NEW NUMBER FOR "MIX" GRIND - 1673
Post new topic   Reply to topic    Forum Index -> Wade Cams
Wade Cams
Commercial Sponsor
PostPosted: Wed Jun 06, 2007 11:01 am    Post subject: NEW NUMBER FOR "MIX" GRIND - 1673 Reply with quote
We have issued a new number for the "mix" grind previously referred to as profile no. 1636C977B. The new number is 1673. This profile is only suitable for the EA / EL series 6cyl engine. Please note. This profile will not work in EL engines that have the AU head fitted.
The specifications for the 1673 profile are:
Cam lift - Intake 0.256". Exhaust 0.242".
Advertised duration - Intake 264 degrees. Exhaust 258 degrees.
Duration @ 0.050" - Intake 206 degrees. Exhaust 198 degrees.
Advertised timing - In. opens 19 closes 65. Ex. opens 60 closes 18.
Phase angle - 113 degrees.
Chris
WADE CAMS
MooseMan
PostPosted: Wed Jun 06, 2007 12:15 pm    Post subject: Reply with quote
For someone who doesn't understand the technical specs and such, how would you describe the performance and needs of this cam?
twr7cx
PostPosted: Wed Jun 06, 2007 2:41 pm    Post subject: Reply with quote
http://www.fordmods.com/forums/viewtopic.php?t=46455&highlight=1636c977b
http://www.fordmods.com/forums/viewtopic.php?t=46396&highlight=1636c977b
http://www.fordmods.com/forums/viewtopic.php?t=45770&highlight=1636c977b
Grk 4LTR
PostPosted: Thu Sep 27, 2007 6:38 pm    Post subject: Reply with quote
ive got a 4lt el 1998 model falcon with suspected au head being a march build. i was planning on putting a stall convertor and a cam in and possibly a computer chip if required. just wanted to know whats the best grind you could do for something like 2000-6000 or something along the lines of that?
james88
PostPosted: Sun Oct 28, 2007 4:17 pm    Post subject: cam question Reply with quote
i was wondering what kind of power gain should i expect from adding a wade 1673 cam to my ef xr6 with full exhaust???.
will i gain more power if i upgrade my valve springs?
what power gains have people gained with car simmilar to mine when they added a 1673 cam?
twr7cx
PostPosted: Sun Oct 28, 2007 5:31 pm    Post subject: Reply with quote
How does this compare to the 1636? On the website ( http://www.wadecams.com/ ) it says more power than the 1636, but what about torque, which is a better grind for the low down pull? It says more torque than the 977B, so am I to assume the power band for this grind is inbetweern the 1636 and 977B?
james88
PostPosted: Mon Oct 29, 2007 11:24 am    Post subject: cam Reply with quote
does anyone know what the power band is for the 1673 cam is???
Wade Cams
Commercial Sponsor
PostPosted: Mon Oct 29, 2007 2:55 pm    Post subject: Reply with quote
Forum member "Grechie" has been using the 1673 for a while. He should be able to give you some reliable information on how it goes.
grub73
PostPosted: Wed Oct 31, 2007 12:34 pm    Post subject: Reply with quote
I've got this cam in my xr6 and man does it haul a**. Pulled 154kw at wheels at MK automotive in Seaford. Really starts pulling from about 3000rpm, but I've had heaps done to the motor so i don't know how a standard motor will react, still had heaps of fuel according to dyno sheet(afr was around 12 at peak power) Good work guys, a BIG thumbs up icon_twisted.gif icon_twisted.gif
Grechie
PostPosted: Wed Oct 31, 2007 9:25 pm    Post subject: Reply with quote
Big thumbs up to this cam,
I had 155rwkw with a 1636, i added this cam, still had 155, but i was leaning out now. IE the 977b half of the cam was asking for more juice.,
Fixed the fuel issue and no tune got me 174 rwkw with no filter on TB!
But same as grub73, my engine isnt a 4L standard. the bottom end has got the works internally.
stoj79
PostPosted: Wed Oct 31, 2007 11:28 pm    Post subject: Reply with quote
just fitted the 1673 today not a huge increase in power or torque coudl the timing need to be advanced and how much if so shes got the dizzy its an el ?????
bArNsY
PostPosted: Thu Nov 01, 2007 6:01 pm    Post subject: Reply with quote
I would also like to know this, I am also running verneir gears, will that need to be advanced or retarded?
Barnsy
Wade Cams
Commercial Sponsor
PostPosted: Fri Nov 02, 2007 1:08 pm    Post subject: Reply with quote
Barnsy
Whilst most of our cams are intented to be installed "straight up", you
could, if desired, RETARD the cam up to 2 degrees, but no more.
bArNsY
PostPosted: Fri Nov 02, 2007 6:56 pm    Post subject: Reply with quote
thanks for that, I spoke to scotty who spoke to Keith and said the same thing
akademiks
PostPosted: Wed Nov 28, 2007 8:35 am    Post subject: Reply with quote
this cam does work on automatics BJSPENCER85 has got it working in his AU motor in an auto.
i think its something similar to a 1673 profile ground onto an au cam..
either that or an eseries cam and he is still running e series head but i am unsure.
anyway point being his car is auto and it runs fine when its warmed up. however on cold nigths when the car is cold it idles like a pig until it warms up.
[42 queries :: 0.048 seconds ]
