19concorde Fordmods Stock as a Rock
Age:23 Posts: 115 Joined: 28 Sep 2005 Location: Gold Coast QLD, Australia
Posted: Fri May 16, 2008 11:03 am Post subject: QLD: Car Audio equipment FOR SALE !!! |
Kicker DX350 Class D Amplifier
Put a DX350 mono subwoofer amplifier in your vehicle, and you'll need a new bumper sticker — "Warning! Killer sound on board!" This amp has a high-efficiency Class D power supply. That means you'll be able to get the most out of your charging system. The result is clean, loud sound!
Kicker has equipped the DX350 with state-of-the-art features like a Pulse Width Modulated power supply controller, so you get full power even when your electrical system approaches peak use or low voltage. A temperature sensor ensures that the amp won't "run hot" and cause distortion.
• Class D circuitry
• frequency response 10-200 Hz
• 175 watts RMS x 1 at 4 ohms
• 350 watts RMS x 1 at 2 ohms
• requires 8-gauge power and ground leads
• MOSFET power supply
• module docking port with two-way active crossover (can be set for high- or low-pass at 60, 80, or 100 Hz, 24 dB/octave)
• preamp outputs can pass a full-range signal or be set for high- or low-pass at 60, 80, or 100 Hz, 24 dB/octave
• oversized power connectors
• 12-5/16"W x 3"H x 10-1/16"D
$350.00 neg. ($1299 new)
2 x JL Audio 12W3 D2 subwoofers in custom box
The 12W3 offers a great balance between reasonable enclosure volume and massive output capabilities. Very long excursion capability and highly linear motor and suspension designs combine to deliver maximum performance from higher power levels. This speaker works extremely well in sealed, ported and bandpass enclosures and its dual voice coil design gives the user a high degree of application flexibility.
The custom box the subs come in is ported and was created by myself, so the box volume has been made to get maximum efficency from the subs and has been reinforced to withstand any application.
$500 for both subs in box neg.
$200 individually neg.
2 x 12 inch Kicker Subwoofer Grills
Stylish way to protect your subwoofers
$50 for the pair
$25 each
Ford sound system
Ford (pioneer) 6 inch splits
Ford (pioneer) 6 inch two ways
Ford Tape deck
Ford 6 stack CD stacker
$50 for the lot
This is for local pick up only for Brisbane and Gold Coast residents
Gianni_x85@hotmail.com
Posted: Fri May 16, 2008 2:43 pm Post subject: |
Some pics
| Description: |
| Filesize: |
211.19 KB |
| Viewed: |
13 Time(s) |
| Description: |
| Filesize: |
190.14 KB |
| Viewed: |
11 Time(s) |
| Description: |
| Filesize: |
265.73 KB |
| Viewed: |
11 Time(s) |
Posted: Fri May 16, 2008 2:47 pm Post subject: |
Some more pics of the Ford Gear. I also have a 1 farad cap for sale $30
| Description: |
| Filesize: |
157.99 KB |
| Viewed: |
12 Time(s) |
| Description: |
| Filesize: |
193.75 KB |
| Viewed: |
11 Time(s) |
| Description: |
| Filesize: |
285.04 KB |
| Viewed: |
13 Time(s) |
| Description: |
| Filesize: |
189.34 KB |
| Viewed: |
11 Time(s) |
4LEDboy Fordmods - Getting Side Ways
Posts: 683 Joined: 07 Mar 2007 Location: moonta SA, Australia
Posted: Fri May 16, 2008 4:45 pm Post subject: |
Damn I would buy the ford stuff if you could post it!
Just the deck, stacker and cables mainly
jonathon Fordmods - Getting Side Ways Donating Member
Age:21 Posts: 1090 Joined: 14 Apr 2006 Location: Whyalla SA, Australia
Posted: Fri May 16, 2008 6:11 pm Post subject: |
| pm sent
Posted: Mon May 19, 2008 5:37 am Post subject: |
bump...
Capacitor sold and i think Ford stuff could be sold also.
Posted: Sat May 24, 2008 6:39 pm Post subject: |
Cap and Ford Stuff sold,
Everything else is still avaiable peeps.
Posted: Fri May 30, 2008 1:48 pm Post subject: |
| bump......
