NOS wiring Question with diag's
TerroristGHIA
PostPosted: Tue Jun 03, 2008 11:21 am    Post subject: NOS wiring Question with diag's Reply with quote
Ok guys, I am at a quandry. I have mucked up the wiring for my 8860 using the NOS function. It is currently on circuit 1 of the outputs. I have a diagram of the NOS wiring, but need to delete the microswitch as the 8860 will use the TPS reading to activate the solenoids.
Attached is the NOS setup instructions, and the wiring diagram is on page 13.
I now have the EMS wiring diagram for the NOS.
Now i will admit i am an idiot when it comes to wiring so could someone please explain how the relays work and how to get then 2 wiring diagrams to become one, or even "draw a diagram for me.
Brett
EMS NOS activation setup.pdf
 Description:
EMS diagram
Download
 Filename:  EMS NOS activation setup.pdf
 Filesize:  6.41 KB
 Downloaded:  19 Time(s)
NOS Kit.pdf
 Description:
page 13
Download
 Filename:  NOS Kit.pdf
 Filesize:  1.43 MB
 Downloaded:  28 Time(s)
NFGhia
PostPosted: Tue Jun 03, 2008 8:04 pm    Post subject: Reply with quote
It looks to be pretty simple.
Your EMS switches the output low to activate the relay so just connect the output to the Green wire on the NOS relay instead of going to ground.
And the input to the EMS goes straight to the Blue wire.
Now you can still fit the microswitch, then the NOS will only activate when the switch is triggered and the EMS triggered. A bit of a double backup.
Or just leave it out and run a wire direct to the NOS relay..
I'm sure if I got it wrong then someone here will point it out pretty quickly. icon_lol.gif
Here's a pic to help..
 Description:
NOS wiring.
 Filesize:  97.64 KB
 Viewed:  11 Time(s)
DA22LE
PostPosted: Tue Jun 03, 2008 8:52 pm    Post subject: Reply with quote
That NOS diagram is the same one for the stinger(not surprising really) Like NF said just follow the ems diagram, and i would add the extra switch for safety sake. You dont want to be wasting shots that's for sure. Get a toggle switch with the rocket cover, look the goods if nothing else.
The ems switch the relays by grounding, same as the injectors. It is pretty easy, you have to have power switched on by the ignition switch, the ecu does the rest. I have to connect up the bbm for my set-up, much the same job. I could help you out if you get really stuck, or desperate....
TerroristGHIA
PostPosted: Tue Jun 03, 2008 10:23 pm    Post subject: Reply with quote
Thanks guys much appreciated. Will get onto it tomorrow morning. Then tuning friday.
I really wish i new more about wiring. Need to get some books
Brett
TerroristGHIA
PostPosted: Wed Jun 04, 2008 6:30 pm    Post subject: Reply with quote
Guys, thanks for that. I was going to re wire the system today, but it was already wired. When i changed the system i cut 4 wires that lead to the solenoids and didnt mark them as to what did what. The diagram you guys provided allowed me to repair my previous install and it all works now. I have test fired it with no NOS hooked up and the engine off, and both solonoids are now firing as they should be. I will not test it until the tune is complete and correct.
Come friday i will have some more pics and photo's after the tune.
Again thanks heaps
DA22LE
PostPosted: Wed Jun 04, 2008 8:08 pm    Post subject: Reply with quote
See........your not so useless after all.........lol....who's doing your tuning??
Daz
TerroristGHIA
PostPosted: Wed Jun 04, 2008 10:04 pm    Post subject: Reply with quote
Joe at Crescent of course.
Brett
DA22LE
PostPosted: Thu Jun 05, 2008 6:03 pm    Post subject: []: Reply with quote
Brett
Have you got an estimate of how long it will take, and what it will cost??
I'm only asking as i am having mine done at Hillsmotorsports next wednesday, as they are close by.
Daz
TerroristGHIA
PostPosted: Thu Jun 05, 2008 6:28 pm    Post subject: Reply with quote
I have no idea on cost or time. Will no by the afternoon.
Brett
[38 queries :: 0.05669 seconds ]
