Wade Cams
Age:55 Posts: 256 Joined: 08 Nov 2004 Location: Melbourne VIC, Australia
Posted: Fri Feb 09, 2007 8:20 am Post subject: SHIMS |
Members are advised that it necessary to fit an extra set of standard shims when fitting a "regrind" Wade cam. This is done in order to offset the amount that we grind off the lobe when we apply a modified profile to a standard shaft.
Please don't hold me to this, but, my understanding is there are 2 different diameter shims available. Approx. 11mm and 14mm . The standard shims are 1.9mm thick. I could be wrong but the important thing is that the shims that you buy are the same dimension as those already fitted. Derrrr . Yes, l know, l'm stating the bleeding obvious.
Chris
WADE CAMS |
