Age:33 Posts: 643 Joined: 14 Dec 2007 Location: delegate NSW, Australia
Posted: Sat May 31, 2008 1:06 am Post subject: Overfilling |
I just got my EBII runnning again and filled it with LPG. Except it seems to have been overfilled and i'm trying to work out why.
There was a small amount left in the tank, and after putting in 61L there was a click and the rate of gas flow reduced markedly. But while normally it stops, in this case it kept trickling in. I waited to see if it would stop but it kept going at about the same rate. So i walked into the shop and they said 'let it go it will stop when it's done'. But it got to 70L and i checked the tank guage and it read about 20% over the "F" mark. The "F" mark is 80% full. So presumably the tank was near 100%. I couldn't see the rated tank volume but i reckon it wouldn't be more than 80L.
As far as i understand there is a blow off valve so there won't be an explosion. So i should use it before hotter weather comes along or it will be wasted.
My thinking is either:
- my tank should have shut off the intake which would have then shut off the pump
- the pump should turn off at a certain pressure and didn't
- both of the above
Any answers? |
eagleaus Fordmods Stock as a Rock
Age:47 Posts: 196 Joined: 06 Nov 2004 Location: Maryborough QLD, Australia
Posted: Sat May 31, 2008 9:25 am Post subject: |
| I would say the automatic cut off may not be working correctly, as you said you heard a click.I find that once a pump starts doing 1c 1c, just hang it up.Sometimes I recon its the weather, that is tank temperatures etc., The pump won't turn off because its a pump and relies on the automatic cut off.The best idea if you know what it holds or you expect to put in just stop at that amount.That's why there is no catches on them any more. |
Posted: Tue Jun 03, 2008 8:24 pm Post subject: |
| eagleaus wrote: | | I would say the automatic cut off may not be working correctly, as you said you heard a click.I find that once a pump starts doing 1c 1c, just hang it up.Sometimes I recon its the weather, that is tank temperatures etc., The pump won't turn off because its a pump and relies on the automatic cut off.The best idea if you know what it holds or you expect to put in just stop at that amount.That's why there is no catches on them any more. |
This pump nozzle had a catch. Are you saying the tank is meant to have an auto cut off and mine must not be working properly?
My current thinking is i don't mind really, as it seems i have the option of 80% fill, or more. As long as it doesn't blow off, the more the merrier, perhaps, living in a remote area anyway. |
muncher2002 Fordmods Oompa Loompa
Age:28 Posts: 46 Joined: 01 Aug 2008 Location: Werribee VIC, Australia
Posted: Sun Aug 03, 2008 11:06 pm Post subject: Re: Overfilling |
you may of gotten a richer mix of butane gas in the automix or you tank might not be sitting rite, if you have a APA tank in the boot use a small level on the inspection cover to make sure it is level otherwise the autofill locator (AFL) wont work
| relaxed_diplomacy wrote: | I just got my EBII runnning again and filled it with LPG. Except it seems to have been overfilled and i'm trying to work out why.
- both of the above
Any answers? |
[31 queries :: 0.04242 seconds ]
