Replacing the lpg switch/gauge on my dash
MooG
PostPosted: Fri Mar 23, 2007 12:34 pm    Post subject: Replacing the lpg switch/gauge on my dash Reply with quote
Duel Fuel EL Falcon Gli, fitted with some aftermarket setup.
The meter on the dash is made of 4 green leds and 1 red one, but has long had problems with flickering on/off etc. Now it won't even light up at all.
On the unit in the dash it has 5 terminals: Ground, Sender, Petrol, Gas, 12v
And i have 4 wires, Brown, Red, White, and Red with a black stripe.
Is there any chance there's a wire gone missing or something? because 4 wires and 5 terminal is strange. which wires should hook-up to which terminals?
Is there any affordable way to simply replace this?
My friend has a tickford lpg system on his auIII that switches the petrol level over to gas when you switch.
I was considering a similar integration but would assume it'd be the more expensive path?
thankyou
Disco Frank
PostPosted: Fri Mar 23, 2007 1:06 pm    Post subject: Reply with quote
MooG
PostPosted: Fri Mar 23, 2007 1:34 pm    Post subject: Reply with quote
any idea of a rough price?
Brett3158
PostPosted: Fri Mar 23, 2007 3:06 pm    Post subject: Reply with quote
Some switch/gauges are around $100. Dont know about the price for yours. I would have a good look for a loose wire before going further though. Which terminal is spare?
twr7cx
PostPosted: Fri Mar 23, 2007 3:52 pm    Post subject: Reply with quote
I have the same unit, with the 5 terminals, green leds and one red, etc. I also only have 4 wires on it - so that sounds right.
Walker
PostPosted: Fri Mar 23, 2007 4:42 pm    Post subject: Reply with quote
Me 3, on the EF that is.
From memory the 5th is only a double terminal to the one next to it.
It would help knowing what area of Melb you are from so we could send you to someone close.
MooG
PostPosted: Fri Mar 23, 2007 5:40 pm    Post subject: Reply with quote
Crib Point, down Mornington Peninsula
gogetta
PostPosted: Fri Mar 23, 2007 6:54 pm    Post subject: Reply with quote
whats the switch look like
is the style that goes in the dash on the same little panel as the demister or is it a little black box with a switch mounted separately onto the dash?
and i would say you would need all five wires for the switch to work right...
also if its just the guage playing up it could be the sender on the tank
hard driver
PostPosted: Tue Mar 27, 2007 8:07 am    Post subject: Reply with quote
u can interface it with your fuel gauge if u like .is it just up were your demister is? u just put a relay in your fuel gauge wire from your tank will try to get the wireing diagrame if u like. on any for before ba u can inteface the lpg gauge.u will need wire a new gas tank gauge to give it the same resistance as your fual gauge which is a 2- 176 and a 5 pin relay.
[36 queries :: 0.04398 seconds ]
