stop leak
xr Rob
View User Gallery (17)
PostPosted: Wed Dec 08, 2004 10:17 pm    Post subject: stop leak Reply with quote
hey everyone at the moment i have a few leak problems such as most welsh plugs and small head gasket leak a fella gave me a pack of this thurmo stop leek stuff i just wanna know if its any good thanx
NOCLAF
PostPosted: Wed Dec 08, 2004 11:10 pm    Post subject: Reply with quote
iv heard of chemi-weld.. but not thurmo-stop...chemi-weld works ok.. my dad used it on my mums old XF about 5 years ago.. it had a slightly cracked head and put chemi-weld in the radiator was fine after that...not a permanent solution tho icon_razz.gif
rockerfella
PostPosted: Wed Dec 08, 2004 11:38 pm    Post subject: Reply with quote
good to see u back on here brother. the ol' beast is getting lowered tomorrow. i'll bring it around to your work when it's done. icon_razz.gif
madmax
PostPosted: Thu Dec 09, 2004 10:15 am    Post subject: Reply with quote
I have heard that these types of stop leak solutions can clog up your radiator! Best to fix it properly, use brass welsh plugs with a little stag on them don't forget there are welsh plugs in the rear of the block also. Then change you head gasket.
1 SLY 97EL
PostPosted: Thu Dec 09, 2004 2:34 pm    Post subject: Reply with quote
I have often used that "Chemweld"or "Barsleaks "on minor leaks f coolant seepage from the block and it has worked fantastic. But for major s**t like head gaskets and welsh plugs, it is generally no good in the long run
EDSteve
PostPosted: Thu Dec 09, 2004 3:05 pm    Post subject: Reply with quote
I used it once on a Tarago I had years ago and it blocked up all fins in the radiator. As madmax said best off to do it properly then you know it will last. icon_biggrin.gif
[33 queries :: 0.03976 seconds ]
