NL fairlane wake up
nudge22
PostPosted: Thu May 03, 2007 9:41 pm    Post subject: NL fairlane wake up Reply with quote
Hi guys ive been reading your forums to get some ideas of which way to go but i havnt had much luck so sorry if i sound repetative. I have an NL Fairlane which i would be happy to get into the high 14s. I would like to keep it fairley drivably (ie avoid extremly lumpy cams)I was going to start with Pacemakers,AU afm and 3.45 diff. I dont want to buy the extractors if i have to change the heads any info on which way to go would be appreciated
Shum's EL
PostPosted: Thu May 03, 2007 10:12 pm    Post subject: Reply with quote
there are plenty of brands of extractors you can get for your can and you DONT have to change your head for extractors
XH5LWEPN
PostPosted: Thu May 03, 2007 10:33 pm    Post subject: Re: NL fairlane wake up Reply with quote
A nice fairly cheap combo to get a big NL Fairlane moving would be to get it pretty much the same as an AU 200kw engine.
For starters get rid of those horrible factory exhaust manifolds for a set of pacemakers, and follow up with just a press bent 3" single exhaust with muffler and resonator if ya wanna keep it cheap. Mate got this done on his NL 5.0L for $350 which isnt bad. If ya wanna spend more go for a mandrel bent 2 1/4" twin system with decent mufflers.
Then i'd go for an Explorer inlet manifold swap (these are the manifolds off the EL series 2's and all AU 5.0's). This along with a 65mm t/b will do and will be fairly cheap (well under a grand).
Decent flowing air filter can help a little aswell, give it a decent service and check timing, clean maf, check TPS voltage etc all the usual things that wont have ya diggin in ya pocket.
A set of 3.45's would be nice, but if i was you i'd go for 3.73's, you'll definately be able to notice more of a difference than just going to the 3.45's especially with the weight of the car.
From there it all starts gettin expensive, How much you looking at spending?
One Drone
PostPosted: Thu May 03, 2007 11:51 pm    Post subject: Reply with quote
I have pretty much the same car. Extractors. Underdrive Pulleys. 1.72 Roller Rockers. 3.45 or preferably higher ratio, shift kit and as long as she is pretty well maintained. That'll be about all you'll need.
Daniel
PostPosted: Fri May 04, 2007 12:33 am    Post subject: Reply with quote
How well does she go with the mods Mr Drone?
nudge22
PostPosted: Fri May 04, 2007 7:31 am    Post subject: Reply with quote
Money isnt really an issue i use the car daily thats the reason why i want to keep it drivable. will i get the power i need out of the standard heads? I did consider a 220kw transplant but after reading your forums i think torque is probably the answer. Maybe stroker or super charger?
nudge22
PostPosted: Fri May 04, 2007 7:42 am    Post subject: Reply with quote
Mr drone that was the way i was heading but i wasnt sure if that would be enough to get the big girl down the quarter in under 15s
One Drone
PostPosted: Fri May 04, 2007 10:24 am    Post subject: Reply with quote
Do the intake as well. Then it should be enough. Depends on how tired your engine is.
kato
PostPosted: Fri May 04, 2007 10:54 am    Post subject: Reply with quote
I'd go with underdrive pulley's, headers/exhaust , and a diff ratio change, at least 3.7's, biggest challenge with a decent 1/4 mile time is getting the car moving (60ft time) diff gears will help this alot especially a big car like the fairlane.
nudge22
PostPosted: Fri May 04, 2007 2:54 pm    Post subject: Reply with quote
Sounds good do the undersized pulley play havoc with the p/s water pump alt or a/c ? So headers, pulleys, rockers, intake, afm and 3.7s should hopefully get me into the 14s. Is anyone running 3.7s with the four speed auto how does it drive on the highway?
falcon gl
PostPosted: Fri May 04, 2007 3:29 pm    Post subject: Reply with quote
i think there is a calc in tech docs that knows how much your car would rev at 100km
falcon gl
PostPosted: Fri May 04, 2007 3:32 pm    Post subject: hay i found it Reply with quote
it was on my desk top
 Description:
 Filesize:  32.39 KB
 Viewed:  11 Time(s)
XH5LWEPN
PostPosted: Fri May 04, 2007 8:39 pm    Post subject: Reply with quote
Underdrives will effect the alternator charge, that is if you go with the 3 pulley kit (BPT Race), alternator will not charge enough at idle but once over about 1000rpm the charge comes up to where it should be at bout 13.8v. As far as the water pump goes, as long as your radiator and rest of cooling system is in pretty good condition internally you will be alright, i havent really noticed a difference in water temp with mine so far, although it hasnt been driven in about a month.
I think if your gonna do all the above mods i would be paying to get a twEECer fitted and a custom tune, especially if your increasing the size of the MAF housing and going to the explorer manifold. It will help get the most out of the mods and ensure it is running a good state of tune.
I would def go for the 3.7's mate, i was running them in my 4.0L auto XH with cam etc, and absolutely loved em. Best thing to do to an auto falcon IMO. As far as highway driving goes, obviously it will rev higher at 100k's etc but 3.7's dont feel too bad as far as comfort goes. I've been in autos with 4.11's etc and sittin at 100k's just feels like s**t, constantly waitin for the next gear.
I know you said money isnt an issue, but give us a rough idea on how much you wanna spend and that will make it much easier to work out the best combo for ya.
nudge22
PostPosted: Sun May 06, 2007 9:10 pm    Post subject: Reply with quote
The limiting factor isnt the money but i want to keep it drivable. Obviously the more it cost the longer it will take to do. What i was after is a combo that works so im not changing things twice like extractors exhaust heads and so on. If I can get the power from bolt ons thats the way i will go if I have to stroke it then thats what i will do. Basically the car looks the part it would be nice if it was competative to.
XH5LWEPN
PostPosted: Sun May 06, 2007 10:32 pm    Post subject: Reply with quote
In that case then i would go for something like this,
AFR 165 alloy heads - $2650
Y/T Stealth rockers 1.6 Adj - $600
Crane 2020 cam - $400
Explorer Manifold (also port match lower) - $500 + $300 for porting
65-70mm T/B - $300
Pacemaker PH4000 - $900 fitted
BPT Underdrives - $280
Rollmaster Timing chain - $130
Gaskets - $300
TwEECer + tune - $1500
All that plus labour which you'd probly be looking at bout $800-1000 i'd say, unless you can do the work yourself. The above cam is fairly mild, plenty of choice as far as cams go, you could probly even just go for the crow 220kw cam.
All the above should bring you pretty damn close to consistent low 14's with the diff gear change and even better with a decent high stall.
Or you could go for a bit more cash and just stroke it, i was going to do that but my budget couldnt stretch that far, i only had about 8500 for the engine, a decent stroker (347) with alloy heads was puttin me up to about $12500.
nudge22
PostPosted: Sun May 06, 2007 11:03 pm    Post subject: Reply with quote
Sounds good guys i will keep use updated as i go
Thanks
el-ghia
PostPosted: Fri May 09, 2008 9:22 pm    Post subject: Exhaust For NL Fairlane Reply with quote
anyone got a stock exhuast for a nl fairlane
need it urgent
ge2589
PostPosted: Fri May 09, 2008 10:13 pm    Post subject: Reply with quote
mate i have spent under a grand on my nl and it will be doin over 300 kws all i got was the cam from crow ecu springs and supercharger from a toyota supra it hasn't gone in yet but everyone rekons that it will doin most of the 8s around the place
fnp
PostPosted: Sat May 10, 2008 12:42 am    Post subject: Reply with quote
You got a cam, valve springs, tuned ecu and a supercharger setup for <$1000? And it makes over 300kw on standard heads and exhaust..?
wtf
ge2589
PostPosted: Sat May 10, 2008 1:00 am    Post subject: Reply with quote
its all bout retro fitting mate all i did was follow the instructions of the street fords stright six mod guide im not saying that it will do 300 but it will be pretty close too well think bout it custom grind cam xr6 turbo valve springs a head gasket and blower with the right pulley it would be easy to get in the high 200s low 3s
[49 queries :: 0.07478 seconds ]
