Need some help with Ignition Sensor Config and Types
Waggin
Site Admin
PostPosted: Sat Jan 15, 2005 12:39 am    Post subject: Need some help with Ignition Sensor Config and Types Reply with quote
Hey Guys,
Decided to install and base tune the MoTeC myself in the Waggin, once the Fairmont is back on the road.
I'll be making a plug in harness to plug directly into the existing 104 EEC-V ECU loom, so i can switch between EEC-V and MoTeC while im doing the install, incase anything goes pear shaped icon_biggrin.gif
The setup for the MoTeC is quite extensive, and there are a few settings which im unsure of at this point.. the list will grow icon_smile.gif
The Ref/Sync mode. I'm assuming this is talking about the TFI module output (if running dizzy) or in my case, being an EF, Cam Angle Sensor.
My options are:
0 : 1 Tooth per Firing
1 : 1 Dual Edge
2 : Multi Tooth (More than 1 tooth per firing)
3 : 1 Additional tooth twice per cycle
4 : 1 Additional tooth once per cycle
5 : 1 Missing tooth twice per cycle
6 : 1 Missing tooth once per cycle
7 : 2 Missing teeth twice per cycle
8 : 2 Missing teeth once per cycle
9 : 2 Missing teeth four times per cycle
There is also a 'Custom OEM' option, which says 'Ford BA'. Do they use the same technology? If so, I'm set icon_biggrin.gif
Next up is Crank Ref Teeth. Since I have the wonderful Crank Angle Sensor mounted on the front of my timing cover, I guess option 0 (not used) isn't what I want. How are the teeth set up on the crank?
The MoTeC options are:
REF/SYNC Mode 2
The number of teeth per crank rev
REF/SYNC Modes 3 & 4
The number of teeth excluding the additional tooth.
REF/SYNC Modes 5 & 6
The number of teeth including the missing tooth.
REF/SYNC Modes 7 to 9
The number of teeth including the two missing teeth.
Mmkay, next .. Trigger Edge. Fall or Rise? Or can I use an OEM Spec, such as 'Ford SAW'
I think with that stuff set, I should be able to atleast start the car icon_smile.gif
Waggin
Site Admin
PostPosted: Sat Jan 15, 2005 1:42 am    Post subject: Reply with quote
Okay.. Just thinking aloud and documenting my thoughts here.
Been reading a nice article on the EDIS system (The Ford Coilpack) and I've found that it does use SAW, so I think i've answered my own question regarding the trigger edge.
Quote:
The SAW (Spark Angle Word) is analguous to the SPOUT (Spark OUT) line on Ford TFI-IV systems. The interface is different though.
PostPosted: Mon Jan 17, 2005 8:09 am    Post subject: Reply with quote
Yikes... some scary stuff. Interesting tho.
Well this is my fav doco (after all of FM's of course....):
http://fordfuelinjection.com/files/eectch97.pdf
Instead of regurgitating it all here for you, i'll refer you to page 17 of 27: "EEC ignition and timing control"
Hopefully this helps. Good luck mate.
Waggin
Site Admin
PostPosted: Mon Jan 17, 2005 9:41 am    Post subject: Reply with quote
Thanks martin.. thats a fantastic doco!
PostPosted: Mon Jan 17, 2005 11:17 am    Post subject: Reply with quote
Also another source ive just found. The new love of my life:
[32 queries :: 0.05142 seconds ]
