Age:33 Posts: 621 Joined: 14 Dec 2007 Location: delegate NSW, Australia
Posted: Sat Jun 28, 2008 11:12 pm Post subject: |
| TROYMAN wrote: | you seem to have most of it covered..
but if your using the ef/au water pump the outlet is smaller than the eb one..
so you need to use a ef/el radiator or at least the ef tank as the bottom hose on the eb is larger than ef/el you can rig up an adaptor to go from small hose to a larger hose but if your still sourcing parts it would be best to get the ef/el radiator... |
I will be using an EB radiator, at least in the short term. I have a section of EL hose, and my first idea is to see if the EB lower hose fits over this. If so i can probably just clamp them, using two hose clamps for extra measure. |
TROYMAN Technical Contributor
Age:34 Posts: 2652 Joined: 07 Nov 2004 Location: South Western Sydney NSW, Australia
View User Gallery (29)
Posted: Sun Jun 29, 2008 12:03 am Post subject: |
| relaxed_diplomacy wrote: | | TROYMAN wrote: | you seem to have most of it covered..
yes the eb hose will fit over the ef hose..
i did that when i was using the ef radiator with the ea water pump.
but in your case its the opposite way around. but the same idea.you can fit a short piece of ef hose onto your water pump then slide the eb hose over the piece of ef hose and clamp it up.
also im not sure if i mentioned it before but the factory eb radiators dont have the mounting holes for the thermo fans. |
Age:36 Posts: 1100 Joined: 23 Dec 2007 Location: Perth WA, Australia
View User Gallery (24)
Posted: Sun Jun 29, 2008 2:14 am Post subject: |
| I also have an ED motor with an EF radiator and thermos and the hose works fine with a good clamp. |
Posted: Sun Jun 29, 2008 7:55 pm Post subject: |
| TROYMAN wrote: | yes the eb hose will fit over the ef hose..
but in your case its the opposite way around. but the same idea.you can fit a short piece of ef hose onto your water pump then slide the eb hose over the piece of ef hose and clamp it up. |
Great, and perhaps slightly more reliable even than your scenario because the water pump tube is a stiffer base than the plastic tube of the radiator.
| Quote: | | also im not sure if i mentioned it before but the factory eb radiators dont have the mounting holes for the thermo fans. |
Oh bugger. I guess it's something that can be worked out? Any suggestions?
In the short term i really would like to use one of my EB rad's, in the long term i might get an EF/EL H/D one (3 core). |
Posted: Sun Jun 29, 2008 8:01 pm Post subject: |
| relaxed_diplomacy wrote: | | TROYMAN wrote: | yes the eb hose will fit over the ef hose..
yes it would be better..although i had mine on there for about 12 months and there was no probs at all..
i guess you could make a couple of small bracket and mount the fans to the top of the radiator core??
iv even seen some people cable tie the fans to the radiator..
i would rather do it right but you could make something up to get by.. |
badcooky Fordmods Tyre Shredder
Posts: 315 Joined: 27 Jan 2007 Location: Toowoomba QLD, Australia
Posted: Sun Jun 29, 2008 8:41 pm Post subject: |
| You are swapping your car for a digital camera? |
Posted: Sun Jun 29, 2008 8:52 pm Post subject: |
| badcooky wrote: | | You are swapping your car for a digital camera? |
Ha Ha . . . . . . . no. |
Posted: Wed Jul 02, 2008 9:56 pm Post subject: |
| I have made a few mod's to my "updated list" and placed it at the top of page 1. |
Posted: Thu Jul 10, 2008 10:20 pm Post subject: |
I've just got an AU motor and some parts. Some questions have arisen . . .
1. There is no alternator. There is one bolt hole in the block, one in the sump, and behind these is a metal bracket held on by two bolts. Does the AU alternator bolt directly to these, or am i missing a bracket? Can i use my EL alternator?
2. There is no water pump. Is the EL water pump the same?
3. Other fordmodders have swapped the upper inlet manifold for an EL item. Are they swapping the upper section of the inlet tubes, or just the single inlet where the throttle, ISC, etc is? Why?
4. Do i fit an EF/EL a/c compressor onto the AU bracket, or onto an EF/EL bracket? On casual inspection the AU bracket looks like it might make the dizzy a tight fit, or interfere. |
Steady ED Fordmods Addict
Age:22 Posts: 6865 Joined: 01 Jun 2005 Location: Melbourne VIC, Australia
Posted: Thu Jul 10, 2008 10:42 pm Post subject: |
Can't help you on 1,3 and 4 cause I've been drinking, but as for 2, EF to BF (probably FG as well? who knows) all use the same waterpump.
So EL pump will be fine. |
Posted: Fri Jul 11, 2008 12:19 am Post subject: |
| Steady ED wrote: | Can't help you on 1,3 and 4 cause I've been drinking, but as for 2, EF to BF (probably FG as well? who knows) all use the same waterpump.
Beauty, thanks for answering no. 2
They say they take them off because they can fail and they would like you to fit a new one re: overheating and warranty. But s**t i have one that's only done 96k.
Last edited by relaxed_diplomacy on Mon Jul 14, 2008 11:31 am, edited 1 time in total |
Posted: Fri Jul 11, 2008 10:06 pm Post subject: |
| Quote: | | 1. There is no alternator. There is one bolt hole in the block, one in the sump, and behind these is a metal bracket held on by two bolts. Does the AU alternator bolt directly to these, or am i missing a bracket? Can i use my EL alternator? |
I just looked at a pic of a BA alternator and mounts and it looks exactly the same as my AU. I can't see how an EL alternator or bracket can fit the AU block. I don't really want to have to buy another alternator, any suggestions?
| Quote: | | 3. Other fordmodders have swapped the upper inlet manifold for an EL item. Are they swapping the upper section of the inlet tubes, or just the single inlet where the throttle, ISC, etc is? Why? |
| Quote: | | 4. Do i fit an EF/EL a/c compressor onto the AU bracket, or onto an EF/EL bracket? On casual inspection the AU bracket looks like it might make the dizzy a tight fit, or interfere. |
5. I was supposed to get the wiring and relays (fuses too?) with my thermofans but i did not. They tell me they don't do pre-AU falcons anymore, but can give me the stuff from an AU if i want. Can i use AU wiring/relays/fuses with my EL thermofans? |
fairmont1 Fordmods Stock as a Rock
Posts: 108 Joined: 05 Jan 2008 Location: Egg SA, Australia
Posted: Mon Sep 01, 2008 12:29 pm Post subject: |
| just buy 3 relays/holders/fuses and a tridon thermo switch and a t peice adaptor if its a fairmont and some wire and make up a davis craig diagram using twin fan thermo/single fan condensor |
Posted: Thu Sep 11, 2008 9:50 pm Post subject: |
I'm back! Circumstances saw me put the project on hold.
I practised with my new MIG on my trailer, then did the first stage of modding the front crossmember thingy on the EB. I added a piece of 3"x1" in front of the original square section bar, then removed the middle section of the square bar to provide clearance for the alloy sump. I got the front radius rod bushs smoking and flaming doing this, bummer, they were worn anyway, but i still hope they hold up for a while.
While i was at it i noticed the K-frame is slightly bent. I bought the car with a ding, and, well, i'm learning about it. It seems that the chassis rail has sprung back more than the K-frame. I could have swapped in the K from my spare car, but that would be a lot of work. The bend isn't much, i can live with it, it's not a show car by any stretch of the imagination.
| fairmont1 wrote: | | just buy 3 relays/holders/fuses and a tridon thermo switch and a t peice adaptor if its a fairmont and some wire and make up a davis craig diagram using twin fan thermo/single fan condensor |
I'm putting in an EL ecu and plan to run the fans from that. I have read that the Davies Craig stuff only runs the fans either on or off, there are no middle settings as there are with the EL ecu. |
Posted: Fri Sep 12, 2008 9:57 pm Post subject: |
I did some engine work today and everything is going to plan. There's still a fair bit more to go.
I am confident that the EL alternator bracket and alternator has not a chance in hell of being fitted to the AU block, without doing engineering adaptation. I'd rather not go there. So unless anyone has any ideas i'm thinking i will need to get an AU alternator.
I have also learnt that the dizzy will not fit in conjunction with the AU A/C bracket. I am reliably informed that i should use an EF A/C compressor, so i am thinking i am also to use an EF A/C bracket, and that it will clear the dizzy. At least an EL bracket must surely clear the dizzy, at it would have to in an EL. Hang on, i have an EL bracket, or i should do, or is it the same as the EB and XG brackets? |
Posted: Sat Sep 13, 2008 9:01 pm Post subject: |
I did some more work today.
COIL - I tried to fit the coil using the two inner manifold bolts but the plug for the coil and a plug going into the manifold clashed. So i plan to use some 25mm x 3mm flat plate between one of the manifold bolts and the unused engine mount bolt hole, and mount the coil accordingly.
BA AIRBOX - I also fitted a BA airbox today. The inner guard needs to be hammered down a tad for the airbox to fit. I located the spot that needed work, then placed a piece of carpet like stuff over the metal to prevent damage to the paint, scratches, sharp dints, etc. I then picked up a say 2 to 2.5kg square headed, short handled mallet. The weight means you don't have to have a big swing, and the broad head reduces the chance of sharp dents. I gave the spot a soft tap first to judge what was required, then a harder tap. This did most of the job, creating a dimple about 4" in diameter and about 15 to 20mm deep. I then needed to expand the dimple off to one side, and then another side as well. The airbox then fitted as if it was designed for the car, bolting up to the existing bolt holes and looking designed for the location.
LPG MIXER - I tried to fit the mixer between the throttle body and the first section of plastic pipe (BA), but just couldn't make it work. So i fitted the mixer between the end of the first pipe and the flexible tube. The BA piping is impressively big all the way, except the snorkel mouth looks a bit small compared to the bigger options i've seen on this forum.
EBII ISC - I fitted a cleaned EBII ISC to the throttle body, using a gasket with only approximately 2mm holes in it. From memory the holes are small because otherwise the idle speed isn't managed correctly. From memory 2mm holes are about right, but i should have checked this to be sure.
WIRING HARNESS - I took some of the shrouding off the EBII wiring harness to free up some wires, and at the moment it looks like i might not have to do any other modifications, but i'm not 100% sure yet as the starter motor isn't fitted. |
Posted: Mon Sep 15, 2008 8:26 pm Post subject: |
I've now completed fitting the EBII engine wiring harness to the AU motor.
I didn't have to extend or modify any wires or plugs! |
Posted: Mon Sep 15, 2008 8:39 pm Post subject: |
| relaxed_diplomacy wrote: | I've now completed fitting the EBII engine wiring harness to the AU motor.
thats good..
ive noticed that some looms have a slight difference in length.
as recently a few of us did a conversion on a eb and other than the tps and isc the rest of the wires didnt need to be extended at all.
but in other cases ive seen where the coil wire,starter wire had to be extended aswell.. |
Posted: Mon Sep 15, 2008 9:27 pm Post subject: |
| TROYMAN wrote: | | relaxed_diplomacy wrote: | I've now completed fitting the EBII engine wiring harness to the AU motor.
thats good..
I did have to take a small amount of the shrouding off, and re-shroud of course. I fitted the main loom in the valley of the bbm, of course. I am probably more patient than most people and that may have been the difference.
I have two EBII looms and they look basically the same, but i didn't check exact wire lengths. |
BenJ Cruise Moderator
Posts: 1275 Joined: 20 May 2005 Location: Seven Hills, Sydney NSW, Australia
I agree, as Troyman and I found out, our two looms needed different adjusting, so there is some variance in the EB Looms.
BenJ |
[47 queries :: 0.10138 seconds ]
