japa62 Fordmods Parts Gopher Donating Member
Age:45 Posts: 95 Joined: 05 Nov 2004 Location: Redcliffe QLD, Australia
Posted: Fri Jan 07, 2005 7:00 pm Post subject: nolathane |
| Now that the low's are in I need to replace the bushes etc. Can anyone recommend a decent deal on a nolathane or simular kit for the front end? I already have the powersteering bush's just need the rest. |
eb2fairmont Fordmods - Getting Side Ways
Age:32 Posts: 958 Joined: 14 Nov 2004 Location: Adelaide SA, Australia
Posted: Mon Jan 10, 2005 1:59 pm Post subject: |
For the front and rear nolthane kit you're looking at around $500 supplied from coventries (mototraders here in SA).
It's a piece of piss to install if you got the time, the backend stuff needs a press to do it.
Cheers,
David |
Posted: Mon Jan 10, 2005 6:38 pm Post subject: |
| eb2fairmont wrote: | For the front and rear nolthane kit you're looking at around $500 supplied from coventries (mototraders here in SA).
Cheers,
David |
Thanx's David. Which bush need the press?? One of the Trailing arms ?? |
smoke_ Cruise Moderator
Age:24 Posts: 5801 Joined: 05 Nov 2004 Location: Brisbane QLD, Australia
Posted: Wed Jan 12, 2005 6:50 pm Post subject: |
both of the trailing arms need them.
how many bushes are in the front, besides the swaybar bushes? |
Disco Frank Fordmods Junkie
Age:29 Posts: 13062 Joined: 05 Nov 2004 Location: Perth WA, Australia
Posted: Wed Jan 12, 2005 9:11 pm Post subject: |
| smoke_rubber wrote: | both of the trailing arms need them.
how many bushes are in the front, besides the swaybar bushes? | basically u have10 sway bar bussehs ( 4 eash side for the link arm) then the body ones)
ther are also the wishbone bushes but they would need a press as well |
400kwgtr Fordmods Oompa Loompa
Posts: 23 Joined: 14 Dec 2004 Location: sydney NSW, Australia
Posted: Thu Jan 13, 2005 2:56 pm Post subject: |
| i nolathaned my ford a few months back, very worthwhile. |
EF 4.9 Fordmods Stock as a Rock
Posts: 139 Joined: 08 Nov 2004 Location: Meeka, Coonland WA, Australia
Posted: Thu Jan 13, 2005 5:25 pm Post subject: |
A press would be recomended for the lower wishbone bushes. I managed to do mine without a press. but for all the effort, its much easier to take them to a machine shop and have the old ones pressed out and new ones pressed in.
If you'r feeling lucky you can use 1/2 inch threaded rod, a bigassed locknut socket, 3nuts and a washer slightly smaller than the steel bush shell. But its not easy. |
Posted: Thu Jan 13, 2005 9:35 pm Post subject: |
| i'd just take it to my work, 3 different presses lol, and plenty of machined bits and pieces of different sizes. |
[35 queries :: 0.03401 seconds ]
