re-programme remote
surfn
PostPosted: Fri Feb 09, 2007 10:17 am    Post subject: re-programme remote Reply with quote
My remote is no longer working, have reprogrammed in the past, but i foget the sequence, can anybody help ??
Jinxed
PostPosted: Fri Feb 09, 2007 10:56 pm    Post subject: Reply with quote
Adding and Removing remote Keypads to the Smartlock module
Up to four Keypads can be programmed and used with the Smartlock Remote Central locking system.
If you have replaced the BEM, or new keypads are being added to the system, you will need to train the keypad codes to the module.
# 1. The ignition switch should be in the Off position, with all the doors shut and Unlocked.
# 2. Turn the ignition key to the ACCESSORY position and within 5 seconds, operates the rear demister switch exactly three times in quick succession.
(IE. Press the switch so the Demister light turns on, then off, then back on again.)
# 3. After the 5 seconds is up, the door locks will change state, to indicate that the BEM has entered keypad learn mode.
NOTE : All existing keypads at this point, have been erased from memory !
# 4. Press either buttons on the keypad that is to be trained. The door locks will change state twice, to indicate that the keypad has been added to the BEM memory.
# 5. Follow step 4. for each keypad that is to be added to the BEM memory. A maximum of 4 keypads can be added to the BEM memory.
NOTE : You must teach all remote keypads for the Smartlock module, before proceeding.
# 6. When you have taught all the remote keypads, turn the ignition to the Off position to leave the learn mode. The door locks will change
state to indicate a return to normal mode.
# 7. Check the function of both buttons on each keypad, to ensure that the keypad has been trained.
surfn
PostPosted: Tue Feb 13, 2007 11:08 am    Post subject: Reply with quote
Thanks mate, if i was a smart bloke i would have checked around, seeings there are a number of posts already on this. thanks
Jocool
PostPosted: Tue Apr 24, 2007 7:33 pm    Post subject: Reply with quote
I own a Falcon and a Fairlane. Can I get both cars to work with the one remote?
sexyr6
View User Gallery (25)
PostPosted: Tue Apr 24, 2007 8:19 pm    Post subject: Reply with quote
yes.
SHADOW_351
PostPosted: Wed May 16, 2007 9:57 pm    Post subject: Reply with quote
will you unlock both cars get in one and drive away leaveing the other unlocked?
or unlock both cars get in one lock both cars and drive off?
seems like a bit of f**k around
Hyena
PostPosted: Fri May 18, 2007 2:37 pm    Post subject: Reply with quote
On a related note, a flat battery shouldn't cause a remote to stop working should it ?
Mine went flat months ago and I just used the key in the mean time. I replaced the battery today and the light now comes on brightly but the doors don't unlock. I'll try the above learning method but I thought that was more a case of BEM learning the remote not vise versa...
Waggin
Site Admin
PostPosted: Sat May 26, 2007 3:36 pm    Post subject: Reply with quote
No, they should work still! The remote codes are stored in some type of non volatile memory in the BEM.
Leroy
PostPosted: Sun May 27, 2007 3:11 pm    Post subject: Reply with quote
we have a lot of AU's that lose coding when the battery has been flat, or the battery holder coming unstuck(AUII owners will know what i mean), for a long time.
Hyena
PostPosted: Sun May 27, 2007 6:01 pm    Post subject: Reply with quote
I followed the above procedure and it works again now. Curious...
gpkitchu
PostPosted: Thu Jun 14, 2007 11:59 am    Post subject: Tried the steps and didnt work Reply with quote
Hi, Im new to using Ford Falcon AU (year 2000) car and the car came with no remote. So i just bought the new remote from Ford dealer and followed the steps mentioned above.
It worked until Step 3.
The above step 4 is not working for me icon_cry.gif I even tried with different options like, keep the remote bit close to the key, or bit distance. The door locks didnt change to any state. I keep the LOCK or UNLOCK button the keypad for more than 5 seconds too. Nothing is changed.
#5 is works as usual that when i switched off.
Can you someone please explain, whether i am doing wrong? Thanks in advance.
Leroy
PostPosted: Thu Jun 14, 2007 12:01 pm    Post subject: Reply with quote
take it to rhe dealer who you bought it off and get them to do it for you.
make sure they gave you the right remote. 2000 was the year they changed so you may of gotten the wrong one.
Froggy_Spawn
PostPosted: Sat Sep 08, 2007 11:22 pm    Post subject: Reply with quote
just done this on an EBII it was'nt the rear demister switch 3 times
it was the boot release 3 times
Brice
PostPosted: Sun Sep 16, 2007 11:52 am    Post subject: Reply with quote
I have tried all of the above and still can't get this one to programme.
Any ideas?
Thanks
Brice
[41 queries :: 0.05301 seconds ]
