Raptor Superchargers Project AU work ute
sly
PostPosted: Sat May 24, 2008 8:56 am    Post subject: Reply with quote
Best check whether his XR6 is a HP or a VCT Tim...
Raptorsc
PostPosted: Sat May 24, 2008 9:22 am    Post subject: Reply with quote
djcustom
As per the previous email, do you have a HP or a VCT? VCT is fine we can handle that.
djcustomcomputing
PostPosted: Sat May 24, 2008 6:44 pm    Post subject: Reply with quote
sorry i didnt post that info
i didnt relise there was two diff types is there anyway of finding out.
thanks for the quick reply
P.S. i was just looking into it for the future. dont want it quite yet.
sly
PostPosted: Sat May 24, 2008 9:30 pm    Post subject: Reply with quote
If your XR6 has a live rear axle it's a HP. If it has IRS it's a VCT. Also, the VCT engine will have "VCT Intech" across the front of the rocker cover above the thermostat cover!
djcustomcomputing
PostPosted: Sun May 25, 2008 7:26 pm    Post subject: Reply with quote
its only got 4.0 intech on the rocker cover
so i guess that means its a hp icon_sad.gif icon_sad.gif 8 less kws
sly
PostPosted: Sun May 25, 2008 10:52 pm    Post subject: Reply with quote
80kg less in the rear suspension. Performance difference is only a bee's d**k.
djcustomcomputing
PostPosted: Mon May 26, 2008 12:09 pm    Post subject: Reply with quote
less handling though
badcooky
PostPosted: Mon May 26, 2008 6:51 pm    Post subject: Reply with quote
So if you put in a Raptor you'll gain a 100kw at the crank,so i don't think you'll miss that 8kw one bit.
Raptorsc
PostPosted: Sat May 31, 2008 7:50 am    Post subject: Reply with quote
Having less kw is the point of adding it in the first place, to PUMP IT UP icon_biggrin.gif
Actually with boost they all pretty much produce indentical power
Raptorsc
PostPosted: Mon Jun 16, 2008 7:10 pm    Post subject: Reply with quote
The AU ute is going really well, couldn't be happier with the performance, I have fitted the new generation mounting bracket and know for certain it fits up just sweet.
On sat afternoon I headed out with dirtbike in back of ute for a bit of recreation, about 10 mins out and a couple of young dudes in a Commy VY S decide they are not going to be following a Ford for anything, they made a few risky moves so I just waited for the right time ....... we both ended up behind a truck with me behind the VY and truck in front of that. Now I know the road pretty good so just waited ......... a long straight coming up .... this would be the decider icon_biggrin.gif, they pulled out and over took the truck .... I stayed out and over took them also ....... with ease and they had not 1kw left that they weren't using.
All I can say is they were completely owned in no time flat by a loaded up "stock" AU ute icon_biggrin.gif
This kit will not disappoint, the bang for buck is UNREAL
AU99
PostPosted: Tue Jun 17, 2008 1:58 am    Post subject: Reply with quote
hahahaha that would have been a classic moment lol
Raptorsc
PostPosted: Wed Jun 18, 2008 8:06 pm    Post subject: Reply with quote
Yep, the Lions roar didn't come within a bulls roar of the Falcons roar lol
Raptorsc
PostPosted: Thu Jun 19, 2008 7:41 pm    Post subject: Reply with quote
Ute is in for Auto service and S5 Solenoid adjustment tomorrow .......... then all being well .......... the TEST AND TUNE woo hoo icon_biggrin.gif
Raptorsc
PostPosted: Fri Jun 20, 2008 6:53 am    Post subject: Reply with quote
Gave the ute an oil change the other day, went over to Castrol Edge 5/30 synthetic, have been very impressed with the oil in our other car so the Falcon copped it too.
It is a light weight but pretty suitable for a lot of the short running we do and seems to maintain good oil pressure even when its been hammered. Confident this is a good thing, will see if any change in consumption due to it being thinner.
sly
PostPosted: Fri Jun 20, 2008 4:31 pm    Post subject: Reply with quote
Pretty sure Castrol Edge is what used to be called "Formula R". I've used that in 5W30 for some 80,000 km of my car's 340,000 km so far, as heavier grades cause a noticeable drop in performance. The recommended oil in Series 1 AU's is 5W30 BTW. I'm not sure when it changed but the oil cap in our Series 3 says 10W30 or 10W40.
As long as the consumption is OK as you say, you shouldn't have any issues with it. I switched back to it at my last change in preparation for bolting some extra power on... have been monitoring the level and no issues so far. Dunno what happened with the last lot of disappearing oil icon_confused.gif
sly
PostPosted: Fri Jun 20, 2008 4:37 pm    Post subject: Reply with quote
Just out of curiosity Tim, did the tuner get to the bottom of what was happening with the manifold butterflies flattening power when they switched over? What RPM did they end up switching over at?
Raptorsc
PostPosted: Sun Jun 22, 2008 7:03 pm    Post subject: Reply with quote
Sly
The only happened the day we did part of the tune, we thought it fltattened out but in the dyno charts which I posted here someplace you can see exactly how it panned out. icon_smile.gif
Raptorsc
PostPosted: Mon Jun 23, 2008 8:08 pm    Post subject: Reply with quote
Well the AU went into the automatic doctor for the big check up. I wasn't totally happy as it was flaring way too much so decided at 135 000km it could go a serious service. They asked what I wanted to achieve and I said I just want it to shift properly without flaring.
They pulled the valve body out, adjusted/shimmed the clutches which they claim were never correctly adjusted at the factory in the first instance, then tested all the solenoids and tossed out the S5 and replaced with a new item.
Refilled trans with Penrite Synthetic trans fluid (complete flush as well).
Then they wired in a trim pot and installed that on the dash, haven't looked to see where the wires go yet. They said just turn it until you get the firmness you want, fully CCW is stock and full CW is maximum firmness, well I selected 5/8 of a turn and went for it ......... the thing shifts to perfection, like crisp as ...... absolute perfection.
Extremely happy with results but it didn't come cheap. All up the bill came to $807 and about half split on parts/labour.
Raptorsc
PostPosted: Mon Jun 23, 2008 8:10 pm    Post subject: Reply with quote
Final comment on the last post, I think anyone who doesn't arrange something similar will not get the best from their supercharger install, there is just too much torque at the shift point for the stock auto as it is setup.
I think next thing to organise now is a 6000rpm tune with 5800 shift points, this little combo with auto shifting like it is should run some nice numbers for a low buck system.
cboz
PostPosted: Mon Jun 23, 2008 10:45 pm    Post subject: Reply with quote
Hi mate, I take it the charger kit will completely muder a stock t5 manual even with HD clutch?
Page 5 of 6
[47 queries :: 0.05263 seconds ]
