Power Window Maintenance
Goto page Previous  1, 2
DEADSET_AU_WAGON
PostPosted: Mon Apr 30, 2007 10:56 pm    Post subject: Reply with quote
MY AU series one Drivers side power window TAKES FOREVER to wind back up, it is fast to wind down, but it sounds like its labouring to get back up and is very very slow, should I get the rubber replaced or spray somthing in the rubbers,,,, or will that screw everything up??
its an ex cab so its pretty used.... but still works.....takes a few minutes tho.
BlkEB2
PostPosted: Sat May 05, 2007 6:57 pm    Post subject: Reply with quote
Also if the window wants to fall forward because of wear and tear or just badly adjusted you should firstly clean and lube the runners and slides as above threads explain and then put the window all the way up and re-adjust the whole regulator mechansim buy loosening all six bolts that hold it. Then push the bottom section of the mech towards the front of the door and the top section to the back and while holding re-tighten.....This should allow the weight of the glass to balance even on the holder it sits in and will hopefully fix/improve most.....But sometimes they're just too worn!
siegz88
PostPosted: Fri Jun 22, 2007 8:18 am    Post subject: Reply with quote
If any one is interested in the genuine ford window lubricant it's called LY70 and it's available from dealers.
farquar
PostPosted: Tue Jul 24, 2007 7:28 am    Post subject: power windows Reply with quote
Hey, I am about to install a full set of power windows into my GL wagon. Would anbody have or know where I can get the wiring diagrams for this job? Also any hints and tips would be very much appreciated (positive ones. Not things like - Don't do it)
MadMatt
View User Gallery (25)
PostPosted: Tue Jul 24, 2007 7:47 am    Post subject: Reply with quote
EA GL? ED GL? what model/year is it?
EB92
PostPosted: Tue Jul 24, 2007 8:11 am    Post subject: Reply with quote
I find that "Nulon Ezy-Glide" is pretty good
for the window rubbers.
I spray mine about once every 6 weeks or so.
Bout $16 for a big spray can.
farquar
PostPosted: Tue Jul 24, 2007 7:37 pm    Post subject: Reply with quote
Sorry, I forgot to say EF. I have found a full set of (supposedly) every thing I need in a EF (Futura) sedan and have yet to pull it all out to put into my wagon.
marky d
PostPosted: Tue Sep 11, 2007 8:21 am    Post subject: Reply with quote
i have found most liquid lubes end up like glue when they dry out making your windows slower than when you started.i also tried dishwashing detergent which works great but not for long.i found the best thing to use is graphite powder as it does not dry out and turn into glue
EFairmanual2088
PostPosted: Mon Oct 15, 2007 8:23 pm    Post subject: Reply with quote
did mine yesterday used a lube called drylube silicone based stuff no liquid viscocity yet lubricates just as well as graphite powder but somehow hangs around a lil longer great stuff get it from joints like autobahn auto-one repco super cheap all those auto mobs... give it a shot.. as for rubbers a good dose of silicon spray is always good....
MrShansta
PostPosted: Fri Nov 09, 2007 12:32 am    Post subject: My 20c worth (Plus GST) Reply with quote
FWIW.......
For the window rubbers I was advised by a used car dealer to use WD-40 or CRC-556 - they reckon it lasts a lot longer than the silicone spray...
It worked on my old VH Crummy for about a year before I had to re-do it...
I use it under the bonnet (rubber hoses look MAD) and on the tyres if I run out of "So-Easy".... (So-Easy still works better - but it ain't cheap)
Silly spray turns too tacky for window rubbers - add a bit of dust and crap and you end up with valve grinding paste....
I did see pure silicone oil once (It was for a photocopier?) the most slippery substance I have ever seen or heard about!!!
-GAS-MAN-
PostPosted: Sun Dec 02, 2007 7:55 pm    Post subject: Reply with quote
I had an electric window that took forever to go up, i had to use my hand to pull the glass forward half way up to keep it moving upwards. I went and pulled the whole door off, looked at the whole thing and thought, the resistance here is in the rubbers on the sides, i got my can of degreaser and the slightest squirt inside each rubber well where the windows are held in removed the resistance and the window works a treat, after one week its running very well. Degreaser did and does not require washing out, window freed up immediately.
Unless your problems involve something damaged, why would you want to spend half a day, even an hour removing the doors and fiddling around with anything else.
If i overlooked something please dont flame me, i am just noting my experience for the benefit of others.
cgglasson
PostPosted: Fri Feb 01, 2008 12:50 am    Post subject: Reply with quote
Hey guys. Sorry to bring this thread back up but its better than starting another one.
Just curious as to whether you guys ahve been taking the door trims off while using the spray or graphite powder???
I am needing to lube up the fairlane and dont want to have to pull apart the door trim if I dont have to.
-GAS-MAN-
PostPosted: Fri Feb 01, 2008 7:36 am    Post subject: Reply with quote
Hey mate, i was taking mine off - having trouble finding one screw (didnt sleep the night before) icon_smile.gif'
No, you dont have to, get some degreaser and spray it down the sides of the runners (where the glass runs up and down icon_smile.gif
Worked a treat for me.
Matt
cgglasson
PostPosted: Fri Feb 01, 2008 8:09 am    Post subject: Reply with quote
Cheers mate for the reply.
Now there's no excuse for me to get off my a** and do it... Damn.
Page 2 of 2
[41 queries :: 1.61034 seconds ]
