99chris99 Fordmods - Getting Side Ways
Age:21 Posts: 663 Joined: 10 Nov 2004 Location: Richmond NSW, Australia
Posted: Thu Dec 30, 2004 11:56 am Post subject: speed cut out |
| anyone know what the fastest an EL Gli is supposed to go? |
Happy Moderator
Age:35 Posts: 9840 Joined: 05 Nov 2004 Location: Perth WA, Australia
Posted: Thu Dec 30, 2004 11:57 am Post subject: |
"supposed" is such a "suggestory" word but 180 kph is the number you are looking for! |
Age:27 Posts: 4737 Joined: 24 Nov 2004 Location: Canberra ACT, Australia
Posted: Thu Dec 30, 2004 12:32 pm Post subject: |
only the autos (limited by the ECU), manuals are unlimited (well except by certain laws of phsyics).
But given a suitable long road, and a tail wind, the 220 on the speedo should be jus the beginning. |
Posted: Thu Dec 30, 2004 8:28 pm Post subject: |
| Sorry dude, but I beg to differ. My factory 5 speed EL Futura is most definatly limited at 180kp/h. I think manual XR's aren't limited. But manual standard models certainly are. |
He[X]eN Fordmods Stock as a Rock
Posts: 107 Joined: 07 Nov 2004 Location: Melbourne VIC, Australia
Posted: Thu Dec 30, 2004 8:51 pm Post subject: |
| I thought they were limited because the tailshaft could not handle speeds over 180. Manual and auto both use the same tailshaft dont they?? |
Posted: Thu Dec 30, 2004 11:02 pm Post subject: |
I didn't think it could limit the manuals, as it is based of a calculation of, diff ratio, gear in use (if its auto the ECU picked it so it knows), and RPM.
But I guess if you've tried and 180 is it, then I guess it must only be the XRs and Cop Packs. |
XR~ADZ Fordmods - Getting Side Ways
Age:27 Posts: 470 Joined: 08 Nov 2004 Location: Adelaide SA, Australia
Posted: Wed Jan 05, 2005 11:10 am Post subject: |
My car is an EF GLI
I Put an EL XR6 Motor in it, and a T5 manual conversion.
We then got a manual XR6 ECU and LSD.
Had no problems getting the car up to 200km/h
Would have gone more - but Im not a fan of going that fast.... Just wanted to see if it would go past the 180 mark.
BTW - Before all these mods, it would only go to 180
Hope this helps you? |
Posts: 1003 Joined: 05 Nov 2004 Location: Sydney NSW, Australia
Posted: Wed Jan 05, 2005 12:12 pm Post subject: |
Its based on two limiters :
There is the Rev Limiter (all models)
and there is Speed limiter, which works off the Speedo sensor just the same as the speedo does.
You can have them deleted etc.
I believe tickford also used a different tailshaft for a little more (and police-pack as well??)
I believe the autos are all limited as the internals wont go harder than that (supposedly) |
comhelp Fordmods Tyre Shredder
Age:25 Posts: 391 Joined: 06 Nov 2004 Location: Melbourne VIC, Australia
Posted: Fri Jan 14, 2005 2:42 am Post subject: |
um and also if u have LPG then it is unlimited as it only cuts the injectors and since LPG doesn't use the injectors then the limits are no good  |
Casper Fordmods - Smokin em up
Age:37 Posts: 256 Joined: 13 Nov 2004 Location: Melbourne VIC, Australia
Posted: Fri Jan 14, 2005 7:02 am Post subject: |
Ok, for the record.
ALL EECV cars are limited to 180kph from the factory with the following exceptions
XR Sedans - have varing limits from 210kph to unlimited...regardless of transmissions
Police packs - see XR Sedans
T Series - Same as XR sedans with the exception of the TL50's which had a 180kph limit.
LPG Cars - limiter does not work on LPG
Note: ALL XR utes were 180kph speed limited. |
Posted: Fri Jan 14, 2005 8:11 am Post subject: |
I read that TL50's were speed limited at 190 - im just being picky haha.
What about the 1st ever t series; the FBT, ive had it to 185 but thats it, wasnt trying to do speed run, just overtake. |
Posted: Fri Jan 14, 2005 8:58 am Post subject: |
| Daniel wrote: | I read that TL50's were speed limited at 190 - im just being picky haha.
Overtaking a copper on a high speed chase were we? |
