Need info on a factory system
Silver XR
PostPosted: Sun Nov 07, 2004 7:48 pm    Post subject: Need info on a factory system Reply with quote
Need info on a Premium sound 6 in-dash cd for a 2001 XR6 AU2 ute.
i need the specs on speakers, and location of amp if the utes have one?
post if you have any ideas.
Interceptor
PostPosted: Mon Nov 08, 2004 12:08 am    Post subject: Reply with quote
speakers are 5X7 front and rear, and there isnt an amp
anything else you wanna know?
ch0c0
PostPosted: Mon Nov 08, 2004 1:49 am    Post subject: Reply with quote
FYI there are a few manufacturers who are now making aftermarket 5x7 component split systems,
clarion / alpine do im sure, and probably a few others too !
Chicken
PostPosted: Mon Nov 08, 2004 2:09 pm    Post subject: Reply with quote
Isn't that info in the owner's manual?
I have all the factory sound info I need in my ED manual....
You could also try the Ford website...
Silver XR
PostPosted: Mon Nov 08, 2004 6:27 pm    Post subject: Reply with quote
Does the premium sound head unit have rca output for a sub or a channel for a sub
dcstraight
PostPosted: Mon Nov 08, 2004 6:43 pm    Post subject: Reply with quote
Alpine make some nice SPS-571A - they're 40 RMS, have a separate crossover network and tweeters...a good plug n play upgrade for AU's IMO.
To answer your second question, Pretty sure there aren't RCA preouts on the AU decks...in saying this, I know someone who may be able to put RCA preouts on it for you icon_wink.gif
Also, if you're leaning towards oval shaped speakers, AU owners have the luxury of fitting 6X9's in their doors with a bit of a baffle for a tight squeeze - I'd recommend Total Recoil 6X9's if you're after some serious 6X9 sounds...otherwise Boston Rallies or Focal make some great 6X9's.
Cheers,
Steve
Silver XR
PostPosted: Mon Nov 08, 2004 7:16 pm    Post subject: Reply with quote
Wats the price on the Apline SPS-571A speakers and where in sydney
Interceptor
PostPosted: Mon Nov 08, 2004 11:06 pm    Post subject: Reply with quote
virtually any 6" that isnt too deep will fit into an AU/BA front door with minimal plywood mounting.....
AFAIK no stock HU has ever come with RCA preouts
Silver XR
PostPosted: Tue Nov 09, 2004 6:16 pm    Post subject: Reply with quote
I was aiming for sum decent bass but without a sub and try without adding an amp as i don't want to take up any space in the ute and to keep the cabin as neat as possible
Silver XR
PostPosted: Sun Nov 14, 2004 4:27 pm    Post subject: Reply with quote
I found the speakers and amp for my ute they are:
Alpine R-series 6x9 SPR-694A
Alpine V-sreies Amp MRP-T220
But i don't know if the 6X9's will be able to go in the back of the ute in the old 5X7 hole?and how they modify the bracket to suit the 6X9's?
Interceptor
PostPosted: Sun Nov 14, 2004 11:39 pm    Post subject: Reply with quote
if all else fails, cut the existing grille out of the way and mount the speakers on the trim itself (screwed into the steel) and it should space them out far enough to fit in the hole
Silver XR
PostPosted: Mon Nov 15, 2004 4:59 pm    Post subject: Reply with quote
I am planning to keep the system hidden so the new 6x9's need to be placed in the same position as the orig 5x7's and i need an idea to hide the new alpine amp?
I have no idea how the 6x9's could go in?
Interceptor
PostPosted: Mon Nov 15, 2004 5:49 pm    Post subject: Reply with quote
see if you can find out how much room is between the rear speakers and the grille that goes over them, maybe theres enough room to space the 6X9's out a bit further so you dont have to cut anything
why not mount the amp under a seat?
Silver XR
PostPosted: Mon Nov 15, 2004 6:10 pm    Post subject: Reply with quote
Thanks for the tips and i'm not sure if the type r's are going to give sum mad bass for the ute?
Silver XR
PostPosted: Thu Nov 18, 2004 6:53 pm    Post subject: Reply with quote
Has anyone had alpine 6x9's as i don't know how good alpine is as i always had pioneer and sony but i'll never go back to sony. and i was told the alpines pump sum decent bass?
Interceptor
PostPosted: Thu Nov 18, 2004 7:44 pm    Post subject: Reply with quote
alpine are pretty good, on par with pioneer with the type R's
Silver XR
PostPosted: Wed Nov 24, 2004 7:38 pm    Post subject: Reply with quote
I have just found wat i am getting and i would like your option:
Pioneer DEH-P7650MP Cd-tunner
Pioneer GM-4000F 4 channel amp
Pioneer TS-D690R 6x9 2 way 330 watt speaker
i think this will sound class in the ute.
Interceptor
PostPosted: Wed Nov 24, 2004 10:28 pm    Post subject: Reply with quote
are you gonna be running 2 pairs of 6X9's, or what are you gonna have in the front?
the system sounds allright so far, tho personally i'd only amp the fronts and spend any $$ saved by going to a 2 channel amp on a better set of splits at the front
Silver XR
PostPosted: Mon Nov 29, 2004 6:49 pm    Post subject: Reply with quote
i'm keeping the factory splits at the front as they are ok for now but if i was going to upgrade i will get alpine 5x7 splits at the front and the amp is just runing the 6x9's.
[46 queries :: 0.04332 seconds ]
