fordnuttz Fordmods - Getting Side Ways
Posts: 485 Joined: 17 Feb 2006 Location: Mount Gambier/Adelaide SA, Australia
Posted: Sun Sep 28, 2008 4:50 pm Post subject: Regulator problems |
I have been having trouble with my headlights blowing. I tested the lights and they are at 14volts. When under load they go to 13.5. I was told the maximum for lights should be 12volts.
Is my regulator stuffed and where abouts is it located so it can be replaced? |
GTO13F Fordmods Tyre Shredder
Age:21 Posts: 323 Joined: 07 Sep 2008 Location: Blactown, sydney NSW, Australia
Posted: Sun Sep 28, 2008 4:55 pm Post subject: . |
| theres a group buy in FOR SALE for new ones i suggest getting sum. |
racer Fordmods Stock as a Rock
Age:38 Posts: 107 Joined: 16 Jul 2007 Location: sydney NSW, Australia
Posted: Sun Sep 28, 2008 5:28 pm Post subject: |
OK. First don't touch the glass it's a no no. If you do wipe it with a dry cloth very good.
Second maybe you are using cheep globes. Try using philips globes they are a number 1 product.
Third maybe you mite have a intermintant over charging problem.
Last but not leased check the headlight plugs if they are overheated or loose.
GOOD LUCK. |
luthor Fordmods Parts Gopher
Posts: 51 Joined: 13 Mar 2007 Location: Melbourne VIC, Australia
Posted: Sun Sep 28, 2008 8:45 pm Post subject: |
| Your regulator is working OK at 14 volts, the person that told you 12 volts max. is dreaming. |
Age:21 Posts: 2320 Joined: 22 May 2006 Location: Ballarat VIC, Australia
Posted: Sun Sep 28, 2008 9:37 pm Post subject: |
| luthor wrote: | | Your regulator is working OK at 14 volts, the person that told you 12 volts max. is dreaming. |
are you feeling ok? i just had a mates car throw a reg, and the dash and voltages were through the roof!
13.5v is max |
Posted: Sun Sep 28, 2008 9:48 pm Post subject: |
| racer wrote: | OK. First don't touch the glass it's a no no. If you do wipe it with a dry cloth very good.
GOOD LUCK. |
I am using plus 50s which are a $35 globe so no they not cheap. And i know not to touch the glass and the plugs are fine.
So my reg being at 14v means it's no good and could be causing the problem? |
Posted: Sun Sep 28, 2008 9:53 pm Post subject: |
| might be ok, but it should only charge that high just after the car has started |
Posted: Sun Sep 28, 2008 10:52 pm Post subject: |
| fiftyone wrote: | | luthor wrote: | | Your regulator is working OK at 14 volts, the person that told you 12 volts max. is dreaming. |
13.5v is max |
Oh boy, another "Space Cadet" |
