Ben_Daui Fordmods - Getting Side Ways
Age:29 Posts: 1709 Joined: 10 Nov 2004 Location: THE DRUITT NSW, Australia
View User Gallery (29)
Posted: Mon Jan 21, 2008 8:09 pm Post subject: Programing a Smart Lock FOB to a NC |
I followed the Smart Lock Doco
http://www.fordmods.com/forums/documents.php?doc=26
I followed the steps & no lock action at all
| Quote: | Doco wrote/
Adding and Removing remote Keypads to the Smartlock module
# 1. The ignition switch should be in the Off position, with all the doors shut and Unlocked.
# 2. Turn the ignition key to the ACCESSORY position and within 5 seconds, operates the rear demister switch exactly three times in quick succession. (IE. Press the switch so the Demister light turns on, then off, then back on again.)
# 3. After the 5 seconds is up, the door locks will change state, to indicate that the BEM has entered keypad learn mode |
Will this procedure work for the NC, My NC is a DEC 92 & there is the smart lock light flashing on the dash.
I have used the SERCH & cannot find anything closeley related so if you know the link post it please. |
