Shift Kit - Do it yourself
Goto page Previous  1, 2, 3 ... 16, 17, 18, 19, 20, 21  Next
shoey50
PostPosted: Sun Dec 10, 2006 11:14 am    Post subject: Reply with quote
stomper wrote:
Make sure you put a 560ohm resistor in the redpower line. Without this you will burn the LED's
whats with the red and the green led i just want a simply little blue led to show when its on how would i do that and the 560ohm resistor how many watt ?
stomper
PostPosted: Sun Dec 10, 2006 12:38 pm    Post subject: Reply with quote
you will get away with a half watt resistor, thats whats used on the clusters. You can have a blue LED to show its on. Just take one of the LED's out of the circuit.
shoey50
PostPosted: Wed Dec 27, 2006 6:46 pm    Post subject: Reply with quote
ok just wired up the led to the switch put the 560ohm half watt resitor in the power line and i wanted to test it (havent wired the 3 shift kit wires to the switch yet) anyway hooked it up to the ciggy lighter ignition on and it didnt work tryed the led around both ways still no go so i hooked it up straight to the battery still no go tryed led around both ways replaced the led did it all again still no go! do the shift kit wires have to be wired up i thought not i just wanted to test it all before i assembled the whole lot any ideas what might be the go?
shoey50
PostPosted: Wed Dec 27, 2006 9:54 pm    Post subject: Reply with quote
got it figured dont matter but i burnt it out testing it on a 6v batterey testing it with no resistor opps!
Mr_Soul
PostPosted: Wed Dec 27, 2006 11:37 pm    Post subject: Reply with quote
would a similar setup work for a BA? cause i'm handy with a soldering iron... but wouldn't have a clue if it would work
ebfairmont3.9
PostPosted: Mon Aug 06, 2007 6:57 pm    Post subject: Reply with quote
Awesome stuff!! dads EF box dont slip from 1st to 2nd anymore lol
izedso
PostPosted: Tue Aug 07, 2007 11:59 am    Post subject: Reply with quote
Yup Yup!! Few hours with a soldering iron on sunday and $10 bucks later.
Makes for much fun, and pulls damn hard from first to second.
Thanks Neds.. your instructions are easy to follow and work better than I hoped. Good Work.
lil_lincoln
PostPosted: Tue Aug 07, 2007 3:29 pm    Post subject: Reply with quote
neds are you still using your shift kit?????
ED94V8
PostPosted: Thu Aug 09, 2007 8:20 pm    Post subject: Reply with quote
is this diagram the one i use for an Ed V8?
chancedingo
PostPosted: Thu Aug 23, 2007 6:03 pm    Post subject: Reply with quote
neds wrote:
got a small diagram that may help if someone can host it for me
mattcomm
PostPosted: Fri Aug 31, 2007 9:15 am    Post subject: Reply with quote
neds wrote:
Just had a look at the diagram for El's. It looks exactly the same, except pin 71 is actually pin 57, and pin 81 is pin 38. Other than that it should use the same resistors and the same setup.
i have a 91 eb 5lt with the le 4 spd. is the computer and, or the pinouts the same
for this model , it is a fairmont ghia if that makes a difference.
shannonwulff
PostPosted: Fri Aug 31, 2007 11:45 pm    Post subject: Reply with quote
pins would be different mate, but otherwise the circuit would be the same. wouldnt have a clue on the pinout though, try your gregories.
Blu Falc
PostPosted: Sat Sep 01, 2007 11:25 pm    Post subject: Reply with quote
the V8's have a seperate trans computer above the drivers left knee like EA's
the S5 wire to the TCM is on pin 7, and +12v on pin 29.
BeastyEF
View User Gallery (16)
PostPosted: Mon Oct 01, 2007 12:37 pm    Post subject: Reply with quote
Am deffinately doing this and refering this on only thing is i have to wait 3 more weeks but will do it before the Bathurst Cruise, yeehaa.
BenJ
PostPosted: Mon Oct 01, 2007 4:29 pm    Post subject: Reply with quote
Made my shift kit three weeks ago.
Makes a big difference from 1st to 2nd at full throttle. Bit harsh for every day use though.
But that is what the switch is for icon_smile.gif I built mine with the 22ohm and the 18ohm and can switch between them. I must say though, that there isn't really much difference between normal and the 22ohm setting.
BenJ
BeastyEF
PostPosted: Mon Oct 01, 2007 6:08 pm    Post subject: Reply with quote
Sounds good n yea ill tame my down a lil as i will have mine adjustable.
longlivethefalcon
PostPosted: Mon Oct 01, 2007 11:36 pm    Post subject: Reply with quote
Ok i went out to get the parts and the smallest 10w resistor i could find at Jaycar was 20 ohm and i need a 18 and 5.6 or did i read it wrong.
d**k smith only had 5w resistors.
Also to rig up the Leds it says to use a 560ohm resistor , but in what wattage ?? 1/2 1/4 1 5 or 10.
XR 1992
PostPosted: Thu Nov 15, 2007 10:29 pm    Post subject: Reply with quote
hey i wanna know how 2 make shift harder. Which resistors should i put in, currently 18ohm and 5.6 ohn and its soft.
random hero
PostPosted: Wed Nov 21, 2007 6:51 pm    Post subject: shift kit Reply with quote
is this the same for au series 1
smo el
PostPosted: Sun Dec 09, 2007 7:40 am    Post subject: Reply with quote
Quote:
Boys, boys, boys.
Any E-series V8 has a seperate transmisison controller - it was only the I6 that had transmission control intergrated with the ECU.
The trans control module is located under the dash, near your left leg.
Pin 7 on the TCM goes to the S5 solenoid. Pin 29 is the check line for the solenoid... 1ohm resistor for the solenoid, 20ohm for the check line...[/
To anuone who has done this to an el xr8, hopfully i dont sound too stupid but i thought i'd ask. just so i dont kill my trans
On an EL XR8 i use a 20ohm instead of a 18ohm, and a 1 ohm instead of a 5.6ohm. pin 7 is used instead of 71, and pin 29 is used instead of 81.
Cheers all
Page 17 of 21
[47 queries :: 0.06325 seconds ]
