signs of a buggered head gasket?
lockz
PostPosted: Wed Jan 12, 2005 10:19 am    Post subject: signs of a buggered head gasket? Reply with quote
my cars coolant is magically disappearing , i cant find a visable leak ,
the coolant goes from 'max' to 'empty' in the space of 5 minutes driving.
someone surggested to me the head gasket my be f#$ked , what do u think?
PostPosted: Wed Jan 12, 2005 10:22 am    Post subject: Reply with quote
Theres only a few places it can go - into oil, into combustion chamber or leak out somehere.
So its not leaking....
Any 'milky' reside on the bottom of the oil filler cap?
How's it run? I would have thought if that much coolant were entering the combustion chamber the engine wouldnt be running that well.
XRFan101
PostPosted: Wed Jan 12, 2005 10:25 am    Post subject: Reply with quote
Perform a pressure test on the radiator as well, you might be able to pin point where the coolant is going icon_wink.gif Sure you havent got water/ residue coming out the exhaust?
XGPANELVAN
PostPosted: Wed Jan 12, 2005 10:27 am    Post subject: Reply with quote
yeah, what 4.9 said, plus if its bad enough u will hear water boiling and popping sounds after u stop the engin after a while of running .. but milky looking s**t under the oil cap is usually the best way to tell i find
pepsimax
PostPosted: Wed Jan 12, 2005 10:34 am    Post subject: Reply with quote
i your looseing that much so quick your sump would be full of water by now or you'd have one of the cleanest cylinders in the world..
mate look over the top of the motor then ge underneath,,it's going somewhere for sure.
mine coolant used to go down the exhaust but i only lost the over flow tank after 8 hours driving..
XGPANELVAN
PostPosted: Wed Jan 12, 2005 10:43 am    Post subject: Reply with quote
yea reading that a bit more carefully, goes from full to empty in the space of 5 minutes? maybe a split hose?? has to be going somewhere, that much water in that amount of time isnt going to be getting into the head even if u had no gasket at all, aint possible
XRFan101
PostPosted: Wed Jan 12, 2005 10:49 am    Post subject: Reply with quote
Yeah very true, my guess is that its coming straight out of the exhaust. Which would mean its a head gasket or worse a damaged head.
PostPosted: Wed Jan 12, 2005 10:50 am    Post subject: Reply with quote
Heater core? Are your feet wet? lol
Geez i split a side tank and even that didnt leak as much (so long as left rad cap off)
Ace
PostPosted: Wed Jan 12, 2005 10:51 am    Post subject: Reply with quote
My car was doin this the other day, Had split a hose underneath the intake manifold (EL).
This is the absolute worst place to split a hose cause you cant see or hear it until your engine has no water!!!
Fill up your resevoir and run it in ya driveway for awhile and take a look if theres any water comin out, if ur losin water it will come out somewhere and the only real way to find it is by leaving it sitting somewhere running and seeing where the water comes out.
Start the car and turn the aircon to full hot temp on max fan, rev it to 2000 for a few mins then get out and look at the water.
Make sure u keep an eye on the temp too.
When u fill it up keep the cap off the resevoir tank for awhile and if the water 'surges' back out like its pushing all the water out the top you need a new thermostat.
Andrew J
PostPosted: Wed Jan 12, 2005 12:00 pm    Post subject: Reply with quote
Could be head, heater tap, split hose, radiator, or something similar. But if youve got no physical sign of water anywhere on the ground, in the car, or on the engine, then it tends to look like a head or gasket. But at that rate, id be thinking head.
lockz
PostPosted: Wed Jan 12, 2005 12:09 pm    Post subject: Reply with quote
any 'milky' reside on the bottom of the oil filler cap?
YEP
and idleing like s**t
blows a bit of smoke sometimes
and some sort of liquid out the exhaust sometimes
PostPosted: Wed Jan 12, 2005 12:12 pm    Post subject: Reply with quote
Hmmmmm - ever taken a head off before?
lockz
PostPosted: Wed Jan 12, 2005 12:15 pm    Post subject: Reply with quote
cant say i have.
sounds like its f**k.
whats a head gasket cost to get replaced?
...might just be a good excuse to get a bank loan and go to ITS PERFORMANCE icon_twisted.gif
PostPosted: Wed Jan 12, 2005 12:18 pm    Post subject: Reply with quote
Sounds like its well and truly f**k. Im not sure on total cost (i dont have a 6 cyl) but plenty of the guys here know all about it.
Basically you need the head removed and inspected for damage, prolly decked to make sure the surface is still true. New gasket, put back together etc.
Not much in the way of parts but plenty of labour involved.
Ace
PostPosted: Wed Jan 12, 2005 12:35 pm    Post subject: Reply with quote
It'd be over a grand EASY... I'd expect about $1500 depending on the damage to the engine internals really...
Waggin
Site Admin
PostPosted: Wed Jan 12, 2005 12:42 pm    Post subject: Reply with quote
$1000-1500 from a workshop.
Under $500 to DIY, unless the head needs to be replaced.
Andrew J
PostPosted: Wed Jan 12, 2005 2:14 pm    Post subject: Reply with quote
Id hope not!
Ive reaplced my head twice now (both times done at a shop after splitting it under the camshaft), once under warranty. The first time cost me 1300, which included the reconditioned head and obviously a head gasket. The plkace I went to was fairly reasonable, and helped me figure out things along the way. After getting water in the oil again, they tried to pass it off as condensation due to a hgher compression and blowby, and that theyd seen it on many cars. It was leaking water but, so they had a search around, replaced radiator cap, cracked hose, and heater tap, which all needed replacing, for free. That being said, they didnt listen to my original instructions of putting everything broken back in the boot of the car, so i lost a full set of brand new plugs. Oh well, the second head for free was good enough for me.
XGPANELVAN
PostPosted: Wed Jan 12, 2005 2:19 pm    Post subject: Reply with quote
i suggest if dont think you can do it or want to do it your self and are going to get a mechanic to do it, at least pull the inlet and outlet manifold off, undo the head and clean it up your self, then tow it to the mechanics yard and get him to do the rest, that'll knock off an hour or 2 off labour costs
pepsimax
PostPosted: Wed Jan 12, 2005 2:39 pm    Post subject: Reply with quote
took me 2 days to do my ea head gasket,only cause 3 of the bolts would not undo..
it cost me under 200 all up,,didn't need the head machined because it was still pretty straight,,and clean for that matter..wasn't to hard..
how the hell do you put pictures up here,,i've tried the [img][/img] buttons but it don't work
XRFan101
PostPosted: Wed Jan 12, 2005 4:08 pm    Post subject: Reply with quote
YEP
Ahh yeah thiers your problem there mate, sounds like it is quite F***! Not being rude but get it checked out asap!!!!
[47 queries :: 0.06109 seconds ]
