Shift Kit - Do it yourself
Goto page Previous  1, 2, 3 ... 17, 18, 19, 20, 21  Next
znipa-x
PostPosted: Sun Dec 09, 2007 6:11 pm    Post subject: Reply with quote
smo el wrote:
Quote:
Boys, boys, boys.
Any E-series V8 has a seperate transmisison controller - it was only the I6 that had transmission control intergrated with the ECU.
The trans control module is located under the dash, near your left leg.
Pin 7 on the TCM goes to the S5 solenoid. Pin 29 is the check line for the solenoid... 1ohm resistor for the solenoid, 20ohm for the check line...[/
To anuone who has done this to an el xr8, hopfully i dont sound too stupid but i thought i'd ask. just so i dont kill my trans
On an EL XR8 i use a 20ohm instead of a 18ohm, and a 1 ohm instead of a 5.6ohm. pin 7 is used instead of 71, and pin 29 is used instead of 81.
Cheers all
what is 1ohm or 5.6ohm used for, I'm trying to figure out if the kit I have for a EF6 of AU6/8 is compatible with my EF8, I have a stage 2 shiftkit that has 18 ohms and 21 ohms, but I can't seem to find the 1 or 5.6 on any other wire combination, and there's only 3 wires coming out of the box.
also are the pin 7 and 29 you mention the pins on the TCM.
znipa-x
PostPosted: Mon Dec 10, 2007 6:31 pm    Post subject: Reply with quote
smo el
PostPosted: Fri Dec 14, 2007 7:44 am    Post subject: Reply with quote
pin 7 and 29 are from the TCM, but i'm not 100% what resistor goes with what pin.
speedwayR31
PostPosted: Sun Dec 30, 2007 11:12 pm    Post subject: Reply with quote
neds fantastic simple diagram of the shift kit even an old f@rt like me (57) can understand can you tell me if the au has the same numberd pins as the e series ecu===job well done===
znipa-x
PostPosted: Sat Jan 05, 2008 4:46 pm    Post subject: Reply with quote
mines in finally, 2 stage, and it works a treat, very postive gear changes, and not for the faint hearted with a lead foot, if anyone needs the wire colours, pin orientation and resistors I used for EF V8 (the one with the TCM) let me know.
danc666
PostPosted: Thu Jan 17, 2008 6:59 pm    Post subject: Reply with quote
Has anyone done this for a ba??? can you tel me which pins to use please?
moodyblues
PostPosted: Sat Feb 02, 2008 9:24 am    Post subject: kit Reply with quote
ey silly question is this the same for EB (series 2 fairmont)?
and does any one no wat colour the 2 wires are that come from the respective pins as i couldnt see number any where!!!
Thanks
Paulmac
PostPosted: Mon Feb 04, 2008 2:44 am    Post subject: Reply with quote
Mal,
Just a suggestion, read through the thread until you find someone with an EB2-ED that's done it. Click on the 'PM' button in that post and ask them directly.
Cheers,
Paul
moodyblues
PostPosted: Mon Feb 04, 2008 5:22 pm    Post subject: Reply with quote
Yeah i know i tried to read thru it as much as i could and could only find one instance where i believe even the person with the car and EB mont ser.1 wasnt sure wat was going on with his car TCM and such. if there is any one here who has done it to the EB ser.2 any help would be much appreciated@!
Paulmac
PostPosted: Mon Feb 04, 2008 5:44 pm    Post subject: Reply with quote
PM 'BenJ', he may be able to help you out, use the search button up the top.
Paul
xfpaul
PostPosted: Thu Feb 07, 2008 7:07 am    Post subject: Reply with quote
any problems after the mod , please report even the smallest ????
BenJ
PostPosted: Thu Feb 07, 2008 3:41 pm    Post subject: Reply with quote
I broke an Engine Mount under full throttle first to second. Chirped the wheels nicely.
BenJ
Paulmac
PostPosted: Thu Feb 07, 2008 6:15 pm    Post subject: Reply with quote
Ben, Ben...with a 400k klms engine, that's not a problem....that's bragging!!!!
Paul
syko4d
PostPosted: Sat Feb 16, 2008 4:07 pm    Post subject: Reply with quote
ok i just built eeryhing for my eb series 2 and i dont have a 38 pin its empty?
has anyone done this to a eb series 2 what pin did you use?
and yes its the 4 speed btr
i have pin 57 but no 38?
Paulmac
PostPosted: Sat Feb 16, 2008 4:17 pm    Post subject: Reply with quote
syko4d,
PM 'BenJ', 2 posts above and click on the pm button. Ben's becoming the EB guru on these things and will probably help you.
Paul
syko4d
PostPosted: Sat Feb 16, 2008 4:48 pm    Post subject: Reply with quote
yeah i did that thanx mate
AU99
PostPosted: Sat Feb 16, 2008 5:07 pm    Post subject: Reply with quote
wire up same as EF, hope that helps
Paulmac
PostPosted: Tue Feb 19, 2008 12:36 am    Post subject: Reply with quote
The pin numbers used for the EB-ED shift kit seem to be hard to find in this long thread, so I'll post this up to make them easier to find:
The 18 ohm resistor wire goes to pin 57
The 5.6 ohm resistor wire goes to pin 38
You can use a 20ohm resistor instead of the 18ohm to achieve a less harsh but still quick, change.
Cheers,
Paul
BenJ
PostPosted: Tue Feb 19, 2008 12:52 am    Post subject: Reply with quote
Small correction there Sir
The second resistor, is not 5.6ohms (which is for EF six only) it is 1.0ohm for the others, six cylinder only. V8s and EAs with separate TCM are different again.
BenJ
Paulmac
PostPosted: Tue Feb 19, 2008 1:04 am    Post subject: Reply with quote
Well done Ben, 16 mins for the correction! I win the bet by 4 minutes, I knew you'd pick it up in under 20mins!
I did mean to type the one ohm but I was laughing so much I screwed up and just as I was going to try to edit it your post caught me out.
So now I'm laughing even more... you see there were two dudes fitting a BBM and...oh well wrong thread, another time perhaps?
Cheers,
Paul
Page 18 of 21
[47 queries :: 1.23153 seconds ]
