GT-P Fordmods Tyre Shredder
Age:22 Posts: 306 Joined: 02 Dec 2004 Location: Melbourne VIC, Australia
Posted: Tue Jan 18, 2005 1:35 pm Post subject: Straight gas engine into a AU1 |
hey guys
just a quick question, ive got a striaght gas engine from an AUII, and i want to put the AUII straight gas engine into AUI with a duel fuel setup. Would this work? Would it still be able to run on petrol? Would i still be able to use the same ECU?
thanks |
Disco Frank Fordmods Junkie
Posted: Tue Jan 18, 2005 3:18 pm Post subject: |
NO the au2 straight gas engine ( green rocker cover ) does not have fuel rails or fuel injectors it also runs a different gas convertor
then there is the problem the AU2 has bigger gas tanks and no petrol tank so u would need to buy a gas tank for the au1 to fit in the boot
alot of f**k about be easier to add gas to you au1 after the government rebate it is about $1400 |
Posted: Tue Jan 18, 2005 8:44 pm Post subject: |
| opps i meant to say the au1 has already duel fuel, and i just wanted to use the straight gas engine from the au2 in the au1. does it make sence now? |
Posted: Tue Jan 18, 2005 11:50 pm Post subject: |
umm u would need to fit a fuel rail to the engine which will require an Au1 intake manifold, the gas engine manifold does not have the holes for the injectors.
and i think the gas engine has differnt pistons/comp ratio and rings so not sure how it would go on petrol |
Posted: Thu Jan 20, 2005 9:51 am Post subject: |
| sweet thanks mate |
flukey Fordmods Newbie
Age:32 Posts: 15 Joined: 14 Nov 2004 Location: sydney NSW, Australia
Posted: Fri Jan 21, 2005 11:39 am Post subject: |
If all you are transferring is basically a "long motor" without manifolding or anything else, you should have no probs. The AU e-gasser's are basically a petrol engine with hard valves / seats (excluding intake manifold etc etc)  |
