Sub Install Problem in EF
Goto page Previous  1, 2
DMac
PostPosted: Sun Jan 16, 2005 6:22 pm    Post subject: Reply with quote
i mounted my amp in the factory position(on the right hand side of boot). the other one is infront of the wheel arch held by a bracket which is screwed into the metal at the back of the boot. it looks like it is not being held.
XRFan101
PostPosted: Sun Jan 16, 2005 7:10 pm    Post subject: Reply with quote
Best advice i can give is just to mount it where the factory ones go, thats where mine is, looks good and is completely secure and gets adequate ventilation.
All i did was make up a custom mounting board for it then carpeted it and then mounted the amp on that. Looks good and is very clean too. (quite happy with the result ) seing as it was a first.
Good luck
poolep88
PostPosted: Mon Jan 17, 2005 12:54 am    Post subject: Reply with quote
any suggestions for installing a sub when u have a 70lt lpg tank in the boot
twirqurky
PostPosted: Mon Jan 17, 2005 1:02 am    Post subject: Reply with quote
Dont. The tank will runi the sound quality.
XRFan101
PostPosted: Mon Jan 17, 2005 9:26 am    Post subject: Reply with quote
LOOK at my gallery dude!!! There is F*** all you can do unless you want a complete professional boot intall etc. I actually had a few ideas but to put them to reality it was gonna cost me quite a bit.
I had to have a custom box made up so that it would sit up against the front of the Gas tank (see Gallery) i dont believe it has effected the sound quality as the only difference it would of made was how loud it would be.
I have got it to stay in the one spot but later on down the track im gonna make up a proper boot linning etc so it all sits in thier properly. icon_rolleyes.gif
Neal-50
PostPosted: Mon Jan 17, 2005 5:15 pm    Post subject: Reply with quote
poolep88,
I have a lpg tank and had the same problem. I made a box that fits in the boot floor recess, its about 150mm deep and holds 2 10in jvc subs. the box is easy removed to get to the tyre well. I made a board for the amps that has a hinge that pivots from the lpg tank mounting brackets. it is hinged so i can get to the lpg tank sender/valve box for service etc.
sounds pretty cool to me. makes the boot usless though.
poolep88
PostPosted: Mon Jan 17, 2005 7:40 pm    Post subject: Reply with quote
thanxs guys i will have to have a play around
Daniel
PostPosted: Mon Jan 17, 2005 8:04 pm    Post subject: Reply with quote
Neal-50 wrote:
...sounds pretty cool to me. makes the boot usless though.
And theres the reason why Im scared to put my foot into the water as such, i need to sit down n think opf a way i can keep it looking neat/stock(ish)/and retaining boot usability.. icon_cry.gif
data_mine
PostPosted: Mon Jan 17, 2005 8:17 pm    Post subject: Reply with quote
It's always a tradeoff. My sub boxes have quick release fittings, so when I need boot space (or the fold down) they come out easy.
XRFan101
PostPosted: Tue Jan 18, 2005 9:25 am    Post subject: Reply with quote
Yeah all i gotta do is disconnect sub wire and i can take my sub out, still pleanty of room in the boot, but i dont like ne thing sitting in front of the sub so i have to put everything on the LH side, as on the RH side i have the amp.... icon_rolleyes.gif
wolfpac_w
PostPosted: Thu Jan 20, 2005 10:01 pm    Post subject: Reply with quote
Might have to "borrow" a few ideas, yeah, that's it "borrow"... icon_lol.gif
Wolfpac
xr Rob
View User Gallery (17)
PostPosted: Thu Jan 20, 2005 10:22 pm    Post subject: Reply with quote
hey all well i work at BDL car stero for about 2 months now so i am as u put the new guy but i have found under the passenger seat is a good spot for the amp or the back of the rear seats but if u hace an ef/el and dont use ya boot all that much like me i have put my amp on the raised step behind the rear seat and the sub behind that but i didnt want to put screws all over the place so i velcroed it down.
twirqurky
PostPosted: Thu Jan 20, 2005 11:28 pm    Post subject: Reply with quote
Yeah we tried to velcro the amp to the sub box but it fell off when I left my driveway.
What we ended up doing was screwing the sub box to the floor of the rasied bit just behind the seats using 4 L brackets. Then put the amp on the back of tha using 4 screws. And finally put a bit of wood attached to the front of it using 2 more L brackets to stop it rocking.
That reminds I really should paint that wood. Green doesnt suit my gray boot carpet.
dunis
PostPosted: Fri Jan 21, 2005 12:56 pm    Post subject: Reply with quote
just screw the amp onto tha box with a couple of self tappers.
use the velcro under the box to stop the box slidding around. make sure you put the velcro stripps with the hooks on the box underside (nor fur, fur is bad)
Page 2 of 2
[41 queries :: 0.05612 seconds ]
