More Grunt Fordmods - Getting Side Ways
Age:26 Posts: 712 Joined: 10 Jul 2007 Location: Bacchus Marsh VIC, Australia
Posted: Sun May 11, 2008 8:43 pm Post subject: quick question needs quick answer |
found a BA 5 speed manual transmision for sale for a good price, suposed to have done 40,000ks. question is will the BA T5 go into an AU? will it fit in the tunnel? no worries if i need a new bellhousing can get one of those, just wanna know if Im wasting my money buying it and if its any different from the e-au series T5s.
fast and knowledgeabl response vastly apreciated. you may even get your name as my first childs middle name (not a garauntee.) |
Posted: Sun May 11, 2008 9:46 pm Post subject: |
| need to know within 15 hours. |
MMD Fordmods Tyre Shredder
Posts: 386 Joined: 30 Nov 2004 Location: Melbourne VIC, Australia
Posted: Sun May 11, 2008 9:47 pm Post subject: |
| i know that an E Series t5 will bolt up to a BA motor with an AU bell housing. |
Age:18 Posts: 3358 Joined: 02 Mar 2006 Location: Port Lincoln SA, Australia
Posted: Sun May 11, 2008 9:49 pm Post subject: |
| i think the T5s are all the same. IIRC the only difference in BA's is the box is called T5-Z, and is built stronger... |
Posted: Sun May 11, 2008 9:52 pm Post subject: |
so therefore the tunnels should be the same? were there any issues with the clutch cable setup? I know of an au bellhousing for sale if the BA one wont fit the AU.
its not for sale for much longer, so any furhter info between BA t5's and e-au T5's needed. |
Posted: Sun May 11, 2008 9:56 pm Post subject: |
i *think* the BA's have a hydraulic clutch, not sure though, ive never actually seen one in the metal.
but the boxes are pretty much the same. |
Posted: Sun May 11, 2008 10:18 pm Post subject: |
i know the t56 is hydraulic, im not sure bout the t5... theoretically if it were, is there much issue installing the hydraulic system off a BA? how much extra $$ would this add to the excercise?
I was hoping BA t5's were still cable operated... would make the descision much easier.
thanks for posting alfy  |
Mitch_ Cruise Moderator
Age:20 Posts: 5699 Joined: 05 Nov 2004 Location: Streets of Brisvegas QLD, Australia
Posted: Sun May 11, 2008 11:18 pm Post subject: |
| there hydraulic... for for some reason put s**t cables in e-series and au's... |
Posted: Sun May 11, 2008 11:20 pm Post subject: |
no probs, i do what i can to help
i think Dansedgli had a hydraulic setup in his EA, maybe fire him a few Q's about it. |
Posted: Mon May 12, 2008 1:02 am Post subject: |
| MMD wrote: | | i know that an E Series t5 will bolt up to a BA motor with an AU bell housing. |
So the AU bellhousings bolt up to BA engines, and so BA bellhousings bolt up to AU engines - we are talking I6 here correct? Therefore a T56 from a BA would bolt up to an AU. All that would be required then would be a hydraulic clutch conversion, possible modifications to tailshaft and rear gearbox mount. |
Steady ED Fordmods Addict
Age:22 Posts: 6628 Joined: 01 Jun 2005 Location: Melbourne VIC, Australia
Posted: Mon May 12, 2008 8:59 am Post subject: |
| twr7cx, correct, done by 'rollin' over at E-Series. |
Posted: Mon May 12, 2008 5:57 pm Post subject: |
| twr7cx wrote: | | MMD wrote: | | i know that an E Series t5 will bolt up to a BA motor with an AU bell housing. |
90% sure e-series bell housing bolts up to a BA motor but only the top 4 bolts.
And the hydraulic setup on dan's red EA was a custom setup.
when i get around to pulling this BA motor out that i have i will have a look to confirm. |
Posted: Thu May 15, 2008 12:39 am Post subject: |
| Will the stock BA T56 clutch bolt to the AU flywheel do you think? |
