Waggin Site Admin
Posted: Tue Mar 06, 2007 10:21 pm Post subject: |
| Send him a PM. Its hard to keep a watch on every topic. |
lukey39 Fordmods Newbie
Posts: 18 Joined: 06 Aug 2006 Location: Brisbane QLD, Australia
Posted: Mon Mar 19, 2007 9:07 pm Post subject: |
| Good stuff with the tec doc on the smartlock bypass but there is only one problem,This bypass design works very well and easy to do but on the down side is the the relay in the smartlock can also fail as well.The only way around this it to generate a signal to fool the PCM but this is alot harder.Never the less thumbs up. |
EBGizmo Technical Contributor
Posts: 691 Joined: 01 Jun 2005 Location: Brisbane QLD, Australia
Posted: Thu Apr 12, 2007 5:29 pm Post subject: |
You mean the relay in the BEM that stops it cranking?
If so, you would just wire up the ignition crank wire directly to the starter relay positive. No need to generate any codes. |
