OIL once and for all
Goto page 1, 2, 3, 4, 5, 6  Next
tickford_6
PostPosted: Sat Apr 29, 2006 1:06 pm    Post subject: OIL once and for all Reply with quote
the oil topic comes up alot so i thought i'd put this together
What viscosity to use.....
All I6 OHC cam engines up to and including the EL have a recomended oil of 15w40, the AU and on I6 including twincam are 10w30
why use thinner oil??
these engine are built with tigher clearences then the older engines to enable them to use thinner oil. the up side of the thinner oil is less oil drag on moving parts, transalting to less energy wasted trying to over come this drag. thinner oil is also easyer to pump through the engine and on start up every thing is oiled sooner.
this all means less wear and better feul economy.
Why change from recomended??
for the most part you should never change from what is recomended for your engine. the only thing you achieve is more wear on start up and more feul consumption.
If you are having problems like oil consumption with the recomended oil, it may (but not always) be helped by useing the next thicker oil.
what the numbers mean!!!!!
this is one thing people don't seem to understand.
5w50
10w50
15w50
20w50
one thing those all have in common is at operating temp they are ALL THE SAME THICKNESS
from the top of the list the get thicker WHEN COLD as you go down the list.
the first number is the weight of the oil when could is the first number.
the second number is the weight when hot.
an explanation of the second number......
the seond number is the hot wieght, with a 5w50 the oil starts out as an SAE 5 when cold but it only thins out as much as an SAE 50 would when hot.
the further apart the numbers are the more constant the thickness of the oil. because it starts out thinner.
here are a few threads on the subect of oil (a small selection from the many we have)
http://www.fordmods.com/forums/viewtopic.php?t=26612&highlight=oil
http://www.fordmods.com/forums/viewtopic.php?t=26256&highlight=oil
http://www.fordmods.com/forums/viewtopic.php?t=23638&highlight=oil
http://www.fordmods.com/forums/viewtopic.php?t=17728&highlight=oil
http://www.fordmods.com/forums/viewtopic.php?t=17197&highlight=oil
http://www.fordmods.com/forums/viewtopic.php?t=15158&highlight=oil
www.motul.com.au
www.fuchslubritech.com.au
www.penrite.com.au
www.valvoline.com.au
www.esso.com.au (moblie)
http://www.castrol.com/castrol/castrolhomepage.do?categoryId=3000&source=castrolglobalcountryselector
(castrol australia)
common questions
Quote:
im gettting my bottom end rebuilt and have acl pistons is it fine after i run it in to use penrite sin fully synthetic 15w 40?
run the engine in on mineral oil of the same weight that is going to be used for the rest of the engine life. then and this is my opinion it's a collective and averaged out number, switch to fully synthetic after about 3000km.
Quote:
i use shell helix older engines 25-60 in my eb. its done 293k so i think using a -40 or -50 oil might be a bit too thin. is this correct? or am i totally off the track?
if there are no signs of mayjor oil consumption or very low oil pressure, regardless of the amount KMs the engine has done there is nothing to be gained from using thicker oil. in fact using oil that is to thick will only add to the wear on start up and cause poor feul economy.
Quote:
i get the ticking noise momentarily on start up,should i try something thicker?
thats only a slight oil drainback of the HLAs nothing to worry about if it goes away in a few seconds
Gaz
PostPosted: Sat Apr 29, 2006 1:32 pm    Post subject: Reply with quote
does that mean the penrite HPR15 (isnt it 15w60?) is to thick?
tickford_6
PostPosted: Sat Apr 29, 2006 1:53 pm    Post subject: Reply with quote
yes
Happy
PostPosted: Sat Apr 29, 2006 2:10 pm    Post subject: Reply with quote
good work!
Gaz
PostPosted: Sat Apr 29, 2006 2:17 pm    Post subject: Reply with quote
so what would you recommend? ive been usin that for a fair while, would it be worse to keep using it or worse to change to a 15w40. in which case, whats the best in that range? dont wanna go to expensive. and fully synthetic isnt well suited to older engines is it? or even changing from semi to full synthetic is bad isnt it?
TROYMAN
View User Gallery (30)
PostPosted: Sat Apr 29, 2006 2:21 pm    Post subject: Re: OIL once and for all Reply with quote
5w50
10w50
15w50
20w50
i agree 100% but providing your clearences are as tight as they are when new.. obviously after 10 years or say 250000kms your clearences will not be as tight.. this will also depend on the way you treat your car (driving habits,servicing etc) we can only wish that our engine clearences will be as good as new..
if so we would have engines that would never wear out!!
thats my opinion...
Grechie
PostPosted: Sat Apr 29, 2006 2:48 pm    Post subject: Reply with quote
tickford_6
PostPosted: Sat Apr 29, 2006 3:08 pm    Post subject: Re: OIL once and for all Reply with quote
thats my opinion...
that wear can be judged by the amount of oil consumption and a simple oil pressure check. if there is no or little oil consumption and the pressure is still within limmits there is nothing to be gained and feul economy to be lost by using thing thicker oil
Gaz
PostPosted: Sat Apr 29, 2006 3:25 pm    Post subject: Reply with quote
what sort of fuel consumption are we talking about here? cause mines is crud. could it explain crap consumption stop start driving but fine consumption cruising on highway?
would you recommend i switch back to a 15w40? ive been runnin HPR15 for 30,000km or so i think.
best to stay semi synthetic or go full? in your other thread u said motul8100 15w40 for your engine whats that worth? or should i go a fuchs if they do 15w40?
its an 1996 ef2 I6 mont, with 126,000k's (trip comp susually sits on about 17L/100km mixed driving)
fuchs recommends:
TITAN Performance Plus
A high quality mineral grade engine oil for multi-valve, modern engines. The high quality base oils and latest technology additive package offers greater protection at cold start and assists with reducing unwanted sludge and deposits. Suitable for all gasoline and diesel passenger vehicles with normally aspirated and turbocharged engines.
Specifications:
SAE 15W-40 API SL/CF
whats price different between motul and fuchs?
prydey
PostPosted: Sat Apr 29, 2006 3:30 pm    Post subject: Reply with quote
high km's doesn't always mean you have to start using thicker oil. my car has 292000 km's on the clock and i use shell helix ultra (5-40) and have done for about 8 years. i won't say it doesn't use oil but what it does use is well within tolerance. over 5000km it may use 2-300ml. not sure how accurate the oil pressure guages are on the dash but it always reads between 1/2 and 3/4 sometimes higher. i will always recommend a full synthetic over semi or mineral base.
it can be detrimental changing from mineral to synthetic as a lot of the carbon build up around the motor is also acting as a seal. synthetics will tend to clean all this out (to an extent) and could shorten the life of the motor. having said that i bought my car on 230000 and changed to shell helix ultra straight away and have never looked back. economy is pretty good in mine too. 10.8 city and 7.8 highway. i have no doubt the oil plays a small part
tickford_6
PostPosted: Sat Apr 29, 2006 4:20 pm    Post subject: Reply with quote
fuchs recommends:
Specifications:
the motul 8100 is full syn oil and the cost represents that.
not sure on retail price (i'm not the salesman at work) but i think it's around $65 for 5L we also use fuchs oil at work and put simply i believe them to be tw best oils you could put in your engine
i'll always recomend you use the recomended oil for your engine unless there is a problem that there is no other cost effective solution for.
Gaz
PostPosted: Sat Apr 29, 2006 4:27 pm    Post subject: Reply with quote
hm, not to keen on switching to a fully synth oil, mainly cause of how old it is. guessing that fuchs is semi synthetic, next oil change is due in 3500km, might try the fuchs stuff if the price is reasonable.
i got no real reason to run ticker oil i guess. got some lifter noise, but that was after a cam change so i think i just got a buggered HLA.
Grechie
PostPosted: Sat Apr 29, 2006 5:05 pm    Post subject: Reply with quote
would it matter if wen i get my motor back to run penrite sin 15w 40???? it has forggied ACL pistons (heavy duty) , and new rings etc...
twr7cx
PostPosted: Sat Apr 29, 2006 5:22 pm    Post subject: Reply with quote
hopefully this stops talk of people running bloody 20W60 and who knows what else in there donks!
tickford_6
PostPosted: Sat Apr 29, 2006 5:41 pm    Post subject: Reply with quote
dont run the engine in with synthetic oil.
run it in with a 15w40 mineral oil
bluecube
PostPosted: Sat Apr 29, 2006 5:48 pm    Post subject: Reply with quote
Molloy
View User Gallery (23)
PostPosted: Sat Apr 29, 2006 6:20 pm    Post subject: Reply with quote
cool 15w40 full synthetic it is then.
kezz
PostPosted: Sat Apr 29, 2006 7:12 pm    Post subject: Reply with quote
i tried some GTX 3? 15w-40 in my car recently, now on start up i get the ticking noise momentarily. safe to keep using it? or try something thicker?
Grechie
PostPosted: Sun Apr 30, 2006 3:15 am    Post subject: Reply with quote
i wont run my motor in with fully synthetic, ill run it in with s**t stuff or woteva, then ill run it with penrite sin 15 w 40, shood be fine
snap0964
PostPosted: Sun Apr 30, 2006 10:45 am    Post subject: Reply with quote
Good idea adding the links and putting FAQ's.
Happy wrote:
good work!
Greg, you should copy and paste the first post and make a doco out of it as originally intended.
Speaking of FAQ's:
As far as NA LPG/petrol cars go, it's been advised to me that using the manufacturer spec petrol oil is fine for long term use on LPG engines. Although there is oil designed for use on LPG cars, I can't see why you can't use the regular spec oil either. The ford owners manuals don't seem include the Tickford LPG oil specs - I suppose that means it uses the same oil specs. Do you have any advice regarding oils for LPG ??
Page 1 of 6
[47 queries :: 0.09546 seconds ]
