Posted: Fri Feb 04, 2005 5:14 pm Post subject: Squeak from Engine somewhere |
Hi all.
I got a squeak coming from the p/s pump area. I sounds like it's low fluid, but the fluid level's fine.
It happens when the engine's warm, not cold from what I've noticed and is dissapears above about 1800RPM.
Any ideas? |
Posted: Fri Feb 04, 2005 5:59 pm Post subject: |
| I doubt it. Bearings get worse with speed, not better. |
altedxr6
Age:30 Posts: 1435 Joined: 05 Nov 2004 Location: Sunshine Coast QLD QLD, Australia
Posted: Fri Feb 04, 2005 6:21 pm Post subject: |
| check all the belts, making sure they are not breaking up on you, also, make sure there is no oil on the belts, there is also a bearing in the adjustable pully for the power steering pump ... I've seen then brake up and sweak heaps. |
nannas_ed Fordmods - Getting Side Ways
Age:23 Posts: 2124 Joined: 14 Jan 2005 Location: Melbourne VIC, Australia
Posted: Fri Feb 04, 2005 7:32 pm Post subject: |
| whilst the engine is idleing spray some CRC or Lithium Grease on the Belts and Pulleys. |
revcore Fordmods - Getting Side Ways
Age:32 Posts: 2696 Joined: 05 Nov 2004 Location: Bairnsdale VIC, Australia
Posted: Fri Feb 04, 2005 7:34 pm Post subject: |
CRC Belt grip (It's in a green can) works great on dry noisy belts.
Just spray it on then start the car and leave idleing until noise dissapears. |
Age:34 Posts: 2475 Joined: 06 Nov 2004 Location: Melbourne VIC, Australia
Posted: Fri Feb 04, 2005 8:50 pm Post subject: |
| could be the tensioner pulleys. the set of 2 is about $25 from ford |
mspw Fordmods - Getting Side Ways
Age:36 Posts: 1743 Joined: 05 Nov 2004 Location: Quakers Hill NSW, Australia
Posted: Fri Feb 04, 2005 9:51 pm Post subject: Re: Squeak from Engine somewhere |
| unclewoja wrote: | Hi all.
Any ideas? |
I was going to make a crack about a dehydrated mouse on a treadmill - but thought better of it. |
Posted: Sat Feb 05, 2005 7:30 am Post subject: |
Kewel. I'll try the CRC. Thanks guys.
I've never seen a bearing get better, or quieter with increased speed in my experience. That's why I don't think it's a bearing. |
cro142 Fordmods Parts Gopher
Posts: 55 Joined: 14 Dec 2004 Location: Brisbane QLD, Australia
Posted: Sun Feb 06, 2005 4:33 pm Post subject: EA squeak |
Try the 2 bearings inside the tensioner and a/c idler pulleys.
They go all the time - but you can replace just the bearing for $5 each from any parts place - don't have to buy the whole pulley assembly. |
dark_realm Fordmods Oompa Loompa
Age:23 Posts: 47 Joined: 28 Nov 2004 Location: Newborough VIC, Australia
Posted: Sun Feb 06, 2005 11:10 pm Post subject: |
| its monkeys under your bonnet..... |
