POWERDYNE super charger question for I6
Goto page 1, 2, 3  Next
sickd
PostPosted: Thu Mar 10, 2005 8:02 pm    Post subject: POWERDYNE super charger question for I6 Reply with quote
anyone with a cappa powerdyne kit or supercharger how does the car cruize on the highway does it use more fuel?
what sorta power delivery do they have is it from low to mid or is there stuff all down low.
if anyone has a dyno chart with torque figures would be very helpfull
PostPosted: Fri Mar 11, 2005 8:10 am    Post subject: Reply with quote
Hey mate. Well ive got it on the 5.0L but i imagine would be similar to the I6, both fairly torquey motors.
Highway cruising it probably gets better mileage than stock but not really noticeable. Certianly no worse. I think i sit on about 6-8L/100km cruising at 100km/hr.
The boost doesnt really come on untill 2750-3000rpm (which is when she really takes off), but that doesnt necissarily mean the power delivery isnt present below these revs. Even from the word go, air is being pushed into the engine.. just not enough to register noticeable amounts of boost. On the windsor, the power really comes on in the midrange (which makes it an incredibly good daily driver) - the standard heads/intake arent very good for high RPM - im not sure what the 6 is like.
distortion
PostPosted: Fri Mar 11, 2005 9:40 am    Post subject: Re: POWERDYNE super charger question for I6 Reply with quote
dyno charts are available on their website (capa's)
PostPosted: Fri Mar 11, 2005 9:49 am    Post subject: Reply with quote
Well this aint the best example for you... but for what it's worth....
I dont have the "money shot" for upload - the second graph was just after fitting the blower and the MAF was incorrectly measureing air. Hence the a/f ratio dropping below 10.1:1.... but gives you an idea of the torque.
Stock:
With blower but tuned like s**t (my impersonation of ayers rock):
sickd
PostPosted: Fri Mar 11, 2005 8:56 pm    Post subject: Reply with quote
thanks for that mate so whats the output on you car it has to be more than 116kw doesnt it
EDXR8
PostPosted: Fri Mar 11, 2005 9:38 pm    Post subject: Reply with quote
The 2nd one is after the blower install which looks close to 155rwkw. Not a great initial result but after sorting out the initial problems I am sure its a fair bit more now, but yeah lovely torque curve!
On an I6, the powerdyne blowers seem to get around the 170rwkw, which is similar to some of the NA kits out there but the blower would have tons more torque. My friend has a powerdyne ED XR8 producing 180rwkw and it feels awesome on the road.
Gaz
PostPosted: Sat Mar 12, 2005 12:37 am    Post subject: Reply with quote
just a general question.
if you can produce around the same kw from a powerdyne or a NA engine, would the blower be the better option? or all the block and heard work etc, to get it narurally aspired? which would be better option
2nd, with the capa kits, say the 6-9 psi boost kits, can the stock internals handle this kinds boost? or do u need rebuilds?
3rd (last) the ecu cant handle this boost right? so u need aftermarket/? they included in kits?
EDXR8
PostPosted: Sat Mar 12, 2005 12:48 am    Post subject: Reply with quote
Even with the same power levels I would go forced induction because IMO it gives much more low down and useable torque, there really isn't anything like driving a blowen / turbo engine.
6-9psi is fine on stock internals, no other mods are really needed to fit these blowers except a decent exhaust which isn't needed but highly recommended. Same with the EEC, the stock EEC is fine with the blowers, usually only needing a chip (which comes in the kit) to remove some timing under boost and to adjust the AF ratios. If you want a better tune you can opt for a Unichip or an aftermarket system, but on a stock engine the chip is fine IMO.
EBXR8380
PostPosted: Sat Mar 12, 2005 10:24 am    Post subject: Reply with quote
Exactly N/A power is often at or nr top rpm..Blower's have power under cam [ 1500 to 4000] range.Compared to n/a...
sickd
PostPosted: Sat Mar 12, 2005 2:31 pm    Post subject: Reply with quote
perfect guys all good info its good to talk to someone who has done this and can give pointers and info on what to expect thanks for your help.
if anyone has more stuff to say go ahead its all usefull stuff
Casper
PostPosted: Sat Mar 12, 2005 2:39 pm    Post subject: Reply with quote
I've been looking at SC's for the I6 for a while now. I'll be going the Vortec route rather than powerdyne. The V2 looks like the ducks guts and has plenty of room to grow.
EDXR8
PostPosted: Sat Mar 12, 2005 5:20 pm    Post subject: Reply with quote
Yeah exactly, I went for the Vortech V2 with mine for reliability and future upgrades. The Powerdynes are still good for street cars but they aren't the strongest units with their internal belt setup. If your budget can stretch to the Vortech I would highly recomend it.
Casper
PostPosted: Sat Mar 12, 2005 5:28 pm    Post subject: Reply with quote
The other option is the Vortec S Trim. Either way, the Vortec is, by all accounts, the superior SCer from what I've been able to find. So much so that I will not consider a Powerdyne now, even if its cheap. A rebuild every 15-20,000kms isnt that appealing to me....and that seems to be a common theme.
EDXR8
PostPosted: Sat Mar 12, 2005 5:36 pm    Post subject: Reply with quote
Yeah if the powerdynes are treated badly it is not uncommon to rebuild them ever year or so, although the ones from CAPA are now much better than they use to be as they manufacture and install new bearings and a better belt in theirs. Having said that one of my friends has been running one fairly hard for almost 100,000kms and it is still ok (although I am sure it is getting pretty worn now).
PostPosted: Tue Mar 15, 2005 3:39 pm    Post subject: Reply with quote
Yeah, sound advice guys.
From what ive been reading on the stang forums (quite a bit lately...) the poofterdyne is very well suited to automatic cars which arent driven like race cars (like mine....). It's the rapid changing of revs, hard on/off throttle (more associated with a manual trans getting flogged) which puts massive amounts of load on the internal belt of the powerdyne.
A lot of the complaints in the US have also arisen from ppl squeezing 10psi+ from the powerdyne which is well in excess of the 39,000rpm internal drive limit of the blower (read about one guy with a 347ci @ 15psi and wondered why the PD s**t itslef... icon_rolleyes.gif ). Although i dont think their suppliers are as open/honest/helpful as CAPA are here in Australia.
In the even of failure in mine I think I might try a Powerdyne XB model, identical shaped blower (i.e. will fit into my existing bracket) but with vortech-style gear drive.... although these units are reportedly very very noisy, might wait for the salary to increase so can afford to pay all the defects. Fitting a PD was also more inline with my mechanical abilities...
In summary... get a vortech, lol. Powerdyne lots of fun for me, but i'm easy to please.
sickd
PostPosted: Tue Mar 15, 2005 4:40 pm    Post subject: Reply with quote
does capa do the kit with a PD XB blower i have a manual and dont wanna put any more boost out of it but i will be giving it a bit of a hard time, do you know the cost of the XB model
PostPosted: Tue Mar 15, 2005 4:47 pm    Post subject: Reply with quote
Not on their website but I imagine they'd be able to get them. I think they actually build the powerdynes on site now.
IMO i wouldnt go straight for a PD XB, might as well go vortech. Im only thinking about a PD XB as i have the brackets etc. for it already. Heck the vortech blower is actually cheaper than a belt-drivern PD... its just the extra bits you need for the vortech which pushes up the kit price.
EDXR8
PostPosted: Tue Mar 15, 2005 5:41 pm    Post subject: Reply with quote
Yeah you may as well just go for the Vortech as the XB will work out just as expensive and it is still not as good IMO.
sickd
PostPosted: Tue Mar 15, 2005 6:14 pm    Post subject: Reply with quote
what is the extras in the vortec kit i had the impression it was a computer or do they just put an interceptor on
EDXR8
PostPosted: Tue Mar 15, 2005 7:08 pm    Post subject: Reply with quote
The Vortech kit comes with oil lines, extra bypass valve, T-rex fuel pump, billet aluminium pulley system and larger fuel injectors.
Page 1 of 3
[47 queries :: 0.07916 seconds ]
