Surfer Fordmods Newbie
Posts: 5 Joined: 03 May 2008 Location: Adelaide SA, Australia
Posted: Tue May 13, 2008 8:41 pm Post subject: rf timming still out |
Hi al
Still having problems with my ef there must be away to adjust the timming I short the pins on the conrctor under the dash which puts it into Test mode mode then what
Age:25 Posts: 3379 Joined: 11 Nov 2004 Location: townsville QLD, Australia
Posted: Tue May 13, 2008 9:48 pm Post subject: |
you can not adjust the timing on 6cyl EF falcons.
IF the timing is wrong you have other issues that need to be sorted |
spaniad Fordmods Oompa Loompa
Age:19 Posts: 39 Joined: 09 Jul 2006 Location: melbourne VIC, Australia
Posted: Wed May 14, 2008 8:07 pm Post subject: |
| timing all controled by the ECU , computer adjusts the timing depending on egnine conditions |
Age:22 Posts: 2265 Joined: 07 Nov 2004 Location: Perth WA, Australia
Posted: Fri May 16, 2008 12:11 am Post subject: |
thats exactly right ^^ what they said.
its possible that your crankshaft pulley / harmonic balancer have slipped, which will cause incorect timing as the ecu uses a toothed wheel on this pulley to get its timing from.
there are a few other things as well.
why do u want to adjust it?? is there an issue? |
Posted: Sat May 17, 2008 10:44 am Post subject: |
| whats the problem exacly ? you might have a bad sensor or maybe your coil pack is playing up |
Posts: 2757 Joined: 08 May 2007 Location: Sunny QLD, Australia
Posted: Sat May 17, 2008 10:52 am Post subject: |
| xpression wrote: |
its possible that your crankshaft pulley / harmonic balancer have slipped, which will cause incorect timing as the ecu uses a toothed wheel on this pulley to get its timing from. |
That wont be it cause if the balancer slips, its just the outside rubber with the mark on it, meaning the inner sensor pickup is unaffected.
But having said that, if a cam is setup against the slipped mark then that could be an issue |
