AdamN Fordmods - Getting Side Ways
Posts: 1310 Joined: 12 Dec 2005 Location: Perth WA, Australia
Posted: Thu Oct 05, 2006 10:38 pm Post subject: |
| Try jaycar or altronics... you can get everything you want from them.. and they even deliver if so choose. |
stiffi Fordmods Newbie
Age:20 Posts: 10 Joined: 02 Aug 2006 Location: melbourne VIC, Australia
Posted: Thu Oct 26, 2006 1:54 pm Post subject: |
ok ive read over this and love the idea i went and got the parts although there where no 10watts so i got 2 5 watts to match it bla bla
but i read over this topic and saw this was already brought up but the answer didnt really lead to anywhere.
if join them together to make 10 watts will it double the ohms as well? or more importanly will it work if i join both together to make 10 watts? |
xf_xr6 Fordmods - Smokin em up
Posts: 244 Joined: 29 Oct 2005 Location: Perth WA, Australia
Posted: Sat Oct 28, 2006 8:49 am Post subject: |
I tried this in my car (el). After a few months the gearbox shat its self and had to get a full rebuild.
Has anyone else had reliability issues?
It was fun while I had it though... |
jim_reaper Fordmods Oompa Loompa
Age:19 Posts: 26 Joined: 02 Aug 2006 Location: Mandurah - Perth WA, Australia
Posted: Mon Oct 30, 2006 3:25 pm Post subject: |
use the two resisters in parralel and it will double wattage and halve the ohms.
eg to get the equivelant of 10 16ohm
you need 2x 5W 32ohm in parralel with each other |
MooseMan Fordmods - Getting Side Ways
Age:21 Posts: 2256 Joined: 03 Dec 2004 Location: Melbourne VIC, Australia
Posted: Mon Oct 30, 2006 4:09 pm Post subject: |
| Im utterly hopeless with a soldering iron. Last time I used one was year 7 electronics at school and im pretty sure I failed. Anyone want to help me out and put one in for me in northern suburbs of melbourne? |
| DELETE ME F.A.GS! |
stomper Fordmods - Getting Side Ways
Age:18 Posts: 2983 Joined: 15 Apr 2006 Location: Aberfoyle Park SA, Australia
Posted: Mon Oct 30, 2006 8:04 pm Post subject: |
| MooseMan wrote: | | Im utterly hopeless with a soldering iron. Last time I used one was year 7 electronics at school and im pretty sure I failed. Anyone want to help me out and put one in for me in northern suburbs of melbourne? |
Deposit $35 into my acount and ill build you one and post it over to you.
I built them before and i have almost finished the doco on it.
You can install you self, as long as you know how to read a number higher then 10 and know where a ecu is. You dont have to solder it to the ECU because u maybe beable to crimp it in. EASY |
shoey50 Fordmods - Getting Side Ways
Age:23 Posts: 634 Joined: 10 Nov 2004 Location: sale VIC, Australia
Posted: Thu Nov 16, 2006 9:53 am Post subject: |
| so has anyone managed to make one with an on and off light? |
Posted: Thu Nov 16, 2006 10:05 am Post subject: |
| shoey50 wrote: | | so has anyone managed to make one with an on and off light? |
YEP
I done it. Ill get some photos up when i have a chance.
I used a DPDT switch. 3 of the ples were used for the shift kits its self. The other 3 i put 12v + in to the middle then on the outer poles i had a superbright green LED with a resistor and a red LED for off. That way when the shift kit is on it is Green and bright and you know about it. When it is off its red and not so bright. |
Posted: Thu Nov 16, 2006 10:18 am Post subject: |
| wicked do ya think you could chuck up a bit of i diagram if you havnt already i really wanna but a light on cheers mate |
Posted: Thu Nov 16, 2006 11:31 am Post subject: |
Make sure you put a 560ohm resistor in the redpower line. Without this you will burn the LED's |
falcon_3512003 Fordmods - Smokin em up
Age:37 Posts: 236 Joined: 28 Nov 2006 Location: se melbourne VIC, Australia
Posted: Wed Nov 29, 2006 9:28 pm Post subject: |
| neby hear hi guyd made one of these kits today the great but i wouldnt mine a bit harder shift any idias on what resistors to change to |
Posted: Wed Nov 29, 2006 9:37 pm Post subject: |
| EF/EL bump the 5.6ohm up slightly. That will make it firmer IIRC. |
Posted: Wed Nov 29, 2006 9:56 pm Post subject: |
| whats slightly to a 6.0 or higher ? |
Posted: Thu Nov 30, 2006 12:55 am Post subject: |
| a mate of mine has a auxr8 is the set up the same at the ecu as in 71 and 81 wires to use ? |
Posted: Thu Nov 30, 2006 1:04 am Post subject: |
| im pretty sure that the 8's have a seperate ecu, so short answer is no! |
Posted: Thu Nov 30, 2006 8:57 am Post subject: |
| has anyone done this mod in a auxr8 if so whats the pins to use ? |
Posted: Thu Nov 30, 2006 11:36 am Post subject: |
| falcon_3512003 wrote: | | has anyone done this mod in a auxr8 if so whats the pins to use ? |
I remember seeing it somewhere. But im sure its different pins and different resistor values. |
Posted: Thu Nov 30, 2006 11:57 am Post subject: |
| ok dose anyone know were i can get the diagram then coz my mate wants this done now iv taken him for a spin in mine |
Posted: Mon Dec 04, 2006 9:04 pm Post subject: |
there is one on aufalcon.com.au but it means searching and i hyave had tooo many beers for that right now.  |
