Bruceyy Fordmods Oompa Loompa
Age:20 Posts: 27 Joined: 31 Mar 2008 Location: Melbourne VIC, Australia
Posted: Mon Mar 31, 2008 8:30 pm Post subject: Snort Turbo Charge on EF |
Im looking at purchasing a Snort Performance stage 2 turbo kit, my mate whos a ford mechanic said he thinks he can install, but hes not sure if its all bolt on... Has anybody done it themselves?
I want to be 100% sure before i purchase it. This is for a fairmont EF
Cheers guys |
MMD Fordmods Tyre Shredder
Posts: 398 Joined: 30 Nov 2004 Location: Melbourne VIC, Australia
Posted: Mon Mar 31, 2008 8:45 pm Post subject: |
If your mate is a mechanic and he cant install a snort kit he should not be working with cars.
Snort kits are Almost 100% bolt on.
Tap the Sump for the Oil return
Inter cooler needs to be mounted and piping needs to be sorted out
Connecting the dump pipe to your exhaust is about all that is not "bolt on"
might be a few other little things to sort out as well but nothing that you shouldn't be able to overcome. |
Posted: Mon Mar 31, 2008 8:48 pm Post subject: |
haha, settle on buddy, my mates a great mechanic, but he wasnt 100% sure on how much was bolt on and how much wasnt.
Cheers though mate, just wanted to make sure. |
Age:24 Posts: 2115 Joined: 07 Feb 2005 Location: melbourne VIC, Australia
Posted: Mon Mar 31, 2008 8:52 pm Post subject: |
| An accountant could do it, let alone a mechanic. |
Posted: Mon Mar 31, 2008 8:53 pm Post subject: |
i wasn't having a go at him, don't know him so i cant say how good or bad he is as a mechanic.  |
Posted: Mon Mar 31, 2008 9:06 pm Post subject: |
| haha ye i know, sall good dude. Gonna go with the snort stage 2, have u got one on urs? can i use stock ECU? |
Posted: Mon Mar 31, 2008 9:15 pm Post subject: |
i have a setup from snort that is close to an AIT turbo setup.
Snort put a stage 2 kit on an EA, using their Water to Air inter cooler setup and with stock ECU got over 200rwkw (cant remember exact figure)
with upgraded fuel system BA injectors and a piggyback ECU final tune was 295rwkw.
Remember you will need a F.M.U and a high flow fuel pump (not sure if they are in the snort kits) |
Posted: Mon Mar 31, 2008 9:19 pm Post subject: |
nice dude,
hmm wat if i dont get those extra parts? engine blows? =(
ye those parts dont come with the stage 2, f**k! lol, ill be happy with 200 at the wheels. will i need the piggy back ecu? or can i just run the bolt on kit with a sweet tune on the stock ecu? |
Posted: Mon Mar 31, 2008 9:23 pm Post subject: |
u will need the F.M.U and the Fuel Pump as minimum.
It will and can run on stock fuel setup and ECU but i would at least get it on a dyno to check its running safe. and not run much boost probably 5psi max.
"should" be no problem hitting 200rwkw with a snort stage 2 kit on stock ECU, with the parts above
how many K's on your motor ?
not major problems with it ?
auto box or manual ? |
Posted: Mon Mar 31, 2008 9:29 pm Post subject: |
yee sweet dude,
my mate knows a good place for tunning and dynoing so deff getting them done.
Umm the car is in perfect condition, 175K on the clock, just had new alternator put in, had new fuel pump put in in 2006, other then that, the cars been perfect. Its an auto, but i wanna convert to manual probs next year some time. |
Posted: Mon Mar 31, 2008 9:32 pm Post subject: |
the E series t5's don't like being pushed
if you are turboing stick with the auto and put a shift kit in it.
if i were you i would do a bit more research into turbo's for e series read Chef's sticky at the top and do your sums again. finished product pretty much always ends up more than you will budget for. Especially if you try to do it cheaply. |
Posted: Mon Mar 31, 2008 9:35 pm Post subject: |
ye im deff budgeting above wat i think. Its around 3.5K for the kit, then installation, dyno and tune probs another 1.5...
I havnt got the money yet, so ill deff do some more research, cheers mate. |
67RCE Fordmods - Getting Side Ways
Age:19 Posts: 1178 Joined: 30 May 2005 Location: BrisVegas QLD, Australia
Posted: Mon Mar 31, 2008 9:48 pm Post subject: |
| Mate, under 8psi the snort kit, 12:1FMU and a good Fuel pump (Bosch 040 or similar) will throw around 320rwhp through a stock EA T5, and treated right, or wrong it will last, but for how long is the question. BI6TIM made 350rwhp on: Snort Kit, ED XR6 ECU, Bosch 040 pump, 24lb/hr injectors and a 12:1FMU, and an EA T5, went 13.7@110mph with a 2.4s 60 footer |
Posted: Mon Mar 31, 2008 10:15 pm Post subject: |
Yep another happy customer
He had no intention of keeping that EA T5, i bet even he thought it was going to brake.
and as i said the kit "should" be no problem hitting the figures he asked with a Fuel Pump and FMU.
Cheapest option is to leave the BTR auto in there and use an electronic shift kit. |
Posted: Mon Mar 31, 2008 10:52 pm Post subject: |
Hmm wats a FMU? Sorry newbie here =D
I understand everything else just not the FMU.
How much would i be looking at for the electronic shift kit?
My mate has one in his statesman, the things a beast, he paid around 1500 i think. Is that about right? |
millzy555 Fordmods Oompa Loompa
Posts: 33 Joined: 10 May 2007 Location: melbourne VIC, Australia
Posted: Tue Apr 01, 2008 10:00 am Post subject: |
You can make shift kits for like $20, or buy them for $120
Depends how hard it shifts stock, mines really firm so i didn't bother with one
FMU = fuel management unit, fuel regulator it think.... |
phum Fordmods Oompa Loompa
Posts: 29 Joined: 12 Nov 2005 Location: Bundaberg QLD, Australia
Posted: Tue Apr 01, 2008 3:00 pm Post subject: |
I put a Snort Kit on an XH. (similar setup to an Ef EL) . It is not just a throw it in there and fly setup. There is not much room to fit the intercooler etc.
After 2 blown motors I would recommend that the fuel system is upgraded first, fuel pump, regulator etc, If the thing runs lean detonation starts and soon goodby engine.
If you are going to run any sort of usefull boost the EMS will be suspect, mine would not regulate fuel mixture reliabily above 2PSI. boost.
Cooling is important check that too.
Having said all that I am pleased with my setup. I have dual fuel and it loves the gas ( no aftermarket EMS. so I try to keep off the petrol)
There a couple of photos in my gallery if you are interested.
Peter |
Posted: Tue Apr 01, 2008 5:18 pm Post subject: |
| Hmm sounds like a big hassle, but i want it so bad! I think the fuel management deff needs to be attended to before i start using decent boost. Im going to save around 6K for everything to be done, how much am i looking at for a change in fuel management? |
Posted: Tue Apr 01, 2008 5:39 pm Post subject: |
Fuel pump, bosch one = $200
Rising rate reg = $80
injectors = $400 (cheers daz)
Flash tune and chip things start at $800 and head north from there
these are just estimates, i'm yet to have mine chipped and have had no dramas
DA22LE Fordmods Stock as a Rock
Age:41 Posts: 175 Joined: 06 Aug 2007 Location: Kellyville NSW, Australia
Posted: Tue Apr 01, 2008 7:49 pm Post subject: |
| millzy555 wrote: | injectors = $120
these are just estimates, i'm yet to have mine chipped and have had no dramas |
$120 might get you 2 injectors, still need another 4.....if you're lucky you can get some good inj' off ebay, i scored a set of 42 lb'ers for $355 to my door. Sweet action....
Daz  |
[47 queries :: 0.05109 seconds ]
