Posted: Mon Dec 27, 2004 12:25 am Post subject: Sub Install Problem in EF |
My brother and I tried to install my 12" Sony Xplode this afternoon.
We ran the power cable from the battery through the footwall via the steering column and up the centre to the boot. The RCA cable went in properly.
But the sub didnt work, not even the cone moved a millimetere.
We figured out the problem was the amp is not getting power, but we dont know how.
Any ideas cuz we got none. |
Posted: Mon Dec 27, 2004 3:03 am Post subject: |
| I assume you tried the obvious such as testing the power cable with a multimeter or 12V test lamp and made sure the amp works by powering it with something closer? |
MRE-50L Fordmods - Getting Side Ways
Posts: 2192 Joined: 05 Nov 2004 Location: West Ryde - Sydney NSW, Australia
View User Gallery (53)
Posted: Mon Dec 27, 2004 7:19 am Post subject: |
| stupid as it may sound but did you hook up the remote wire from the HU |
Age:24 Posts: 3049 Joined: 05 Nov 2004 Location: Sydney NSW, Australia
View User Gallery (36)
Posted: Mon Dec 27, 2004 8:05 am Post subject: |
yeah check the remote wire and see if u get power to the amp when the HU is turned on.
have u got a good earhting point also? |
Posted: Mon Dec 27, 2004 6:52 pm Post subject: |
| We got it working but we cant seem to mount it in securely. Any ideas about how to do this? |
Age:27 Posts: 4675 Joined: 24 Nov 2004 Location: Canberra ACT, Australia
Posted: Mon Dec 27, 2004 7:29 pm Post subject: |
I mounted my amp on the back of the '60' part of teh 64/40 split rear seats. 4 self tapper screws easy.
As for the subs, (I got two 10" in sep. sealed boxes), I just occy strapped them to the boot lock catch. |
View User Gallery (33)
Posted: Tue Dec 28, 2004 9:25 am Post subject: |
my amps mpunted where the factory one is now, cant see any cables its sweet  |
99chris99 Fordmods - Getting Side Ways
Age:21 Posts: 663 Joined: 10 Nov 2004 Location: Richmond NSW, Australia
Posted: Wed Dec 29, 2004 10:07 am Post subject: |
| mine is mounted onto the back of the box. its out of the way so its pretty good |
dunis Fordmods Stock as a Rock
Age:25 Posts: 157 Joined: 10 Nov 2004 Location: sydney NSW, Australia
Posted: Wed Jan 12, 2005 12:40 pm Post subject: |
I do about 2-3 installs a month.
My favourite places to mount boxes in a falcon are right behind the back seat, so you can drop one or two seats down a get a more defined and clearer punch at your ears. this can be done by removing the sub from the box and putting about four 35ml self tapping screws down through the box into the chassis. another option is to stick velcro strips onto the bottom side of the box (the strips with the hooks, not the fur..... fur is bad!)
I prefer the first option as if this was done in my car the box wouldn't stay for very long, about untill i hit the first corner
My fav spots for mounting amps is
1. on the sub box
2. on the back of the back seats.
3. recessed in a custom boot.
4. on the inside of the boot (alot of work necessary)
5. recessed in the rear footwells
6. upside down under the parcel tray (this is last option as it doesnt alow the amps to cool very well)
the factors to be taken into acount when deciding where to mount these components are
1. Practicality
2. Cost
3. Usability (accesability, ease of use)
4. The desired outcome (efficency, looks... that type of stuff)
PM me or give me a bell if you want some more neat ideas about how to build custom boots or mount caps and distro blocks or even dual battry setups!
Chris Doulis aka Dunis ph: 0413 032 868 |
azza Fordmods - Smokin em up
Age:22 Posts: 261 Joined: 05 Nov 2004 Location: Perth WA, Australia
Posted: Fri Jan 14, 2005 2:22 pm Post subject: |
i have a sony 12" and mine sits up on the part just behind the seats... its on one of those sony boxes so i had to make some slight adjustments to the parcel shelf with an angle grinder
<------see my gallery for the boot set up |
Posted: Fri Jan 14, 2005 2:23 pm Post subject: |
*cough* defect....
*cough* reduces structural integrity *cough* |
Posted: Fri Jan 14, 2005 5:02 pm Post subject: |
| looks nice though. |
Posted: Fri Jan 14, 2005 5:37 pm Post subject: |
| yeh im completely aware that is interfering with the structure of the car.... but the coppers couldnt see it anyway coz of the way my set up is... doesnt feel astho i have lost any stiffness.... it was a decision that had to be made... and i need the boot space...so it had to sit up there |
Neal-50 Fordmods - Smokin em up
Age:30 Posts: 243 Joined: 09 Nov 2004 Location: Bayswater VIC, Australia
Posted: Sat Jan 15, 2005 4:58 pm Post subject: |
dunis, self tapers through the box into the chassis!!
*cough* Butcher
*cough* Strathfield car radio |
Posted: Sat Jan 15, 2005 5:35 pm Post subject: |
| Check with pro installers like straithfield and autobarn jb hifi etc, the guys in the fitting bays may give you good advice, after all they are doing it all day everyday. |
Age:22 Posts: 2969 Joined: 05 Nov 2004 Location: Melbourne VIC, Australia
Posted: Sat Jan 15, 2005 5:46 pm Post subject: |
| Neal-50 wrote: | | Check with pro installers like straithfield and autobarn jb hifi etc, the guys in the fitting bays may give you good advice, after all they are doing it all day everyday. |
Couldnt agree more - they had great idea with mouning my stuff and did good job as i didnt have time/effort/know how.. |
Posted: Sat Jan 15, 2005 5:48 pm Post subject: |
| Just make sure you don't get the 'new guy' |
Posted: Sat Jan 15, 2005 7:17 pm Post subject: |
| Neal-50 wrote: | | Check with pro installers like straithfield. |
ummm - you cant use "pro installers" and "strathfield" in the same sentence... it just doesnt compute!! |
Age:34 Posts: 2329 Joined: 06 Nov 2004 Location: Melbourne VIC, Australia
Posted: Sun Jan 16, 2005 4:10 am Post subject: |
| you can use pro butchers gettin paid peanuts tho!!! |
Posted: Sun Jan 16, 2005 5:53 pm Post subject: |
Sarcasm people!
i hoped someone would arc up on my pro installers coment, have to be careful with what you say sometimes thats all.
i agree completely xr8chic, i have seen some shockers, stray screws from stacker installs into fuel tanks the works. everyone has there bad days though. |
