edfairmont4.0 Fordmods - Getting Side Ways
Age:22 Posts: 480 Joined: 26 Sep 2007 Location: newcastle NSW, Australia
Posted: Sat Apr 26, 2008 11:59 pm Post subject: |
| BenJ wrote: | Hey, thanks for that - interesting
Might have to play around with my setup some more.
BenJ |
btw the 2.2OHM with the 18OHM is nice with an EL ecu... the eb-ed ecu its a bit more rough obviously the ef/el ecus have a programmed smoother shift. |
Posts: 3068 Joined: 31 Oct 2005 Location: . QLD, Australia
View User Gallery (28)
Posted: Sun Apr 27, 2008 9:27 am Post subject: |
| the shift kit doesnt make the gearbox change at different times it just speeds up the change, so if your gearbox holds onto a gear once you shift up then it will still do that |
dave0 Fordmods Stock as a Rock
Posts: 121 Joined: 09 Jan 2008 Location: syd NSW, Australia
Posted: Sun Apr 27, 2008 10:03 am Post subject: |
| aw ok what about the computer torque control? does it do anything to that |
BenJ Cruise Moderator
Posts: 1292 Joined: 20 May 2005 Location: Seven Hills, Sydney NSW, Australia
Posted: Sun Apr 27, 2008 10:13 am Post subject: |
Nope, all it does is make the shift firmer and faster.
BenJ |
Posted: Sun Apr 27, 2008 9:51 pm Post subject: |
well ive done it today and it has speeded up 2nd and 4th 3rd is still a bit slow have i done something wrong ?
i gave my mate the diagram and instructions since his a sparky and he wired it all up and took it for a drive and i notice second is a s**t load faster and then third is normal then fourth hits much quicker then it used to |
AU99 Fordmods - Getting Side Ways
Age:56 Posts: 469 Joined: 06 Jul 2006 Location: Craigmore SA, Australia
Posted: Tue Apr 29, 2008 5:35 pm Post subject: |
| sounds like a weak solanoid in the trans |
Posted: Tue Apr 29, 2008 6:19 pm Post subject: |
i just had the box changed today got a xr8 recon put in
still dosent shift hard just second |
Posted: Wed Apr 30, 2008 6:31 pm Post subject: |
| any one its really annoying habing it shift to second pretty quik and then 3rd is normal |
Posted: Thu May 01, 2008 11:52 am Post subject: |
| what resistors used? |
raff-26 Fordmods - Getting Side Ways
Age:26 Posts: 401 Joined: 05 Aug 2007 Location: melbourne VIC, Australia
Posted: Thu May 01, 2008 12:31 pm Post subject: |
stupid question....but what is a shift kit?
I took my V8 ghia EF for tranny service, and he told me it shifts firm- like its got a shift kit? what else does it do? and whats the advantages??? |
Posted: Thu May 01, 2008 1:47 pm Post subject: |
"it shifts firm" means that there is no slack between gears, slides right in, when you dont have a firm shift there is like a limobo mode between gears then bangs into gear...
shift kit just makes it change gears quicker, advantages... makes gear change quicker in a race so your more likely to get the upper hand over a car not fitted with one |
Posted: Thu May 01, 2008 1:51 pm Post subject: |
| yeah kno what ya mean, i have an eb2 sedan 6cyl, this like flows into 2nd on 80 k's no limbo....really smooth change |
Posted: Thu May 01, 2008 4:52 pm Post subject: |
| edfairmont4.0 wrote: | | what resistors used? |
i used the ones that were stated in the instructions |
Age:45 Posts: 123 Joined: 12 Jun 2005 Location: hobart TAS, Australia
Posted: Thu May 08, 2008 12:32 am Post subject: |
| anybody have s5 solenoid specs , supply voltage , coil resistance , trying to control mine with pwm ??? freq, duty cycle ????? |
Fullyxr6 Fordmods Oompa Loompa
Age:43 Posts: 38 Joined: 02 Jan 2008 Location: SYDNEY AUSTRALIA NSW, Australia
Posted: Thu May 15, 2008 8:47 pm Post subject: |
| HI will a shift kit help change gears before hitting the rev limiter? or will continue to do so? |
Posted: Thu May 15, 2008 8:58 pm Post subject: |
| it MAY but im leaning towards no |
FORDom Fordmods - Getting Side Ways
Posts: 431 Joined: 11 Nov 2007 Location: Sydney NSW, Australia
Posted: Tue May 20, 2008 10:23 pm Post subject: |
can anyone make one of these for me as i was never good with electrics
i got a el futura, and its shifting really slow. Don't care if the auto s**t itsself as it will get a new gearbox very soon and just want to have some fun with it for the mean time |
Posted: Tue May 20, 2008 10:27 pm Post subject: |
| Fullyxr6 wrote: | | HI will a shift kit help change gears before hitting the rev limiter? or will continue to do so? |
shift pattens are exactly the same it ONLY CHANGES HOW FAST THE BOX CHANGES... so instad of taking 1.5 seconds it takes less then a second to change. |
JPK Fordmods Newbie
Age:19 Posts: 6 Joined: 31 May 2008 Location: Sunshinecoast QLD, Australia
Posted: Sun Jun 08, 2008 3:27 pm Post subject: |
Hey guys.
Just got myself my first ford (El fairmont) after having 5 commodores.
Just did a complete service on the car ( god damn distributor wtf is with its position ) and installed a shift kit as well.
BUT i used a On Off On switch
What different does this make?
Is having it on off turn it off?
And what does the other 2 on's do?
One for 18ohm(firm) n one for 5.6ohm(soft)?
Is that correct?
If so which one do i keep it on when not wanting to use shift kit?
Thanks guys. |
