NFGhia Fordmods Tyre Shredder
Age:42 Posts: 370 Joined: 22 May 2005 Location: Melbourne VIC, Australia
Posted: Tue Feb 07, 2006 10:45 pm Post subject: NFghia's supercharged 347 project |
Well I've had the Fairlane for nearly 6yrs and I was looking at upgrading to a BA fairmont, fairlane maybe XR8.
But if I do that then I'm back at square one with the mods and no cash left.
So I've decided to give the lane a bit of a going over
I picked up a spare donk a few months ago and have been tossing up on
which way to go with the mods. First up I want to make as much torque as possible so forced induction of some kind is the way. And of course there is no substitute for cubic inches.
I'm not after a high rever but want to be able to haul the big a** fairlane around a bit easier which means more punch from low down.
So last week I picked up a stroker kit.
Scat 9000 series 347 crank.
Scat 4340 I beam rods.
And SpeedPro Hyperutectic slugs.
Hmmmmmmmm Stroker.
So thats the bottom end sorted.
I ruled out twin turbos due to heat, lag, and the space.
It was down to what type of S/C, centrifical (Paxton, Vortex) which are pretty easy to bolt up, but with kits at $6500 (Pfffffttttt) all I need is S/C unit and I'll fabricate my own bolt up bits. Roots type blowers (Eaton, Whipple) make great boost down low (around 70% at 1800rpm) so thats the type I decided to go for. PLUS you don't see many roots type blowers bolted onto Windsors.
Seeing as I intend to fabricate my own induction system the hunt was on for a cheap S/C, I was looking at an Eaton M90 which are pretty easy to get under $1k, but they rate them 4.0 to 5.7ltr would probably do as the engine won't see over 5k much, of course the preferred would be the M112.
Today I put a bid in on a S/C that came off a Ford Lightning 5.4 (US car) basically an Eaton M112 made for Production Fords, well bugger me!!! I won it for US$455 form a Canadian Ehh. with shipping I'm guesstimating around Aus$800.
This should look pretty sweet if I can squeeze it all under the bonnet. (Think I'll have to do the BA bulge with the respray)
Now it's time to find a nice pair of alloy heads and valve train.
Also she'll be breathing LPG and at this stage I think I'll go with a GRA setup.
So there ya have it so far, any comments, suggestions or otherwise are welcome as half the crazy ideas I've got have come from reading through the froums here..
Disco Frank Fordmods Junkie
Age:29 Posts: 12787 Joined: 05 Nov 2004 Location: Perth WA, Australia
Posted: Tue Feb 07, 2006 11:30 pm Post subject: |
f**k yer mate!
thats awesome
torque about torque!
XR9UTE EFI Guru
Age:43 Posts: 1328 Joined: 05 Nov 2004 Location: Perth WA, Australia
Posted: Wed Feb 08, 2006 12:16 am Post subject: |
BTW it fits under the bonnet of his ED. I think you may be slightly better with your NF as I think the bonnet bulges up a little more than the earlier falcons and 'Lanes?
I believe initial runs netted 335kw with 10psi and of course stupid amounts of torque. His goal is 16psi but I think belt slippage is becoming a problem with the stock 6-rib.
He's running 42's, 90mm Lightning MAF, 90mm t-body and TwEECer on a 3DEA EEC.
http://norcom.net.au/~bpt/Picture%20001.jpg
Pete.
MooseMan Fordmods - Getting Side Ways
Age:20 Posts: 2229 Joined: 03 Dec 2004 Location: Melbourne VIC, Australia
Posted: Wed Feb 08, 2006 1:03 pm Post subject: |
Wow its really good to see someone getting out there and doing this stuff because alot of people (me included) just talk about doing it without any real chances of ever getting it done.
Good work and good luck.
Waggin Site Admin
Age:25 Posts: 6378 Joined: 18 Dec 2002 Location: Sydney NSW, Australia
Posted: Wed Feb 08, 2006 2:33 pm Post subject: |
| I hope you're not sticking with the stock 302W block. Im going an N/A 347 setup and am nervous about splitting the block. With a blower ontop of that, you should be looking at the Dart block!!!
Posted: Wed Feb 08, 2006 2:45 pm Post subject: |
Hmmmm I'm pretty sure I won't fit the one I got where they have theirs..
But I'm thinking it might fit on the side under the alternator where the idler pulley is now.. If not on the side then a custom or modified lower inlet and bang it on top down the middle...
I know there's a bloody great dizzy in the way.
Seeing as I'll use my MegaSquirt to power it I might get rid of the dizzy and use coil packs for spark. Take a look at some of what this guy has done
http://www.toohighpsi.com/coolers/jimproject2.htm
After dooling over that go back to the home page http://www.toohighpsi.com/index.htm and check out the Twin Supercharged T-bird...
Looking at how they went about doing their cars I thought that doesn't look too hard But I have access to a mill and lathe at work so I'm sure it'll be a bit of trial and error, probably more error
But first I have to get my double garage up so I've got some where to do this crazy s**t..
Posted: Wed Feb 08, 2006 3:12 pm Post subject: |
| Waggin wrote: | | I hope you're not sticking with the stock 302W block. Im going an N/A 347 setup and am nervous about splitting the block. With a blower ontop of that, you should be looking at the Dart block!!! |
Well I was thinking bout it but I'll be happy to get around 300Kw with about 10psi boost or less and seeing as I'm not looking for big revs I'm hoping she'll hold together
All I'd like is to have that 'pushed into the back of the seat' feeling I used to get out of my 351clevo XB when the secondaries opened up.. Hmmmmm Torque as DiscoFrank says..
Plus if it does detonate I'll have the donk thats in it now as a spare while I organize a better block. Hehe
351EL Fordmods Stock as a Rock
Age:37 Posts: 144 Joined: 07 Jan 2006 Location: Innisfail QLD, Australia
Posted: Wed Feb 08, 2006 3:33 pm Post subject: |
[quote="XR9UTE"]Sounds good,
Although the '03 Cobra M112 may have been a better choice due to it's side entry for the throttle body...depends on bonnet clearance I guess.
If you change to a cobra blower I have a f150 it would look good on.
Age:22 Posts: 4728 Joined: 15 Nov 2004 Location: Perth WA, Australia
Posted: Wed Feb 08, 2006 4:23 pm Post subject: |
NFGhia sounds wicked mate keep everyone posted with progress pics and a vid of the final outcome would be sweet 347 and blown sounds unreal good luck
Waggin Site Admin
Posted: Wed Feb 08, 2006 4:26 pm Post subject: |
300KW is getting pretty close to the limit and you should almost be able to reach that without the blower
Steady ED Fordmods Addict
Age:22 Posts: 6627 Joined: 01 Jun 2005 Location: Melbourne VIC, Australia
Posted: Wed Feb 08, 2006 4:39 pm Post subject: |
| Waggin wrote: | | 300KW is getting pretty close to the limit |
Well, if it all goes to s**t, at least Fordmods will be able to start it's photo collection of split Windsor blocks!
Seriously though, this looks like one hell of a project, and I'll be watching with much interest.
Age:25 Posts: 3377 Joined: 11 Nov 2004 Location: townsville QLD, Australia
Posted: Wed Feb 08, 2006 6:50 pm Post subject: |
Is there any reason apart from the extra 17cubes that you went for the 347cui over the 330cui stroker???
the 347s have some big drawbacks, like the poor stroke/rod ratio.
and the piston pin sitting high up in the oil ring..
with a 330 and the blower you'd still easy make the power you wanted.
XR9UTE EFI Guru
Posted: Wed Feb 08, 2006 7:15 pm Post subject: |
| tickford_6 wrote: | Is there any reason apart from the extra 17cubes that you went for the 347cui over the 330cui stroker???
with a 330 and the blower you'd still easy make the power you wanted. |
This is so true....I suppose the displacement is just too hard to resist?
Anyway NF has what he has....
I don't think you'll fit the M112 down under the ALT, Ive already sized that up on my 351 with the Cobra M112..No go. Even the M90 is tight and you'd need a custom short drive snout on it like the old BBK instacharger kit.
In the guts of the intake is likely the best shot but it'll have to sit high because the 5.0 is so narrow. I'm currently working on an intake for my 351...as it is I'll have to change the injector angle to a practically a vertical position to fit the width of the M112 case in there. The idea is of course to keep it low enough so I don't need to go through the bonnet.
You can roughly see in this shot with the M90 on top of the 351 that it is already a hard ask(injectors won't fit with the rail on) and the M90 does not have the big flange of the M112 either.
You may be able to go higher because you have 3" up your sleeve compared to the 351 height. In this case you may be able to squeeze the stock rail and injector angle underneath?
Pete.
Posted: Wed Feb 08, 2006 8:23 pm Post subject: |
Basically I got the 347 kit cause it was offered to me for $1200 so that sorted that out.
And your setups looking pretty good there XR9UTE.
I'm thinking thats where mines gonna end up, the plus for me fitting it under the bonnet is the injection system is getting ripped out and it'll be going on straight LPG. So with a dizzy setup like yours and if I get a low profile carby inlet I think I can shoehorn it under.
I guess last resort is to totally frabricate a new manifold.
Posted: Wed Feb 08, 2006 8:28 pm Post subject: |
| NFGhia wrote: | | tickford_6 wrote: | Is there any reason apart from the extra 17cubes that you went for the 347cui over the 330cui stroker???
I guess last resort is to totally frabricate a new manifold.  |
dude thats good enough for me
ef302 Fordmods - Getting Side Ways
Age:28 Posts: 503 Joined: 11 Nov 2004 Location: Melbourne VIC, Australia
Posted: Thu Feb 09, 2006 2:15 pm Post subject: |
| Out of interest XR9ute... has the motor in your pic been on fire??? Some interesting discolouration around the rocker covers... Everything else seems so nice and shiney new!!
XR9UTE EFI Guru
Posted: Sat Feb 11, 2006 2:36 pm Post subject: |
Nope, no fire....it's just the way it was when I bought it....
The rest of it is not shiny and new either(except the timing cover/water pump which came off a brand new AU 5.0 Crate engine)
That pic was when I just dummied up the whole deal in the bay.
It looks more like this now with the exception of the MAF and inlet tube and that poxy coil bracket.
Pete.
Posted: Sun Feb 12, 2006 11:55 pm Post subject: |
| Looks good Pete... I see you'v sorted the radiator hoses the way V8's should be....
[49 queries :: 0.09268 seconds ]
