problem with EB II ecu
bfturb
PostPosted: Tue Mar 01, 2005 4:11 pm    Post subject: problem with EB II ecu Reply with quote
sonce i have had my extractors fitted i have had problems with my car running REALY ritch idel hunting and when i try 2 get the error codes from the ecu i get a park nutral switch falt power steering falt all on KOEO but the bad thing it when i do a KOER test it starts 2 rev up then dies then i get 1 solid beep that wont go away any ideas ppl
Jase
PostPosted: Tue Mar 01, 2005 4:45 pm    Post subject: Reply with quote
Check the O2 sensor??
Mite have gotten mashed when you done the extractors
Good luck
georges
PostPosted: Thu Mar 10, 2005 12:15 am    Post subject: Reply with quote
Check the IAC valve and make sure it is not stuck open. The ECU will not be able to control the idle speed if th IAC valve is jammed.
Also make sure the MAF sensor has not got heaps of crap in it. This can also stuff up the fuel mixture calculations.
[30 queries :: 0.02604 seconds ]
