Subwoofer
eagleaus
PostPosted: Thu Nov 18, 2004 11:03 am    Post subject: Subwoofer Reply with quote
Anyone know what the Watts are for the factory subwoofer in the premium sound system for the EF etc., it's only a 7"???
XRFan101
PostPosted: Thu Nov 18, 2004 11:14 am    Post subject: Reply with quote
Its 100 or 150 watts isnt it?
fairmontman
PostPosted: Thu Nov 18, 2004 11:16 am    Post subject: Reply with quote
I had thought they were an 8". Don't know the wattage, but suffice to say don't bother trying to get it to do anything interesting...
Waggin
Site Admin
PostPosted: Thu Nov 18, 2004 11:26 am    Post subject: Reply with quote
yeh, its 8". I think theyre rated around 50W RMS
eagleaus
PostPosted: Thu Nov 18, 2004 1:27 pm    Post subject: Reply with quote
50w sounds a bit low?? i thought that the factory amp was rated at 250w??Is there anywhere you can find this info as i want to amp it and don't want to under or over power it.Not keen on haveing a box sitting in my boot (gas tank taken care of that icon_cry.gif )
PostPosted: Thu Nov 18, 2004 1:31 pm    Post subject: Reply with quote
Yeah probably is 250w in peak output. RMS a different story.
Kinda like my engine makes around 250kw, but at the wheels its a very different (rather depressing icon_cry.gif ) story....
fairmontman
PostPosted: Thu Nov 18, 2004 2:45 pm    Post subject: Reply with quote
I understand the dilema about boot space. I went through the very same thing myself and was determined not to use a sub boxed in the boot. However, I strenuously recommend searching till you find a solution that does not involve the stock sub. It really isn't very good
XRFan101
PostPosted: Thu Nov 18, 2004 5:25 pm    Post subject: Reply with quote
Pfft boot space i threw that idea out the window lol. Gas tank + sub in box = SFA space int the boot!
The sub is rated at 50wrms and i think you will find that the amp is only 100wrms as its only got suffiecent power for the 8' sub! Could even be less!
I read b4 that the new factory systems in the BA Range etc i think you will find that the sub and amp are 100wrms and 150wrms respectively.... I think.
joolz
PostPosted: Thu Nov 18, 2004 6:10 pm    Post subject: Reply with quote
the amp is 4x50 watt at 4 ohm, the front speakers are powered by the HU. the power to the sub is only 100watts max! but the driver is rated at 6ohm so its harder to over power it
DMac
PostPosted: Fri Nov 19, 2004 6:50 am    Post subject: Reply with quote
if you had to replace it where would you get a 7" sub from. i thought they went from 6" to 8" 10 12 15. hey guys have any of yous heard of an 18inch sub. i also heard that there is a 21inch sub out..
back to the the topic.
Even the new BA's come with 8inch subs. funny how its a seven.
bloody ford sometimes always making things that little bit harder for us moders.
Daniel
PostPosted: Fri Nov 19, 2004 9:49 am    Post subject: Reply with quote
No ford ive known comes with a 7" sub, all 8".
Im lost to why you think its 7".. have i missed something?
eagleaus
PostPosted: Fri Nov 19, 2004 10:15 am    Post subject: Reply with quote
I think you will find that we think they are 7" is when we measure the face of the woofer, which may not be the way its done.
Daniel
PostPosted: Fri Nov 19, 2004 11:04 am    Post subject: Reply with quote
Err, ok then.
Well put it this way.. If you wish to replace the stock 8" (7" if you wish to call it) with an aftermarket one, you will need to be shopping for an 8" at least, if you wish to fit a 10 there, you could use a bracket made of mdf or the likes..
LTDHO
PostPosted: Fri Nov 19, 2004 12:07 pm    Post subject: Reply with quote
If you are fitting the sub for bass, don't bother with a 8" on the shelf, especially in a Falcon sized car.
The 8" isn't big or powerfull enought, also the parcel shelf will flex and take bass out.
Get a box, even a pre-fab for autobarn. fit a 10 or 12. 1 or 2 of each. wire them to an amplifier which will handle them.
XRFan101
PostPosted: Fri Nov 19, 2004 12:46 pm    Post subject: Reply with quote
Also make sure you know what kind of setup you want as well, either SPL or SQ if my memory serves me correct small box + 10' sub = good SQ or
Big box+ 12' sub or 15' or whateva = Good SPL. I may be wrong but thats a fairly general rule to follow. icon_razz.gif
Im sure other people would have different opinions thou... icon_rolleyes.gif
haggis
PostPosted: Tue Nov 23, 2004 11:35 am    Post subject: Reply with quote
I've heard 2x 18" before, and lemme tell ya it was f**k crazy! I dont know how the car stayed together. It didnt sound particularily good - all the gains were set within too small a range, but the sheer volume was incredible
Interceptor
PostPosted: Tue Nov 23, 2004 6:43 pm    Post subject: Reply with quote
the biggest mass produced sub was a clarion 32", but there have been larger ones made
there's also a couple of 13" subs
[44 queries :: 0.06201 seconds ]
