PCV VALVE EXPLODED INTO ENGINE
ghia97
Donating Member
PostPosted: Wed Jan 16, 2008 11:56 am    Post subject: PCV VALVE EXPLODED INTO ENGINE Reply with quote
Im just wondering after having a major backfire and having the pcv valve smash into the head putting a small hole approx 1.5cm x .5cm in the bottom of the alloy head directly under the pcv what are the chances of long term survival of the engine with a small hole in the head. All of the damaged pcv was removed from engine so there isnt anything floating in there. The car has been driven like this for a while and there is no noticeable difference.
97GLIWAGON
PostPosted: Wed Jan 16, 2008 2:08 pm    Post subject: Reply with quote
Hmmm im thinking this could've happend to my enigne now....Bugger!
relaxed_diplomacy
PostPosted: Thu Mar 27, 2008 9:33 pm    Post subject: Reply with quote
A short time ago i spoke to a parts man at a Ford dealership and he said that after backfire the pcv innards can end up in the timing chain, if it jumps then bang! . . . engine dead.
Krytox
PostPosted: Thu Mar 27, 2008 9:49 pm    Post subject: Reply with quote
I think the 'damage' you'll find will be the oil drain hole.
Did you happen to retrieve a single ball bearing? this can cause a very bad timing chain mishap as stated above.
If it made it to the sump, then she'll be right mate'!
Rick's EF Fairmont Wagon
PostPosted: Fri Mar 28, 2008 5:14 am    Post subject: Reply with quote
Note to all
there is a revised METAL PCV valve that must be fitted when GAS is fitted to avoid this problem.
This was in a ford bulletin
ghia97
Donating Member
PostPosted: Sat Apr 05, 2008 1:27 pm    Post subject: PCV Reply with quote
Thanks guys. I fished out the metal rod and spring but i didnt see a little ball bearing. The car has been driven 5000kms in this state now with no problems so i would say all is good.
xcabbi
PostPosted: Fri Apr 25, 2008 11:30 am    Post subject: Reply with quote
Rick's EF Fairmont Wagon wrote:
Note to all
Then why the hell do the pricks still sell plastic ones?
Krytox
PostPosted: Fri Apr 25, 2008 11:37 am    Post subject: Reply with quote
Price.
Disco Frank
PostPosted: Fri Apr 25, 2008 12:49 pm    Post subject: Reply with quote
and i would say u need to ask for the metal pcv valve
if u ask for a pcv valve they would give u the plastic on
dude sounds like the ball bearing made it into the sump
TROYMAN
View User Gallery (30)
PostPosted: Fri Apr 25, 2008 1:18 pm    Post subject: Reply with quote
or you can use the metal pcv from ea/ed..
i dont run lpg but im using a metal ea pcv in my au engine and it works fine!
ghia97
Donating Member
PostPosted: Tue Apr 29, 2008 7:49 pm    Post subject: pcv Reply with quote
Yep it was the oil drain hole lol not pcv as i thought, has metal pcv on there now. Fraud shouldnt sell plastic ones or ask if vehicle is on lpg at least.
[38 queries :: 0.03278 seconds ]
