Power Window Maintenance
Happy
PostPosted: Tue Sep 06, 2005 12:28 pm    Post subject: Power Window Maintenance Reply with quote
People,
I've done the conversion on my GLi and I wanted to pass on some info you may not know. The short of it is DO NOT GET GREASE ON THE CABLE.
Grease up the slide the regulator runs on but do not get grease on the cable.
It doesn't need grease and what seems to happen, is over time the grease will thicken up inside the cable tubes with dust and moisture and increase friction, this is the most common cause of power window reg failures.
Hope this helps!!
Nicko
PostPosted: Tue Sep 06, 2005 12:32 pm    Post subject: Reply with quote
good tip there greg!
fuzion
View User Gallery (17)
PostPosted: Tue Sep 06, 2005 1:35 pm    Post subject: Reply with quote
Happy, also the runners are a big problem in the e series.
quick steps to fix em
a) take off door trims
b) get a flathead screw driver, degreaser, and a rag.
c) rap the rag around the screw driver, spray the runners with degreaser all the way up and down.
d) run the screwdriver with the rag along them scrubbing it out
e) use a spray bottle of water or hose watever you prefer to get out the degreaser from the runners
f) clean them again with rag/screwdriver
g) spray NULON EZY-GLIDE (red can) all the way through, you should almost waste a whole can on all 4 windows..
give it a 2-3 days for them to start moving quicker.
if you really want, attempt to clean the glass of gunk/grease where they sit in the runners to.
makes a HUGE difference. most especially if your front windows fall inwards whilst winding upwards.
GlennBA
PostPosted: Tue Aug 29, 2006 11:56 pm    Post subject: Reply with quote
fuzion where do you get that ezy glide stuff from? my drivers window takes about 7 years to wind up.
Nicko
PostPosted: Wed Aug 30, 2006 11:18 am    Post subject: Reply with quote
You get ezy glide from repco, autobahn, bursons
Even some k marts have it!
Falcon-enthusiast
PostPosted: Wed Aug 30, 2006 11:51 am    Post subject: Reply with quote
thanks fuzion, my drivers side on my ef is a challenge, cheers
Timmeh
PostPosted: Wed Aug 30, 2006 12:12 pm    Post subject: Reply with quote
I use silicon grease on the window runners and they windows hit top speed on the up and down now.
Window races have never been so much fun.
JohnnyFX
PostPosted: Wed Aug 30, 2006 1:18 pm    Post subject: Reply with quote
Amazing thing is, mine 90% of the time do it after it has rained
once water gets around the windows they slow down or sometimes stop when going up
then on dry days they're ok
is that all to do with water and oil not being good bed fellows?
GlennBA
PostPosted: Sat Sep 02, 2006 10:41 pm    Post subject: Reply with quote
Yeah i don't have a problem with my windows if the car has been sitting in the sun.
GlennBA
PostPosted: Tue Sep 19, 2006 1:26 pm    Post subject: Reply with quote
I just used silicon spray on my front electric windows and they're quicker than ever now. Very easy to do icon_smile.gif
Ferrett
PostPosted: Mon Oct 16, 2006 3:08 pm    Post subject: Reply with quote
I agree
I have same issues when it rains to the point you have to grab the window and help pull it closed!
Does anyone know why this is so and the most applicable remedy??
farmerjason
PostPosted: Tue Oct 17, 2006 2:02 pm    Post subject: Reply with quote
Hey Guys
Since we're talking about power windows, Does anyone have any ideas on what may be my problem. On my wifes AU3 XR6 the front passengers side window wont work from the switch, but it works fine from the main control on the drivers side, Any ideas??
falcongli
PostPosted: Wed Nov 08, 2006 3:59 pm    Post subject: power windows Reply with quote
farmerjason wrote:
Hey Guys
I had this probem with the AU Fairmont windows. It's caused by an accumulation of carbon on the switch contacts. If you're handy and can manage it, you will need to dismantle the switch that's causing the problem and clean the copper contact then re-assemble it. Worked really well for me. Be careful dismantelling the switch as there are small pieces. You don't want to lose anything and you want to remember how everything goes back togther again. Good luck
farmerjason
PostPosted: Wed Nov 08, 2006 5:54 pm    Post subject: Reply with quote
harro
PostPosted: Thu Nov 16, 2006 9:21 pm    Post subject: Reply with quote
mad wowies!
My drivers window most of the time takes ages to go bak up, would that be the cause??
Busso
PostPosted: Thu Nov 16, 2006 9:39 pm    Post subject: Reply with quote
my dad had that carbon problem on his AU xr8 back in the day ugly thing it was lol but it did look mean in black.
anyway guys im pretty sure u get problems with ur power windows after ti rains coz all the dust in there gets moisture in it and then it hardens.
ive heard stories of cars that have been sittin up north like northern territory way and get all dust in them and then when the rain comes everything ceases up
falcondave
PostPosted: Thu Nov 16, 2006 10:23 pm    Post subject: Reply with quote
I had an AU that jammed the window so badly when I wound it up fast (coming out of the Harbour Tunnel with my window half down into torrential rain) that the window came off the regulator when I tried to get it free.
I took it to Ford who admitted it was a common fault to do with the rubber used for the runners. They replaced all the runners and the windows never stuck again... icon_surprised.gif
horis
PostPosted: Fri Mar 16, 2007 5:34 pm    Post subject: Reply with quote
with the e_series falcons there way a special lubricant made to stop the windows from jaming and tilting forwards when sticking its all because of a build up of muck in the guides go to your local ford dealer and ask about this stuff but were protective gloves as it is cancerous if got on bear skin
GTBob
PostPosted: Fri Mar 16, 2007 5:46 pm    Post subject: Reply with quote
In that case don't let a BEAR near your windows icon_biggrin.gif icon_biggrin.gif icon_rolleyes.gif
Krytox
PostPosted: Fri Mar 16, 2007 6:20 pm    Post subject: Reply with quote
1+½ yr old post!
[47 queries :: 0.06107 seconds ]
