Posts: 417 Joined: 30 Nov 2004 Location: Melbourne VIC, Australia
Posted: Tue Apr 01, 2008 8:07 pm Post subject: |
| Bruceyy wrote: | | Hmm sounds like a big hassle, but i want it so bad! I think the fuel management deff needs to be attended to before i start using decent boost. Im going to save around 6K for everything to be done, how much am i looking at for a change in fuel management? |
Mate as i said before do some more research, how can u budget 6k total and not have any idea how much a Engine management setup will cost you.....
your saying i have 6k to spend... turbo kit is ~3k
u go buy a fully programmable ECU - for 1200, then 500 to install and another 300 for the dyno tune - all ready at 5k right there.
Everything else involved going to cost less than $1000 ??? |
BI6TIM Fordmods Oompa Loompa
Age:28 Posts: 27 Joined: 31 Oct 2005 Location: Bribane QLD, Australia
Posted: Tue Apr 01, 2008 11:50 pm Post subject: |
Snort kits are the easiest on the market to get setup!
And for those of you out there that say the standard computer and t5 won't take it, I'm here to tell you, you're wrong!
What you get with the Snort kit:
Manifold, turbo, dump pipe, wastegate, screamer pipe(if externally gated), BOV, intercooler, intake pipe and air filter, oil feed and drain lines and fittings 12:1 fuel pressure regulator (must be plumbed inline after the stock reg. I think thats it.
What you need after that:
Cooler piping, exhaust, silicone joiners, fuel line to plumb the 12:1 in, fuel pump (Walbro 255 or Bosch 040), some vacuum lines. That should have the car running!
The standard computer and map sensor will take up to 11psi max so you can safely run 10psi all day on the stock stuff as long as you have enough fuel for it. The 12:1 reg should take care of that but i would suggest a dyno run to check AFR's before treating it too badly.
As for the T5 I have just removed a, still working(not broken) EA t5 from my car in which it put up with 300rwhp for 2months and 347rwhp for about the same amount of time. I was not nice to it either for those who will automatically assume I babied it. Didn't happen!
There have been a lot of wrong perceptions when it comes to what you can do with a mostly stock E-Series for a long time. Now there is proof that it can be done.
PS: Chef was a fool and that car was a bucket of crap that made no boost. I helped dismantle the car when it got to QLD. It was rubbish.
67RCE Fordmods - Getting Side Ways
Age:20 Posts: 1225 Joined: 30 May 2005 Location: BrisVegas QLD, Australia
Posted: Wed Apr 02, 2008 1:06 am Post subject: |
| BT, should post the Willowbank Vid over here to prove the EA T5 didnt get babied, although 13.7@110mph driving it off the line should also prove that |
Bruceyy Fordmods Oompa Loompa
Age:20 Posts: 27 Joined: 31 Mar 2008 Location: Melbourne VIC, Australia
Posted: Wed Apr 02, 2008 12:19 pm Post subject: |
BI6TIM Sounds like you know what your talking about.
Im a complete rookie at all this, and have only looked into snort performance for about 2 days, plus the rest of the research... If im paying the 3K for the stage 2 snort, how much will i be looking at for the rest of the setup?
As you said there are a number of components i will need to look at after installation of the turbo kit, before the car is running properly without any problems.
Can you give me an estimate of how much i should save, so i have a sort of goal or benchmark to hit...?
That goes for anyone, i need as many opinions as possible =D |
Posted: Wed Apr 02, 2008 4:34 pm Post subject: |
This engine bay cost me about $7000 but I've been in the motor industry for a while and know a lot of people that saved me a lot of money. Everything in this engine bay is new!
That's including the exhaust but nothing else outside of the engine bay like gearbox or diff. I've probably spend the best part of $10,000 on this car in the last 6months and that doesn't include suspension etc. which was all done by the time I took the car off the road for this turbo conversion.
You don't have to spend that much though. I would say you could get away with it for about $6000 if you don't build a new motor. |
Posted: Wed Apr 02, 2008 7:19 pm Post subject: |
wow, that looks awsome!
i pretty much said to myself if i go into this, im gonna be looking at about 6 - 7K by the time the car is running without any problems. Iv got a few mates in industry aswell, which will help. My mate is a ford mechanic, hes going to install the turbo kit for me, and take it to get dynoed and tuned.
He'll also do any extra installations for me, but thats we're im stumped. I know im going to get the snort stage 2 kit, but after that i dont know what to get so that it runs without problems. As you suggested in the post about 2 above, is that all i will need for it to run nicely? |
Posted: Thu Apr 03, 2008 5:03 pm Post subject: |
The only other things you'll need, that don't come in the snort kit, are cooler piping, exhaust, fuel pump, silicone joiners and I'd like to see the xr6 spark plugs (which are one heat range colder) go into it and clean injectors would be nice too.
After all that there is just the usual things that you do with an E-Series ie: set base timing properly, set base idle properly etc. |
Posted: Thu Apr 03, 2008 5:07 pm Post subject: |
| ye i understand, thanks mate, as long as i attend to the important things, like the ones u mentioned i think ill be ok. Thanks mate. ill get back to u if i have anymore queries. |
james88 Fordmods Stock as a Rock
Age:20 Posts: 156 Joined: 27 Oct 2007 Location: whyalla SA, Australia
Posted: Mon May 12, 2008 6:43 pm Post subject: |
| mate of mines au ute is running standard fuel pump with 42 lb injectors and its pullin 250rwkw on a snort stage 3. its strange he had a bosch intank pump but the guys who put his turno on didnt use it. can i ask? how come when you do a fuel return test on a car there is s**t loads of fuel coming back so i figured there is room for bigger injectors. i am getting the bits and pieces together for my ef xr atm and i have a walbro internal 255 ltr/hr and ba injectors ready to go. i dont know why the guys at kpm motorsport didnt use his internal pump they said its the wrong one? |
Posted: Mon May 12, 2008 6:46 pm Post subject: |
| i have been told that ba injectors are 24psi and my ef ones are 18psi??? i dont understand how its in psi im used to cc's but any ways the ba ones were only $220 exchange for 6 from repco |
Steady ED Fordmods Addict
Age:22 Posts: 6865 Joined: 01 Jun 2005 Location: Melbourne VIC, Australia
Posted: Mon May 12, 2008 8:02 pm Post subject: |
| Not PSI (pounds per square inch), LB/h (pounds per hour) |
Posted: Mon May 12, 2008 8:41 pm Post subject: |
XR6T runs at 300kpa, 32lb/h at that pressure.
They should really reference those with pressure, from memory the S/C Ecotec (36lb/hs) are @ 300kpa too. |
Age:55 Posts: 2440 Joined: 07 Nov 2004 Location: Penrith NSW, Australia
Posted: Mon May 12, 2008 9:03 pm Post subject: |
| Blown engines should run atleast 30 to 42 Lb injectors...To be safe to be safe!!!! |
sly Fordmods Tyre Shredder
Age:46 Posts: 347 Joined: 09 Feb 2006 Location: Newcastle NSW, Australia
Posted: Mon May 12, 2008 9:20 pm Post subject: |
| Steady ED wrote: | XR6T runs at 300kpa, 32lb/h at that pressure.
Good point. BTW I just read another thread that claims the XR6T reg is a 4-bar (400 kPa) reg. I assume that's absolute pressure and you're quoting gauge pressure? |
Posted: Mon May 12, 2008 9:31 pm Post subject: |
| Nope I'm wrong it is 4bar, NAs are 3. |
Posted: Wed May 14, 2008 9:32 pm Post subject: |
| cheers fellas im gonna stick with my ba ones the'll do the trick. may have to upgrade later tho but good enough for now. my turbo kit came yesterday, yay will go really good. i think im gonna use the standard fuel pump cause my mates ute is running 32 p/hr injectors on standard fuel pump running 9 psi fine at 250rwkw |
Posted: Wed May 14, 2008 10:09 pm Post subject: |
are you using a aftermarket ECU - piggyback or full ?
i doubt the stock ECU will handle Ba injectors |
4dlvr Fordmods - Getting Side Ways
Age:19 Posts: 1092 Joined: 04 May 2006 Location: melbourne VIC, Australia
Posted: Thu May 15, 2008 12:07 am Post subject: |
let us no how it all goes, im in the same position as you. saving for the stage 2, im going to give it a crack my self  |
kizzer Fordmods - Getting Side Ways
Age:22 Posts: 785 Joined: 14 Jun 2005 Location: perth WA, Australia
Posted: Thu May 15, 2008 12:28 am Post subject: |
i just fitted a stage 2 to my ef.
what eva ya think its going to cost budget twice that just in case things turn to s**t. |
[47 queries :: 0.06907 seconds ]
