new cams in, strange idle
mrnasty
PostPosted: Tue Dec 21, 2004 4:14 pm    Post subject: new cams in, strange idle Reply with quote
got my wade 1004-14 cam in, its got a rough as guts idle, mechanic reckons its the computer trying to adjust to the lack on intake manifold vacuum, would resetting the computer help this at all? its fine after a couple of minutes, but its rough before that.
He adjusted the idle screw up a bit, and he seems to think that the computer senses this, then tries to slam the revs back down to much and causes it to stall sometimes. Any ideas?
PostPosted: Tue Dec 21, 2004 4:17 pm    Post subject: Reply with quote
Sounds like pretty good advice from the mechanic. Definately reset the ECU but i doubt this will fix the idling porblem.
Some people have had success by having a unichip fitted and tuned, others have not had any success at all.
uglybob
i've got a stage 2 crow in mine - the idle isn't exactly anything fantastic, and never will be - the computer will need to 'learn' the new cam as such - reset the base idle if you can, let it learn, and then you may have to up the idle screw slightly until you reach a happy medium with the idle - thats what i've had to do with mine. now it doesn't stall at the lights anymore! icon_razz.gif
mrnasty
PostPosted: Tue Dec 21, 2004 4:19 pm    Post subject: Reply with quote
its fine once warmed up a little, but when i first start the car it struggles a bit, it really hunts in the idle
uglybob
PostPosted: Tue Dec 21, 2004 4:21 pm    Post subject: Reply with quote
if the base idle has been reset correctly, then have a go at upping the idle screw until it idles ok - but don't expect it to be anything like it was before! icon_razz.gif
Waggin
Site Admin
dont play with the idle screw unless youre going to reset base idle.
uglybob
PostPosted: Tue Dec 21, 2004 4:38 pm    Post subject: Reply with quote
as in before/after/during? lol me mechanic is scotty (scotts840) so maybe i shouldn't trust dodgy taxi mechanics?! icon_razz.gif hehe nah hes done a good job - we set the base, and as we were playing around, upped it slightly as we were working, to get it right - its running better than it ever has now
Daniel
PostPosted: Tue Dec 21, 2004 4:50 pm    Post subject: Reply with quote
How long have you given it to learn the new cam?
IT can take upto 1000kms in some cases for it to be noticably smoother, altho most will learn it in about 500-800kms.
EFFalcon
PostPosted: Tue Dec 21, 2004 4:59 pm    Post subject: Reply with quote
usually the 114 is perfectly fine idle wise, so my guess is the ECU trying to relearn.
Give it a while and if it doesn't get better then look for problems.
I have a 1004 110 in mine and idle on petrol is useless... but good ol' LPG loves it icon_biggrin.gif
pauli
PostPosted: Tue Dec 21, 2004 5:00 pm    Post subject: Reply with quote
set yah base idle up to about 400 when its cold and then it should jump to 600-700 when its warm.
or learn to two foot it.
neil101
PostPosted: Wed Dec 22, 2004 7:47 am    Post subject: Reply with quote
Don't adjust the base idle you'll give yourself no end of grief (I know trust me been there done that) It will learn how to idle after about 200kms, have you upped the base ignition timming? if so how far? too much can cause it to hunt.
drazull
PostPosted: Wed Dec 22, 2004 11:24 am    Post subject: Reply with quote
Can I ask wether you got the venier timing gear?
ovo616
PostPosted: Wed Dec 22, 2004 1:50 pm    Post subject: Reply with quote
i'm a little slow why shouldn't u adjust the idle?
mrnasty
PostPosted: Wed Dec 22, 2004 4:05 pm    Post subject: Reply with quote
i havnt drivin it all that much since i got the cam so ill give it a bit of time, but no i havnt played with anything. I have reset the ECU, and the mechanic said he upped the idle a little (once warm it sits at bout 6-700 rpm) but didnt wanna take it up any further. Ill give it a few weeks and see how it goes.
mrnasty
PostPosted: Wed Dec 22, 2004 4:06 pm    Post subject: Reply with quote
oh and also I didnt get the timing gear.
SVO XR6
PostPosted: Wed Dec 22, 2004 5:57 pm    Post subject: Reply with quote
Yeah, this is easy takes bout 2 mins.
400kwgtr
PostPosted: Wed Dec 22, 2004 8:01 pm    Post subject: Reply with quote
i thought a lumpy idle was the downside of the bigger cam?
SVO XR6
PostPosted: Thu Dec 23, 2004 1:32 am    Post subject: Reply with quote
mrnasty
PostPosted: Thu Dec 23, 2004 4:37 pm    Post subject: Reply with quote
I dont mind if its lumpy, but i wanna be able to start it in the morning without having to hold it at 1000rpm for 2 minutes before i can let it idle, or put it in gear without it stalling! Gonna clean my idle valve and replace my plugs/leads tomorrow see if that helps it a bit as it was misfiring a little before i got the cam in, as of tomorrow i hopefully will have my P's so it will get a fair bit of driving tomorrow to get the ECU used to the cam if thats the problem.
SVO - XR6, is your car that lumpy that it stalls when cold?
SVO XR6
PostPosted: Thu Dec 23, 2004 5:27 pm    Post subject: Reply with quote
nope thanks to a EMS
[47 queries :: 0.05238 seconds ]
