same context...
Two-Step
Anti-Lag
T5....
hahaha..
on the topic though, theres no point chasing possible solutions, without first checking some vital signs... a/f and ign for starters |
Posts: 2557 Joined: 27 Dec 2004 Location: melbourne, sunshine VIC, Australia
Posted: Thu Jun 05, 2008 1:59 am Post subject: |
| EBXR8380 wrote: | | You will get far less lag with auto and heaps better 60Ft times.. The turbo spools on converter BEFORE the go light comes on.. The turbo won't spool on rpm alone.. I suggest get it tuned properly and set up a two step rev limiter so it builds boost while staging... In effect it becomes a pre stage anti lag program... Hope you don't have a T5 tranny... |
how does the 2 step and anti-lag work basically? |
