distortion Fordmods - Getting Side Ways
Age:26 Posts: 820 Joined: 05 Nov 2004 Location: melbourne VIC, Australia
Posted: Mon Nov 29, 2004 11:33 am Post subject: radiator light? |
i is gettin worried... its a hot day here, 33 degres (hot for melb) and i took the car for a 3 hour drive, and the radiator light came on for a min at a time then turned off for 30 seconds then came back on... checked the coolant in the overflow tank, it was half full... engine gave off more heat than usual and car was sluggish...
fan was spinning when i checked also... any ideas? PLEASE dont say head gasket cos i will shoot my car if is another one of those expensive bastards |
Posted: Mon Nov 29, 2004 3:27 pm Post subject: |
| sounds like a slight leak somewhere.. if its a headgasket check under the oil cap for a milky substance |
4.9 EF Futura Moderator
Posted: Mon Nov 29, 2004 3:30 pm Post subject: |
Let's not jump to any hasty conclusions.....
I'd just keep an eye on the coolant level. If keeps going down then start losing a bit of sleep. If there's coolant in the resevoir then coolant should be fine in engine and radiator.
Was it the first time it got a real good heating up? Maybe some air removing itself. Hows the cap on the resevior? Last coolant change was done when? |
Posted: Mon Nov 29, 2004 6:18 pm Post subject: |
last coolant change about 3 months ago... coolant was still a good color, oil seems fine though i need to do my rocker cover gasket... it was the first time i've taken the car on a really long trip in the heat... hope it was only air... how often should i check the coolant level to see for head gasket?
hmm some parts of me hopes it is a head gasket... can anyone say ITS?
he he he
thanks for the replies people  |
outlawxr6 Fordmods - Getting Side Ways
Age:36 Posts: 521 Joined: 20 Nov 2004 Location: Brisbane QLD, Australia
Posted: Wed Dec 08, 2004 8:26 pm Post subject: |
| My el does a similar thing even at night time, i have checked the coolant level and all seems ok. It has done it twice now a few months apart, anybody have any ideas? |
pepsimax Fordmods - Getting Side Ways
Age:39 Posts: 400 Joined: 05 Nov 2004 Location: kirra QLD, Australia
Posted: Wed Dec 08, 2004 8:37 pm Post subject: |
| sometimes the float in the coolant tank will do silly things,,mine started flashing even though the coolant was full,,i spent half the day driveing with this thing flashing then it just stopped,,it's just a typical ford |
NOCLAF Fordmods Stock as a Rock
Age:22 Posts: 107 Joined: 01 Dec 2004 Location: Perth WA, Australia
Posted: Wed Dec 08, 2004 11:05 pm Post subject: |
| For a while my coolant was leakn like a siv it was completely dry every few days and i was just filling it and stressn out about it!.... then when i got around to it i bought a pressure tester and it ended up being that someone had avoided putn a gasket on my thermostat housing and the gasket glue they used was just turned to s**t.. so replaced one gasket which was like 2 buks and now its fine!.. |
daro Fordmods - Smokin em up
Age:45 Posts: 205 Joined: 04 Dec 2004 Location: Nambour QLD, Australia
Posted: Thu Dec 09, 2004 7:28 am Post subject: |
I had the thermostat stuff up on my EB II recently, I only know this because the temp gauge shot up in the red one morning going to work, so I replaced the thermostat & the gasket that goes around the thermostat & the problem is now solved.
I have one of those warning lights on my cluster as well, but it would require the engine to be in meltdown before it lights.
What model of Falcon do you have? |
Posted: Thu Dec 09, 2004 10:25 am Post subject: |
If the float seems to be behaving strangely, try this - remove float from header tank - clean assembly with soapy water - rinse off - reinstall. Don't forget ot top up the tank.
| Quote: | | I have one of those warning lights on my cluster as well, but it would require the engine to be in meltdown before it lights. |
That warning light is only for low coolant level nothing to do with temperature. |
Posted: Thu Dec 09, 2004 6:51 pm Post subject: |
| Where is this float? |
Posted: Thu Dec 09, 2004 6:53 pm Post subject: |
| I mean is it in the radiator or the expansion tank? |
Posted: Thu Dec 09, 2004 6:56 pm Post subject: |
| outlawxr6 wrote: | | I mean is it in the radiator or the expansion tank? |
expansion tank-header tank same thing, thats where you'll find it. |
