aristopwr Fordmods - Smokin em up
Posts: 214 Joined: 23 Nov 2007 Location: Brisbane QLD, Australia
Posted: Thu Jun 26, 2008 1:34 pm Post subject: replacing fuel sender unit help |
I was wondering if the 6cyl and the v8 fuel tank sender units are the same?
Thanks in advance! |
Age:24 Posts: 3573 Joined: 13 Mar 2006 Location: Dubbo NSW, Australia
Posted: Thu Jun 26, 2008 2:03 pm Post subject: Re: replacing fuel sender unit help |
| aristopwr wrote: | I was wondering if the 6cyl and the v8 fuel tank sender units are the same?
only guessing i think the sender may be the same but fuel pump i think not. |
Posted: Fri Jun 27, 2008 7:07 pm Post subject: |
| what about ED and EF/EL? Are they interchangeable at all? The sender unit itself,not the pump.. |
Posted: Fri Jun 27, 2008 8:17 pm Post subject: |
| pretty sure that the senders from EA>ED are the same and EF>EL are same but they aren't interchangable ... the pump is but not the sender. wagons on the other hand quite possibly |
Posted: Sat Jun 28, 2008 2:13 pm Post subject: |
so would anyone know if they can be repaired since they are no longer available from ford?
Cheers. |
Posted: Sat Jun 28, 2008 5:46 pm Post subject: |
| aristopwr wrote: | so would anyone know if they can be repaired since they are no longer available from ford?
Cheers. |
I wouldn't bother i would just take a trip to ya local wreckers and pruchase a 2nd hand sender.... what makes you think you have sender problems |
Posted: Sat Jun 28, 2008 7:53 pm Post subject: |
| Guage shows either completely full or empty regardless of how much is actually in the tank.. |
