Stationary Sub Box?
OsbornThomas
PostPosted: Sat Jul 14, 2007 6:26 pm    Post subject: Stationary Sub Box? Reply with quote
Hey guys! How have you all stopped your sub moving around in your boot? It didn't bother me till now because i had a rim in the boot holding it there while i was doing up my car... Now it's complete the rim is out and the sub isn't secure...
Help?
voxace
View User Gallery (27)
PostPosted: Sat Jul 14, 2007 6:31 pm    Post subject: Reply with quote
Well it depends on the shape, size and location of your sub box.
Mine sits on the little hump, and I have attached a bracket from the box to the parcel shelf.
OsbornThomas
PostPosted: Sat Jul 14, 2007 6:35 pm    Post subject: Reply with quote
Here is an old picture... That's where it normally sits, I don't really fancy drilling through the floor and fitting L brackets etc..
 Description:
 Filesize:  595.18 KB
 Viewed:  9 Time(s)
voxace
PostPosted: Sat Jul 14, 2007 6:36 pm    Post subject: Reply with quote
Well in that case get some velcro and attach it to the base of the box, should help it grip to the carpet.
joolz
PostPosted: Sat Jul 14, 2007 7:11 pm    Post subject: Reply with quote
As above... i used strips of the prickly part of velcro, stapled it to the base of the sub box and it sticks well. The sub can still be moved if more boot space is needed.
MooseMan
PostPosted: Sat Jul 14, 2007 7:13 pm    Post subject: Reply with quote
occy strap.
Darkr
PostPosted: Sat Jul 14, 2007 7:20 pm    Post subject: Reply with quote
velcro is the way to go.
lukey
PostPosted: Sat Jul 14, 2007 7:25 pm    Post subject: Reply with quote
I use Velcro works great
OsbornThomas
PostPosted: Mon Jul 16, 2007 11:32 am    Post subject: Reply with quote
Thanks heaps guys! Why didn't i think of that! I have an RDO so i will go pick some up today..
and there is no where really to stick occy straps in the boot to hold a sub box.
FordFairmont
PostPosted: Mon Jul 16, 2007 11:43 am    Post subject: Reply with quote
What you should do is make your own custom box that slots into the section behind the seats and throw away that dodgy super cheap enclosure. Like mentioned before, buy a couple of bracket that attach to the top of the box and to the underside of the parcel shelf.
OsbornThomas
PostPosted: Mon Jul 16, 2007 11:51 am    Post subject: Reply with quote
Ha i told the guy to take a further $40 off the sub price and for him to keep the box, sony explode don't make a bad box so I'm using one of those..
howsie
PostPosted: Mon Jul 16, 2007 1:45 pm    Post subject: Reply with quote
personally i got 2 12's in separate boxes which have been in both an ea and a ba and they fit just behind the rear seat perfectly
they never move as they are wedged in there really tight but of course you'd have to buy another one and the boxes i use are from autobahn and are smaller than sony boxes
MikeSmith
PostPosted: Mon Jul 16, 2007 3:24 pm    Post subject: Reply with quote
Velcro is definetly the way to go. You can get some really big pieces from Bunnings pretty cheap. Then when you need to remove it you just take out the speaker wire and away you go.
huggiebear
View User Gallery (28)
PostPosted: Mon Jul 16, 2007 4:10 pm    Post subject: Reply with quote
i tried velcro in my old EA.. did nothing but i had mine up on the hump. it kept rolling down in the boot and edned up distroying the sub so i got 3 pieces of wire and 6 screws and made bracing like in the pics below
there is NO wiring under the body where the screw is so no chance at shorting something out and the parcel shelf has nothing either. the screws can be put under the carpet if wanted. i never had another issue
skidder
PostPosted: Thu Jul 19, 2007 7:12 pm    Post subject: Reply with quote
L bracket and drill holes through chassis above diff is easiet/best way. stick some bolts through and nylon lock nuts and dont forget the paint to stop rust
data_mine
PostPosted: Thu Jul 19, 2007 7:54 pm    Post subject: Reply with quote
MooseMan wrote:
occy strap.
Used to do that with my EL, now in the GT-P the combination of false floor and parcel shelf allows the boxes to be wedged in and don't move on their own.
falcon gl
PostPosted: Thu Jul 19, 2007 10:07 pm    Post subject: Reply with quote
personally if you just put the rims back use a bit of tyre shine and it would look very nice
timmay_73
PostPosted: Wed Jun 18, 2008 10:55 pm    Post subject: Reply with quote
I also have this problem, with twin alpines...
The problem isn't contact with the carpet as it seems to stick to the same spot in the carpet, but the boot carpet itself moves about... Anyone have any advice?
data_mine
PostPosted: Thu Jun 19, 2008 5:33 pm    Post subject: Reply with quote
You'd have to fix the carpet to the boot somehow.
glue to floor.
Best attack IMO would be to get some brackets and screw the sub box through the carpet into the boot floor.
Reflections
View User Gallery (16)
PostPosted: Thu Jun 19, 2008 10:08 pm    Post subject: Reply with quote
L bracket. To get the best sound quality they need to be mounted quite tightly. I haven't seen or tried velcro but it might work.
[49 queries :: 0.15194 seconds ]
