Simple Brake Bleed Sequence.
BLKXR8
PostPosted: Fri Jan 28, 2005 9:38 am    Post subject: Simple Brake Bleed Sequence. Reply with quote
Jst a simple question,
When bleeding brakes on an eb sedan, whats the sequence for the four rotors? eg front right, front left etc
Thanks
madmax
PostPosted: Fri Jan 28, 2005 9:48 am    Post subject: Reply with quote
I never considered that it made any differance, I just do both fronts then both rears.
ReGiE
View User Gallery (36)
PostPosted: Fri Jan 28, 2005 10:38 am    Post subject: Reply with quote
i think u start from the furtheest one away from the master cylinder and move towards it
BLKXR8
PostPosted: Fri Jan 28, 2005 12:21 pm    Post subject: Reply with quote
Thats what i've always done but a few people have told me now you start from the closest.
Just wondering what the logic in that way would be and if it is correct.
Waggin
Site Admin
PostPosted: Fri Jan 28, 2005 1:34 pm    Post subject: Reply with quote
Ford Workshop manual says to start from the furthest.
Punnisher_42
View User Gallery (24)
PostPosted: Fri Jan 28, 2005 7:57 pm    Post subject: Reply with quote
Ok waggin, ill bite.
arn't you meant to pump the pedal to force the fluid (and air pockets) out?
Andrew J
PostPosted: Fri Jan 28, 2005 8:17 pm    Post subject: Reply with quote
Yeah brad, please explain :p
pepsimax
PostPosted: Fri Jan 28, 2005 8:18 pm    Post subject: Reply with quote
yeah um how do you expect to expell the air bubbles if you don't pump fluid through the system
and you work from the left rear , right rear , left front , right front thats what i was taught
msman
PostPosted: Sat Jan 29, 2005 9:21 am    Post subject: Reply with quote
what was said in previous topic.
and ur ment to pump the pedal, in ef/el ford manual. and i think its basically the same system.
open nipple push brake close nipple and release brake, repeat until new fluid arrives.
pepsimax
PostPosted: Sat Jan 29, 2005 10:23 am    Post subject: Reply with quote
thats what i was taught,,and i don't know of any other way,,except the forced fluid method,,i've seen that done once,,bloody quick but not a very affordable unit for most mechanics.
eb2fairmont
PostPosted: Sat Jan 29, 2005 4:57 pm    Post subject: Reply with quote
Well are you going to suck the air out?
Now brake fluid certainly ain't beer!
David
[38 queries :: 0.04399 seconds ]
