RAM heat sinks and HDD coolers
twr7cx
PostPosted: Sun Mar 05, 2006 9:52 pm    Post subject: RAM heat sinks and HDD coolers Reply with quote
Are these things worth the time and money?
http://cgi.ebay.com.au/ColdChip-ICERAM-SD-DDR-DDR2-AirCraft-Alloy-Heatsink_W0QQitemZ6854666489QQcategoryZ111425QQtcZphotoQQcmdZViewItem
http://cgi.ebay.com.au/2-X-PURPLE-Dual-Fan-Aluminium-Alloy-Hard-Drive-Coolers_W0QQitemZ6853945635QQcategoryZ80148QQtcZphotoQQcmdZViewItem
mreb
PostPosted: Sun Mar 05, 2006 10:52 pm    Post subject: Reply with quote
hard drive fans cant hurt ram coolers are good if your clocking them but if running normal then i wouldnt worry
A_Boring_Username
PostPosted: Mon Mar 06, 2006 3:46 pm    Post subject: Reply with quote
I wouldnt bother. the Hdd heat sinks arer good if you are running a drive farm. Ramsinks are like spoilers or stickers on cars. completely useless. Ram doenst usually get hot even when overclocked.
JOSE
PostPosted: Mon Mar 06, 2006 4:10 pm    Post subject: Reply with quote
Hard drive cooler: Essential if you have a 7200RPM drive (most 40gb drives upwards will be) or if your case has s**t ventilation or a lot of hot components. it will prolong the life of your HDD by a long time.
RAM sinks: not worth it unless your after a huge overclock with really high DIMM voltages, or if your system has RDRAM (which if it does will already have them)
Big Kev
PostPosted: Tue Mar 07, 2006 7:10 pm    Post subject: Reply with quote
yeh but in the same sense by the time u buy a new hard drive your on the 4th or 5th PC they last forever without the coolers....if u arent running raid arrays or high rpm drives like 15000rpm scsi dont bother
and RAM as everyones said unless your overclocking pretty hard core or have a cPU that runs very hot next to your memory banks dont worry bout them either.
JOSE
PostPosted: Tue Mar 07, 2006 7:30 pm    Post subject: Reply with quote
its better to look at it this way, do you have data on your HDD that youd rather not loose? and do you have a spare $20.
i had a 60gb 7200 rpm HDD start to make the HDD of death sounds, UNTILL i put it in a cooler then no more sounds and i still have it as a backup drive today
haggis
PostPosted: Tue Mar 07, 2006 11:20 pm    Post subject: Reply with quote
if you have data on your hdd that you'd rather not lose, you'd be wise to back it up onto a cd/dvd or another storage medium.
the drives are designed to work properly in static air, if they weren't then they would ship with active cooling + they wouldnt come with warranties icon_wink.gif
Bug
PostPosted: Sun Mar 12, 2006 4:37 pm    Post subject: Reply with quote
Check your hdd's. If theyre hot to touch you should increase air circulation. Dont pretend hdd's are built to handle all conditions these days, many drives crap out very easily due to heat related problems (wont mention any brands in particular but ive got one in mind).
[35 queries :: 0.06198 seconds ]
