Problem with eb stereo. HELP!!
cenomorph
PostPosted: Mon Dec 06, 2004 2:52 pm    Post subject: Problem with eb stereo. HELP!! Reply with quote
the stereo in my car is a stock unit from fora and there's a problem with the head. the FR speaker keeps coming on and off. when i tap or push on the face just under the screen thingy it comes back but cuts out shortly after
WTF!!!
Dellboy999
PostPosted: Mon Dec 06, 2004 2:56 pm    Post subject: Reply with quote
Sounds like the plug in the back of it is loose, and dropping connection.
cenomorph
PostPosted: Mon Dec 06, 2004 3:01 pm    Post subject: Reply with quote
nah, i pulled the unit out and had a fiddle but it's something else inside the unit. speakers and connections are fine
ch0c0
PostPosted: Mon Dec 06, 2004 3:53 pm    Post subject: Reply with quote
your best bet might be to get a replacement from a wrecker.
or fit an aftermarket unit
sounds like there is an internal short, virtually impossible to diagnose and fix easily.
if you paid someone to do it, youd be better off replacing.
cenomorph
PostPosted: Mon Dec 06, 2004 4:10 pm    Post subject: Reply with quote
yeah, i'll get a new unit, need a cd playa ne way.
joolz
PostPosted: Mon Dec 06, 2004 7:41 pm    Post subject: Reply with quote
if your any good with a soldering iron its easily fixed. what happens is you get dry/broken joints on the audio output chip, its cause of the expansion and contraction as the chip heats and cools. the chip is located along the back or sides of the head unit as its mounted to a heat sinc (aluminium). if you remove the botton cover you should be able to access it from there. make sure no joints are touching each other after soldering.
v8fordman351
PostPosted: Wed Dec 08, 2004 9:20 pm    Post subject: Reply with quote
can get heaps of chep cd players from $150 up for name brands so next tim it does it stick a screwdriver in it real hard (you will feel great) and just buy a new one
[34 queries :: 0.04258 seconds ]
