No Heating, HELP!!!
samir__a
PostPosted: Tue Jul 22, 2008 4:36 am    Post subject: No Heating, HELP!!! Reply with quote
Hi all, i bought my car a few months ago at an auction and just noticed the heating doesnt work. The cool A/C worked fine in summer but now that its winter i turned the nob of my ba xr6t the red reigon and it did nothing only cool air came out. I have tried all settings, still nothing, just cool air, so i leave it off. HELP PLEASE??? icon_cry.gif
stalker
PostPosted: Tue Jul 22, 2008 6:44 am    Post subject: Reply with quote
mines the same in the ED, its meant to be some part shat its self i cant be bothered replacing it as its under the dash...
sunbury23
PostPosted: Tue Jul 22, 2008 7:24 am    Post subject: Reply with quote
i had a prob like this in my EF, the thermostat had s**t itself.
Sierra
PostPosted: Tue Jul 22, 2008 7:41 am    Post subject: Reply with quote
There are a few things you can check.
Check the thermostat to ensure it is not stuck open and not allowing the engine to reach normal operating temperature.
Have a look in the engine bay to see if the hot water valve on the heater core inlet side is opening and closing as you change the heater control position from blue to red.
If the valve doesnt move then there is a fault either in the valve or the actuating system.
If the valve is operating as normaly then check the temperature of the inlet and outlet hoses to the heater core with the engine at operating temperature .... are they hot or cold?
If they are cold then for some reason water is not flowing.
Check and flush the cooling system to make sure there are no blockages etc.
I just had the same problem on my EF .... no hot water getting to the heater core caused by a broken thermostat (stuck open) and semi blocked cooling system.
All fixed by replacing thermostat and a good flush of the cooling system.
fnp
PostPosted: Tue Jul 22, 2008 9:42 am    Post subject: Reply with quote
Most likely in the BA the air mix shaft has broken. Pretty common on them.
ringastinga
PostPosted: Thu Jul 24, 2008 7:10 pm    Post subject: Reply with quote
heater tap?
ttickfordbetty
PostPosted: Sun Jul 27, 2008 8:37 am    Post subject: Reply with quote
if its the thermostat,the fans wouldnt come on ? if was broken ?
vaughan romano
PostPosted: Mon Jul 28, 2008 4:53 am    Post subject: Reply with quote
my ba xr8 has the same problem i was told the air mix shaft was brocken
EA90GHIA
PostPosted: Tue Jul 29, 2008 1:38 am    Post subject: Reply with quote
Thx for posting this i have the same problem sorta, im getting heating but just warmish hot if i leave the fan on low speed. ill see what happens.
sunbury23
PostPosted: Fri Aug 01, 2008 11:10 am    Post subject: Reply with quote
all i know with my wagon they didn't come on because the thermostat was letting the water circulate around the engine so it wouldn't heat up so there was no reason for the fans to come on.
Cheers.
[37 queries :: 0.04288 seconds ]
