NF Fairlane ghia interior into EA, will it fit???
EA_FANATIC
PostPosted: Thu Jul 24, 2008 10:20 pm    Post subject: NF Fairlane ghia interior into EA, will it fit??? Reply with quote
Will the NF Fairlane interior ie: front and rear seats, fit into a EB falcon?? I already know about the rear bolsters are bigger than the falcons but is everything else just a straight swap? ...... Ive looked on previous post and there is no definete answer on this. So any help is really appreciated.
Please only people that definetly know about this mod reply
BenJ
PostPosted: Fri Jul 25, 2008 12:03 am    Post subject: Reply with quote
Hi
The front seat rails need to be modded as the floor pans are different. You will need to cut and shut one of the legs, and weld an adaptor plate on another.
Not too difficult if you can weld, but really hard if you can't LOL.
The rear seat base is a direct fit as are the seat backs.
BenJ
EA_FANATIC
PostPosted: Fri Jul 25, 2008 5:55 pm    Post subject: Reply with quote
Thanks for that sounds pretty straight forward............I hope LOL icon_lol.gif
PIMP_LTD
PostPosted: Fri Jul 25, 2008 5:57 pm    Post subject: Reply with quote
View a couple of the EA-ED threads in the garage. Alot of them including BENJ and I have recently done this. There is detailed pitcures and explanations etc.
Also look in the tech doc section, there is a full writeup somewhere by BUNTER on doing this. icon_smile.gif
Andrew
EA_FANATIC
PostPosted: Fri Jul 25, 2008 7:09 pm    Post subject: Reply with quote
Thanks for the tip but was after changing seats out of a fairLANE not fairMONT into me EA.........
PIMP_LTD
PostPosted: Fri Jul 25, 2008 7:25 pm    Post subject: Reply with quote
ringastinga
PostPosted: Fri Jul 25, 2008 7:30 pm    Post subject: Reply with quote
has anyone actuall welded the floor brackets instead of choppin the rails if so any pics i had a search but didnt find anything... i need to know because i'm doing the whole interior conversion and want the carpet to fit look good
PIMP_LTD
PostPosted: Fri Jul 25, 2008 7:34 pm    Post subject: Reply with quote
If you carefully cut out the rear inside floor bracket, or make a new one, you can certainly weld that to the floor so the seat sits on it, it would be easier to make a new bracket.
xbgt2dr
PostPosted: Fri Jul 25, 2008 7:49 pm    Post subject: Reply with quote
knowsfords used 20cm gal pipe cut to 85cm and a hi tensile bolt,and slotted out the front bolt holes and the seats fitted in perfectly,no welding and he used the ef carpet!!icon_smile.gif
PIMP_LTD
PostPosted: Fri Jul 25, 2008 7:57 pm    Post subject: Reply with quote
I did the same thing, and i also have the EF carpet.
ringastinga
PostPosted: Fri Jul 25, 2008 8:11 pm    Post subject: Reply with quote
any pics?
PIMP_LTD
PostPosted: Sat Jul 26, 2008 1:12 pm    Post subject: Reply with quote
Of the finished product or the actualing modding of it?
I don't have either, but i can take some finished product photos if needed.
ringastinga
PostPosted: Sat Jul 26, 2008 7:29 pm    Post subject: Reply with quote
nah of modding it... even a drawing so i can understand coz that sounds way easier
PIMP_LTD
PostPosted: Sat Jul 26, 2008 7:43 pm    Post subject: Reply with quote
Here is a s**t drawing of what is needed to do to the front brackets. The holes need to be die ground, or filed to the inside.
You may have to go quite far, i reccomend if you get to close to the edge to weld on a new washer or something.
PIMP_LTD
PostPosted: Sat Jul 26, 2008 8:08 pm    Post subject: Reply with quote
This is looking at the inside of the seats.
The back mount on the inside of the EF seat is higher. it requires 87mm of spacing. I used 76mm long peice of steel tube with a 10mm id, and welded on some 5mm thick flat washers on either end, to give it some seating.
The outside brackets lined up no problems.
This will apply to your application. Hope you understand my s**t drawings, and hope this helps.
Andrew
ringastinga
PostPosted: Sat Jul 26, 2008 8:10 pm    Post subject: Reply with quote
f**k legend andrew i call this as a sticky lol....
i totaly understand now but did u just use long bolts to bolt it down?
PIMP_LTD
PostPosted: Sat Jul 26, 2008 8:17 pm    Post subject: Reply with quote
YES, i used a 100mm high tensile bolt. Make sure it is a high tensile, otherwise it could break due to the different height.
knowsfords
PostPosted: Sat Jul 26, 2008 8:19 pm    Post subject: Reply with quote
Yep, any nut and bolt supplier should have something there I just used 11cm long hardened bolts I think the thread size was 11mm or something they should be able to match it... match the bit at the head of the bolt as the bolts are tapered.
EDIT: what pimp said :p
easpak91
PostPosted: Sat Jul 26, 2008 9:52 pm    Post subject: Reply with quote
Thanks for that PIMP_LTD it explains it nicely i just bought an interior off ghia97......... http://www.fordmods.com/forums/post859388.html#859388 and will be attempting this myself in the not to far distant future and by the way your drawing is A1.. All i need now is some sh#tty EA bolsters
rogan
PostPosted: Sun Jul 27, 2008 7:33 pm    Post subject: Reply with quote
love the work PIMP_LTD, just one question: legal? dont get me wrong, not too worried about car being roadworthy, but to best of my knowledge, any seat mods have to be engineered, could be a problem if someone is looking at doing this mod to an unregistered car.
[47 queries :: 0.2033 seconds ]
